Old 03-05-2019, 03:52 AM #1
6wheelin 6wheelin is offline
Real Name: Hugh.
6wheelin is on a distinguished road
Real Name: Hugh.
Crooked steering wheel after off roading.
I get the rig aligned go wheeling and in the middle of my trail run the steering wheel is crooked, biased to the driver side.
From what I've read this is the driver side outer tie-rod lengthened and the passenger side shortened , ah maybe I have that backwards. Is this the shop simply not tightening down the lock nut? I'm planning on doing this adjustment in my driveway this weekend.
Is this a common issue? My buddy down in San Diego with a similar 4th gen has the same issue.
Build has a 3" Icon Stage 6 tubular suspension lift, DK LCA's, gusseted spindles, new Inner and outer tie-rods. Rolling on Method 17x8.5 701's wrapped with 285/75/17" Toyo Open Country MT's.
looking for constructive feedback. Really curious whether this a common issue and I need to start doing trail side adjustments?
TIA,
Hugh
2005 t4r Icon stage 2 custom roof rack and sliders. It's a process.
6wheelin is offline   Reply With QuoteReply With Quote
Old 03-05-2019, 05:11 AM #2
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Mine has done this twice after hitting the trails. My Alignment tech is very good and says it was not out of spec either time. Steering wheel was off between 10 and 11 o'clock to the passenger side the first time, then about the same to the drivers side the second time. We're thinking the bushings in the steering rack need replaced. Unfortunately not an easy fix, so I'm leaving it alone for the time being until I have the time to do it.
Post an update if you find a solution.
Good luck!
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 03-05-2019, 04:18 PM #3
Real Name: Hugh.
Real Name: Hugh.
I can't see how this would be bad steering rack bushings? From what I have read and watched on YouTube it seems a tie-rod adjustment issue. When others adjust those the problem is corrected. Can anyone explain how the steering bushings would cause this? I'd think they would manifest as sloppy steering.
To be clear the truck drives pretty straight, but it's been sitting in the drive way for two weeks so I can't recall if it pulls or not, I don't believe it does.
Has anyone encountered this and resolved it?
Yes if I find a fix I'll do an update.
Hugh
Good luck!
Old 03-05-2019, 04:51 PM #4
Real Name: Brett
Real Name: Brett
Hugh
Just a theory, something is moving around in there. If my specs are in alignment and the truck drives straight both times I did it, I have no idea what causes it. My situation might be different with the 35" BFGs. They are a few pounds heavier than a 33". I have hit this thing pretty hard both times. It might be just enough to move the rack a hair, but not enough to cause sloppy steering? I'm curious what everyone else might think on here.
Sorry not much help, good luck.
Old 03-05-2019, 06:17 PM #5
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Are you sure your pinion isn't jumping a tooth on the rack? A hard hit could conceivably do that if parts were old and worn. You could try centering the wheel and then measuring how much the rack arms extend from the box on either side. Should be the same with the wheel centered, I would think.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 03-05-2019, 08:40 PM #6
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
If the rack and pinion bushings are worn and the rack moves L or R, the tie rods move as well, this will not cause the alignment to change, cause slopply steering, or cause it to pull, but it will cause the steering wheel to be off center, this is what I think is causing the issue ya'll are experiencing, you can adjust the tie rods to get the steering wheel centered...BUT if the rack moves back the other way the steering wheel will become off centered again opposite of what it was before the adjustment.
2004 Limited V8
Old 03-05-2019, 08:56 PM #7
ElZilcho's Avatar
ElZilcho ElZilcho is offline
ElZilcho will become famous soon enough
ElZilcho's Avatar
If the truck drives true without pulling to one side or the other and the only symptom is the steering wheel is off center it is most likely that your steering rack has been bumped out of position. It's extremely unlikely that both the left and right tie-rods would slip but still hold proper toe. If you adjust the tie-rods to bring the steering wheel on center, but don't fix the underlying cause (which I believe is the rack) the truck WILL pull to one side or the other, or will alter its turning geometry at extreme steering angles.
I doubt the rack jumped a tooth but it's not impossible. Check the rack sooner rather than later. If you bumped it hard enough to move it you may have damaged the bolts holding it in place and it could be holding on by a thread and the next pothole could give you more of an adventure than you bargained for.
Be healthy.
Be nice.
Do interesting things.
2008 4WD SR5 V8. 2.5/1.5 Daystar. 265/75R16 Duratracs #UZN215
ElZilcho is offline   Reply With QuoteReply With Quote
Old 03-05-2019, 11:43 PM #8
having fun's Avatar
having fun having fun is offline
Real Name: Leonard
having fun will become famous soon enough having fun will become famous soon enough
having fun's Avatar
Real Name: Leonard
Had mine aligned before and the next day, no off roading, had the steering wheel sitting at 1oclock.
Turned passenger tie rod out, driver in. Equal amount of turns on each. Or the opposite cant remember.
Take out for a drive and see if you need to do it any more.
Plenty of hard off road runs since, no change or problems.
Having fun's build
having fun is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 03:12 PM #9
atalarico's Avatar
atalarico atalarico is offline
atalarico will become famous soon enough
atalarico's Avatar
Interesting since I had a Firestone tell me that my steering rack bushings were the reason my wheel wouldn't stay straight after off-roading. Same symptoms since it is technically aligned and doesn't pull, but yeah, it's just cocked to the driver's side at about 10 o'clock.
I thought Firestone was full of bologna, but it sounds like there might be some merit to what they said.
2004 Sport Edition V8. 3" OME lift. 5th Gen Brakes. 285/70 Duratracs. JBA UCAs. SCS Ray10s. DT Headers.
1997 4-Runner Limited w/ factory locker. Totaled in February 2018. Still miss it.
atalarico is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 03:57 PM #10
having fun's Avatar
Real Name: Leonard
having fun's Avatar
Real Name: Leonard
Have someone turn your wheel left and right, while looking at the rack, you'll see if the bushings are bad by the excess play.
Having fun's build
Old 03-07-2019, 04:19 PM #11
Real Name: Hugh.
Real Name: Hugh.
At this point I'm not sure of anything. I've replaced the all the inner and outer tie-rods so maybe it is the rack. Absolutely no idea whether it's the pinion slipping? I'll give the measuring a try.
Old 03-07-2019, 04:22 PM #12
Real Name: Hugh.
Real Name: Hugh.
The steering wheel has never moved the other way. Always to the driver side. I appreciate the clarification on symptoms. I'm leaning towards having the rack looked at.
Old 03-07-2019, 04:24 PM #13
Real Name: Hugh.
Real Name: Hugh.
Well I'm happy your problem is solved. I think tomorrow on my day off I'll do the same.
Old 03-07-2019, 04:27 PM #14
Real Name: Hugh.
Real Name: Hugh.
Interesting. What was the condition of the other components? Relatively new? Did they give you anymore information to why they thought it was the rack?
Old 03-07-2019, 04:27 PM #15
Real Name: Hugh.
Real Name: Hugh.
I will.
crooked , driver , issue , side , steering
Steering Rack Replaced now Steering wheel off, Please help! 4Runner4TW 3rd gen T4Rs 24 03-07-2023 01:00 PM
Replacing steering wheel with another Toyota/Lexus model steering wheel LexusFTW 3rd gen T4Rs 20 03-04-2021 12:24 AM
XUJI leather steering wheel cover install. Goodbye plastic steering wheel. OEM? Kelbad 5th gen T4Rs 24 05-19-2019 03:51 AM
Crooked Wheel After UCA's... bigjebus 4th Gen T4Rs 5 04-09-2015 04:09 PM
Steering Wheel Alignment w/ Steering Column UncleOOPS 3rd gen T4Rs 2 07-13-2012 04:17 PM
