03-06-2019, 11:39 AM
Oops, said my mechanic... XREAS blown.
So, as my mechanic was installing tp spacers on my '08 (just getting rid of the rake), he discovered dry and torn cv boots; my 2 hour bill suddenly ballooned to a 3.5 hour job, plus axles...BUT...when they had that done and were re-installing the struts, he mistakenly split the line on my XREAS system, blowing the whole thing.
Here's a sign of a great garage---they called me, owned that it was their fault, and offered to cover the replacement---with conventional stuff. Yeah, they spun it like they "could" get the XREAS but definitely tried to convince me otherwise. I knew why; cost, but I was fine with it. After all, it's got 122k on it, right? Gotta respect a garage with integrity. As a result, I get the spacers in, new axles, and new shocks and struts all the way around for about $500.
The question----huge differences in handling/response/etc. by going with conventional stuff instead?
03-06-2019, 11:53 AM
that worked out well for you id say. have them get 5100s and some new springs and ditch the spacers while youre at it
03-06-2019, 12:05 PM
Real Name: Ed
Real Name: Ed
I think you made out great b/c if they would've replaced the XREAS system, it would have grenaded as well in time. These damn things don't last past 100K miles. There are exceptions, but they are few.
03-06-2019, 12:06 PM
so if the system is opened its garbage?
"mistakenly split the line" if it rusted apart thats one thing another if he disconnected it. i recently tackled this job without xreas and it was a total pita to remove strut that wasnt even oem and rusted solid in there. ended up cutting everything out.
being that your in michigan, mileage and xreas failing in general sounds like a good deal
03-06-2019, 12:39 PM
I wish on the Bilsteins....I mentioned that to him, but there aren't any Bilstein dealers close by, so it'd take a few days, and they already had the whole front end torn apart. I'm pretty appreciative that they were so good about covering it, so I think it's getting KYB...like others said, the XREAS was gonna go sometime anyway.
03-06-2019, 01:51 PM
You could overnight some via Amazon...
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
03-06-2019, 02:01 PM
Honestly, I'd ditch the spacers and get the bilsteins. A few extra days wil l be worth it and if you have to spend a little extra it will certainly be worth the cost.
03-06-2019, 02:33 PM
those replacement KYB are actually awesome too though. i just got rid of them to lift with 5100s almost reluctantly because they ride great and they will give you a +1" in front too. itll be level after. check out one of my started threads, 'does my truck look stock height?'
03-06-2019, 02:46 PM
Real Name: Kevin
Real Name: Kevin
Would definitely recommend Bilsteins/stiffer springs if you're getting rid of XREAS. There's gonna be a decent drop in handling from what you're used to without the XREAS.
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
03-06-2019, 03:02 PM
Real Name: B-Money
Real Name: B-Money
Another vote for the Bilsteins. I know they want your truck out of the garage but you’re in this situation now so don’t settle. Really. The difference would be worth the wait and like it was mentioned, you can easily overnight the parts. Truth is, you’re in this situation because of the shop so they have to be willing to make sure you’re happy.
Anger Fuels Motion...Motion Fuels Momentum...Momentum Fuels Action...DO SOMETHING!
2010 4Runner SR5
03-06-2019, 03:15 PM
i agree with the above for sure. buy the kit on amazon and have it 1 dayed.
03-06-2019, 03:50 PM
I installed 5th gen springs and 5100's and could not be happier. the on road handling is different than the Xres, but after a few months i have zero regrets.
2003 - 4Runner Limited V8 (Sold)
2014 - 4Runner Limited V6
2019 - GX460 Premium V8
03-06-2019, 06:20 PM
Real Name: Michael
Real Name: Michael
5100s and ditch the spacers...no reason to save 2 days on something that you will be experiencing every time you drive the vehicle. Do it right once and don't look back. Trust me, you won't miss those 2 extra days of vehicle downtime.
03-06-2019, 11:18 PM
anyone have a price and link for bilstein 5100s?
03-07-2019, 08:20 AM
Amazon.
