Originally Posted by 2003V8LTD
I have XReas on my '03 ... having them doesn't affect your ability to add spacers one way or the other; the hydraulic line to the shocks is well out of your way.
2" seems like a lot. I used 1/2" spacers to get about an inch of lift and I would say it's pretty much level now -- I think raising the front alone by 2" would make it nose-high.
just now seeing this, the questions you are replying to are almost 3 years old...
i decided against spacers after reading & confirming that the spacers i had for standard shocks would not work with XREAS due to different stud location on teh top hat, its not about the fluid line locations, the xreas spacers are different than the standard SR5 spacers.
i went with all four KYB shocks, coil overs in the front with new springs preinstalled & replacement shocks in the rear keeping the stock springs. the KYB definitely raised the front about 1.5-2" over the 140k miles original XREAS shocks, 2" does not make it nose high, most people offset the front about 2" from the rear to reach level, mine is very close to level but still a little lower in the front than rear, sits perfect for my needs & looks great IMO for a daily driver.
