03-10-2019, 06:56 PM
#16
Do you think you could just mask the sides and flares? Obviously you want to pull the bumper but...
03-10-2019, 06:59 PM
#17
Well, two things:
1- There is a right and wrong way to paint anything in life. The right way is to take it off and paint it properly.
2- I set out to just mask and shoot and realized there is too much that wraps under and that I wouldn’t be happy with the paint job so I removed it all.
03-10-2019, 07:20 PM
#18
Originally Posted by New_2_4runners
Well, two things:
;) excellent. I ask because my middle name is "breaks clips accidentally"
03-10-2019, 11:58 PM
#19
03-11-2019, 07:28 AM
#20
Wow, did you break any clips getting that stuff removed? It sucks they didn’t fully paint under the plastic pieces. I think I would spray over the primer either with matching blue paint,or even bedliner just for extra corrosion protection. Primer really isn’t great for stopping rust without a topcoat. Can’t wait to see the finished product!
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
03-11-2019, 08:20 AM
#21
I broke every clip. They’re not really worth the hassle to try to save so I just ripped them all off and bought new ones. It’s fully painted underneath, that’s just all the dirt and grime. I washed it all with a rag and it came clean.
03-11-2019, 08:33 AM
#22
Real Name: Ed
Real Name: Ed
I clicked the photos so they show in full size, the non body color areas may just be dirt. Although in the photo of the front fender, it almost looks like the area at the first clip hole (closest to the bumper) could've been "sanded down" all the years by the dirt stuck between the fender and flare and created a rusty spot.
@ New_2_4runners
could you post the link(s) to the fender flare clips?
03-12-2019, 05:47 PM
#24
Joined the forum just to follow how this turns out for you.
Have an 06 (white) that the dogs chewed on right at the junction between the wheel well and front bumper.
Body shop wants $900 to sand/fill/paint the area. That's not happening.
Been toying with the idea of doing exactly what you are tackling. Less money and an "upgrade".
Fricken chipmunks!
03-13-2019, 03:37 AM
#25
I want to have this exact thing done on my 4runner also. (Fenders clearcoar fading/oxidizing on all abs parts, and scuffs on bumpers) I don’t really want to have the parts removed, do you think it’ll be successful or be crap if I don’t remove the bumpers fenders and side panels. Could it come out good with proper taping ?
2005 V8 4wd Sport Edition. 3” lift 6112/5160 bilsteins, 1.25 wheel spacers, 20” limited wheels+33” Goodyear Wrangler Ultra Terrain tires, Gibson elite black cat exhaust. 3” nerf bars. Morimoto HID+projector retrofit into D-spec halo led headlights+ Morimoto 2stroke Led Highbeams/fogs.
03-13-2019, 03:39 AM
#26
Also I asked the local bed liner shop what they would charge to spray my bumpers, fenders, door panels, etc, they told me $900 and that’s without removing any bumper-parts/panels, I thought it sounded too expensive what do you guys think?
03-13-2019, 02:19 PM
#27
In to see how this turns out!
'06 V8 4R Sport, FOX 2.5 RR/DSC Coilovers, FOX 2.0 RR/CD shocks, Wheeler's & Timbren Bumps, ROKMEN lower links, LR UCA's, Warn VR8000, 7069's, Hanma LEDEEZ, DO Front Bumper, BAMF LCA Skidz, RCI Skidz, WMW Full Size 4x8 Roof Rack, WhiteKnuckle Sliders, etc. etc.
03-13-2019, 03:17 PM
#28
Various kits offer different amounts of the spray-on fluid, in bottles. Have you an idea just how much product would be required for the front and rear bumpers to be complete?
Mark
04 V8 SE, RST Twin stick conversion. 4x4 Labs rear bumper, SW Sliders & Bullbar, ARB Locked F&R, 5.39’s, Smittybilt 10,000lb winch, 1.5 4Crawler BL, Flowmaster, CB and 2m/70cm Ham, Sat. Radio, CO2 system, Lightforce, African Outback Rack, Budbuilt, Front Runner RTT. Rock Solid Toys Solid axles, Atlas Crawl Case, 40" Cooper STT Pro's on Fuel Anza D116 beadlocks, 5:38 gear set, ADS Coilovers.
03-13-2019, 06:48 PM
#29
It took me 4 750ml bottles but I definitely could have done it with 3 if I did it all in one sitting.
I’m currently waiting on the weather stripping and glue strips to come in at the dealership and then I’ll be able to have it all back on. This ended up being $125 for the bedliner and $150 for strips and clips to put it all back on.
You could spray it with it all taped but I REALLY don’t think it would turn out well because there are so many spots where the plastic wraps around and inside/underneath that you’d have a lot of spots that look weird. To each their own though.
I’ve done this frame swap and all of the improvements as right as I know how so when I sat down to do this after about 5 pieces of tape I said screw it and started cracking everything off.
03-13-2019, 07:03 PM
#30
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
