Old 03-08-2019, 08:49 AM #1
Dirtrider216 Dirtrider216 is offline
Dirtrider216 will become famous soon enough
06+ to 03 Headlight swap (backwards)
I know that plenty of people do a 2003 to 2006+ headlight swap but would it be just as easy to to a 2006 to 2003 headlight swap? I feel that it would be much easier to do a projector retrofit with 2003 headlights where I would just have to drill a hole in the reflector housing rather than try to mount a projector to the 06 mounting locations..
2006 limited v8 4wd
Toytec/ebiach 3” coilover lift with 1/2” top plate spacers, Jba high caster UCA’s, blistein 5100 rear shocks with toytec superflex hd springs, Cooper st max 255/80/17 with mb 352 in 17x9 -12 mm offset, auxbeam light bar in front bumper, custom retrofit headlights, SS brake lines, 5th gen brakes, custom rear storage box
Dirtrider216 is offline   Reply With QuoteReply With Quote
Old 03-08-2019, 09:01 AM #2
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
I haven’t done it, but there is a company that was discussed in a retrofit thread on here that makes a bolt in projector adapter for the ‘06 style lights. I considered trying it since my aftermarket ‘06 lights leaked anyway, but for now I decided to try some powerful LED bulbs that got rave reviews in another thread. If that doesn’t pan out, then I may just go the retrofit route.
I believe that converting the other way is doable with the correct under light trim pieces, and adapters for the bulbs, but I’m not sure how you would do the DRLs. On the earlier models, like my ‘04, the DRLs were next to the fogs in the bumper, and just get relocated to the corners of the ‘06 style lights, but not sure where they would go in your application...
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 03-08-2019, 11:45 AM #3
NinjaOne's Avatar
NinjaOne NinjaOne is offline
NinjaOne will become famous soon enough
NinjaOne's Avatar
I recall hearing the 03-05 headlights have inference issues with the 06-09 grill. So if you don't mind clearance your grill slightly or also running 03-05 grill you won't have a problem. You could potentially clearance the headlight housing themselves, but that could lead to leaking issues down the road if not done 100% correctly. It should otherwise bolt right in.
You would also need to relocate turn signals as 03-05 doesn't have signals (unless you build those into your retrofit)
<a href=https://www.instagram.com/t4r_juan/ target=_blank>t4r_juan</a>
NinjaOne is offline   Reply With QuoteReply With Quote
Old 03-08-2019, 06:42 PM #4
truckhigh's Avatar
truckhigh truckhigh is offline
truckhigh is on a distinguished road
truckhigh's Avatar
you might just need to trim out behind the grill where it meets the headlight and lower trim. there is a plastic triangle thing that unscrews off. if you follow that body line of the hood you would need to shave off enough for some movement. you can also do the grill too, but the bumper will look odd because the top will be exposed.
04 4runner Sport Edition V8
-MODS- Maxtrac Lift Spindles | Bilstein 5100/5160| Tacoma frt springs | MT LT 3in reat springs | eBay UCA | SS brakelines | 4crawler body lift | 17 level8 punch | At3 315/70/17 | K&N cai | black clazzios |
Build thread
truckhigh is offline   Reply With QuoteReply With Quote
Old 03-09-2019, 08:39 AM #5
I forgot about the grill! I have the ‘06 lights in my ‘04 and it works fine with the older grill, but you’re right, the older housings fill in that triangular area of the older grill. Since my truck and grill is black, those triangles aren’t as noticeable as they would be on lighter colored conversations.
Old 03-11-2019, 10:19 AM #6
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Here you go, brackets to install aftermarket HID projectors into 06+ headlights 2003-2009 Toyota 4 Runner MD2S 4.0/G5 C-Bracket – Custom Brackets & Designs
drill , headlight , hole , projector , swap
03-06 Headlight Swap Help BusinessHippieRH 4th Gen T4Rs 3 08-05-2017 07:57 PM
Headlight swap bd-wheels 4th Gen T4Rs 5 07-26-2016 02:46 PM
Headlight swap DRVNGENTHUSIAST 4th Gen T4Rs 14 03-04-2014 09:38 PM
'98 to mid-gen Headlight swap Asmara 3rd gen T4Rs 1 02-19-2010 01:23 PM
Headlight swap help mario552k 4th Gen T4Rs 6 02-27-2009 02:32 AM
