Old 07-23-2019, 04:09 PM #16
gaber6 gaber6 is offline
gaber6 will become famous soon enough
I did a small upgrade to Bilsteins on a car once and it made the ride uncomfortable for daily driving. I like the soft, boat-like ride of the 4runner.
If you can hammer the LCA bolt from the rear to the forward, you may be able to get away without cutting. I got lucky and had just enough wiggle (pry curse yank) room to get the LCA out with the bolt mostly hammered towards the front of each front bolt. The rear bolts hammered all the way out. And by hammer I mean BFH
gaber6 is offline   Reply With QuoteReply With Quote
Old 07-24-2019, 12:46 PM #17
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks has a spectacular aura about phatcheeks has a spectacular aura about
phatcheeks's Avatar
Ive heard good things about the Eibach pro truck shocks. They are a little more expensive than the 5100s but the ride is better.
2004 4runner Sport V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA
phatcheeks is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 11:16 AM #18
brienb1770 brienb1770 is offline
brienb1770 is on a distinguished road
Thanks to Mike at Exit Offroad, I got a great lesson in the (not exactly inconsequential) differences between the Dobinsons and the Bilsteins..
“The Dobinsons twin tube shocks have a much stronger build construction (twin tubes vs mono (single) tube), better quality pistons, better quality seals, much stronger lower mounts and welds, a fixed coil seat mount that's welded and can't fail, and they come with all the bushings you'll need as well. Google image search "broken bilstein" and you'll see where they fail.
Bilstein also uses digressive valving, meaning it's the firmest at ride height (harsh) then it gets softer when it compresses, so when you need it to absorb a bump better, it gets softer instead of firmer, which is backwards for how a shock would give the best ride quality. Dobinsons shocks have linear valving and are not firmer or softer at any position during the stroke.”
That told me everything that I shoulda known thirty-plus years ago. I trust it, and I trust Mike at Exit Offroad.. he is Dobinson’s (ex) Specialist now off doing his own thing, thankfully.
brienb1770 is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 11:46 AM #19
Tironeous Tironeous is offline
Real Name: Joe
Tironeous will become famous soon enough
Real Name: Joe
help me decide, dobinsons or bilstein shocks
On road only with no lift means you should be looking at Bilstein 4600s and not 5100s. If you want to have the option to eventually lift and go off-road then consider 5100s. I’m in a similar boat with what I want. Ride quality is of higher priority than lifting or going off-road. I’ll hit some gravel and a fire road a few times a year, but that’s it.
I’d add the Eibach Pro Kit to your list. If you’ve not bought from Wheelers Off-road before, you can get 10% off your first order. No tax. Free shipping.
PRO-TRUCK LIFT SYSTEM (Stage 1)
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Trail Wheels (early 5th gen) | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
bilstein , dobinsons , rear , shocks , springs
Can't decide. Bilstein 5100s w/ Eibach Pro lift springs or 6112s TimeZone 3rd gen T4Rs 1 08-07-2018 06:18 AM
Dobinsons vs Bilstein 6112/5160 (+ Dobinsons ?s) MossJenks 5th gen T4Rs 14 09-19-2017 10:58 PM
Dobinsons Long travel front struts and rear shocks Crikeymike 5th gen T4Rs 48 06-15-2017 03:01 PM
Difference between OME shocks and Bilstein Shocks? knightsfs4 4th Gen T4Rs 15 11-15-2011 09:47 PM
using tacoma bilstein trd shocks with LC coils and something else...will shocks work? theizzardking 3rd gen T4Rs 2 10-21-2009 07:03 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
