Old 03-11-2019, 12:52 PM #16
Johns06yota's Avatar
Johns06yota Johns06yota is offline
Real Name: John Iannacone
Johns06yota has a spectacular aura about Johns06yota has a spectacular aura about
Originally Posted by Bluesky 07 View Post
I like the reverse polarity kit. To be clear, installing it simply flips the current colors, correct? In other words, the white LEDs mentioned above are for the fan, temp control, & airflow source buttons (or knobs, or whatever they are), yes, and the odo & info panel characters are amber on the dark background?
That’s how I read it but always better to be certain before laying out $.
Also, how complex is the reverse polarity install?
The install is pretty straight forward. I have the instruction manual on my site if you would like to take a look. And yes this kit will flip the displays so it will be a dark background with raised lettering. If your instrument cluster still has amber LED's then the odometer will have a dark background with orange numbers. The HVAC display once flipped will be dark with white lettering as the kit includes a prebuilt wire harness with a wire tap for the specified connection point(The LED's are 12 volts) You can also do the add on for the kit which includes 6 T3 LED's for the HVAC button illumination. (the little orange arrows will still be orange as those must be de-soldered to replace)
Johns06yota is offline   Reply With QuoteReply With Quote
Old 03-11-2019, 02:53 PM #17
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
We’ll have to see on the steering wheel kit. That’s probably close to 1k, really nice, but really expensive. I’m a buyer if your polarity kit though. I’m guessing it’s easily reversible if it’s not my thing? Also, wasn’t really interested in doing the odometer. But even in stock amber, is it still easy to read? Your HVAC looks great.
Air 4rceRunner One, 04 Sr5
simple is offline   Reply With QuoteReply With Quote
Old 03-11-2019, 02:59 PM #18
WhiteBoomer04's Avatar
WhiteBoomer04 WhiteBoomer04 is offline
WhiteBoomer04 will become famous soon enough
Do you have any particular recommendations on steering wheel suppliers?
Mark
04 V8 SE, RST Twin stick conversion. 4x4 Labs rear bumper, SW Sliders & Bullbar, ARB Locked F&R, 5.39’s, Smittybilt 10,000lb winch, 1.5 4Crawler BL, Flowmaster, CB and 2m/70cm Ham, Sat. Radio, CO2 system, Lightforce, African Outback Rack, Budbuilt, Front Runner RTT. Rock Solid Toys Solid axles, Atlas Crawl Case, 40" Cooper STT Pro's on Fuel Anza D116 beadlocks, 5:38 gear set, ADS Coilovers.
WhiteBoomer04 is offline   Reply With QuoteReply With Quote
Old 03-11-2019, 03:55 PM #19
Formidable's Avatar
Formidable Formidable is offline
Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light
Formidable's Avatar
Any idea which Toyota or Lexus wheels have the heated feature? That would be nice.
2002 Thundercloud | TRD Supercharger | TRD Headers | URD 2.2 Pulley | Toytec | Addicted Offroad | 4xinnovations | Icon | SCS | BRIDE
BUILD THREAD
Formidable is offline   Reply With QuoteReply With Quote
Old 03-11-2019, 06:04 PM #20
I completely understand. And to reverse it you would need to use more polarization film in the original orientation. I cannot guarantee that going back to what it was before would look exactly like oem as the film I use I'm sure is different from what toyota uses. And the stock amber for the odometer is easily readable but for the HVAC cluster it would not be. Those 12 volt white LED's I include would really have to be used to make things visible during the day as the stock toyota bulbs I do not believe would be bright enough
Old 03-11-2019, 06:04 PM #21
Typically ebay has them at decent prices or LKQ might also
Old 03-11-2019, 06:06 PM #22
I've done a little research but I plan to do more in the future. Right now without testing there is no way of me knowing if the heated functions would work. I am almost positive that the clock spring would require modifications
Old 03-31-2019, 11:22 PM #23
simple's Avatar
simple's Avatar
Multiple customer from Ian here. Super pleased with his customer service, and obviously a guy who really cares about his products.
Here's a mini review, 'enhancements', and lessons learned.
I did the reverse kit and steering wheel.
For the reverse kit, I ended up buying 2 because I didn't follow Ian's directions very carefully. I almost just let my errors ride, but I'm really glad I didn't, because it's AWESOME when done correctly.
The directions I didn't follow closely were, be careful with the razor, it is indeed sharp, and it does indeed cut. I also didn't take my time with the install of the cover, and it ended up crooked and with air bubbles.
2nd time around I ended up using a plastic handle for the razor blade, way easier on my fingers, safer, and more efficient. I also used a little piece of scotch tape on each end of the polarized film to help me line it up this time. I did end up with 1 tiny air bubble, but I'm good with it, and it looks great.
I also cut the 12v wire and crimped on a male and female connector. This allows me to connect and disconnect my console whenever I want...which is quite frequently with all the stuff I do in my ride.
Here's a pic of the first install. You can see some hotspots. When I took the pic. I was actually going to comment that I don't notice the hotspots in person, just on the pic. But when I misaligned the film the first time, there was sliver of led screen exposed. Nothing I could see on the console. But, I now think the light bleed over was responsible, because my new film covers everything and looks great.
Steering wheel install here. Plastidipped emblem black.
The cost really scared me here. I was able to pick up an airbag luckily on offer up for about 300. Not much you can do here, these are pretty expensive wherever you go. The steering wheels on ebay were about 250-300. That was too rich for me. I ended up looking on car-part.com and saw them for significantly cheaper. I found a 2016 trail steering wheel for 65 dollars. I had to get it shipped, but it was only 15 to ship.
I tried to do this myself, because I like doing things myself, but I had to turn to ian. Just save yourself the hassle, if you do this mod, send him your controls. It would probably be a good time to change the color of the LEDs as well to whatever you want.
Old 04-01-2019, 02:19 PM #24
That turn out really great man! Just let me know if you end up having any questions or concerns. Thank you for the business.
-John
hvac , odometer , site , steering , wheel
Camelback Toyota Parts Site Down GrassFed General Discussions 22 10-27-2016 12:54 PM
Interesting Used Parts site. SilverRidgeRunner1 3rd gen T4Rs 12 01-08-2016 10:51 PM
Parts site with diagrams? graeaglecrawler Classic T4Rs 7 11-07-2011 07:10 PM
What the best site to buy t4r parts? Gabriel33 Classic T4Rs 10 11-07-2011 06:20 PM
