Old 07-16-2019, 09:51 AM #1
MrEMan's Avatar
MrEMan MrEMan is offline
Real Name: Emory
MrEMan is on a distinguished road
MrEMan's Avatar
Real Name: Emory
Rear bearings/pinion seal
So I began to notice a noise coming from the rear end of my 06 … you know the noise all terrain tires start to make as they wear down? Kind of like that, but associated more with RPM (when in drive) instead of speed. So I took it in to the local shop that I know and trust … diagnosis, both rear bearings are bad and the rear pinion seal is leaking. I'd seen small spots of fluid on the ground around the rear differential the last couple of days, so the rear pinion seal leaking didn't surprise me … but the wheel bearings did.
The 06 has just over 290K miles on it. It was also involved in a minor (at least from a cosmetic perspective) rear end collision in January of this year. I'm just wondering how common it is for both wheel bearings to go out at the same time? Any chance that it's related to the accident or purely an age/mileage issue? Thoughts?
2006 4Runner Sport Edition V6 4WD - Shadow Mica
2005 4Runner SR5 V6 - Titanium Metallic
2004 Sequoia SR5 V8 4WD - Natural White w/ Silver Sky Metallic cladding
2002 4Runner SR5 Sport V6 4WD - Black
Yes, I still own all four ...
MrEMan is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 01:52 PM #2
having fun's Avatar
having fun having fun is offline
Real Name: Leonard
having fun will become famous soon enough having fun will become famous soon enough
having fun's Avatar
Real Name: Leonard
That many miles, bearing seal was probably getting weak enough to let a littl fluid through to the bearing to make them go out and not enough to show leakage past that.
Mine were weak and leaked through on 1 side, should have replace when doing a regear.
150k
Having fun's build
having fun is offline   Reply With QuoteReply With Quote
bearings , pinion , rear , seal , wheel
Are bearings mandatory for rear axle seal replacement? repo 3rd gen T4Rs 11 01-28-2016 11:13 PM
Rear Differential Pinion Seal Torque Specs Nick Danger Classic T4Rs 2 08-25-2015 03:00 AM
Rear Differential Pinion Seal Leak Northland_Runner 3rd gen T4Rs 4 10-08-2013 01:40 AM
bearings in pumpkin bad 1.5 years after rear axles seal & bearings replaced boudreaux Problems & Warranty Issues 2 05-02-2013 04:21 PM
94' rear Pinion seal Help Please Lunatick General Discussions 2 08-01-2011 10:33 AM
