03-10-2019, 07:05 PM
Was there a V6 4x4 in the 4th Generation?
I didn't think so but occasionally come across posts that suggest there is such an animal. In the past I assumed it was a mistake but maybe this exists?
Thanks.
03-10-2019, 07:08 PM
Thanks.
Yes they exist.
I don't know the numbers but I'm guessing there are the same amount of V6's and V8's out there. 4x4 and 2x4 of each.
03-10-2019, 07:21 PM
Originally Posted by Inv4drZm
Yes they exist.
Well that sucks, because the only thing keeping me from really wanting a 4WD 4th Gen was thinking I'd have to get the V8.
03-10-2019, 07:37 PM
Yes. Many many many v6 4x4's out there. They are lovely, with the option for 4x2, 4x4 open center diff (AWD), and 4x4 locked center diff.
03-11-2019, 06:50 AM
Yes I have one and have had it since new in 2004, very common. Plenty of power even when pulling my 20 foot boat.
My 4th 4x4: 2004 V6 4Runner 4x4 (dealer replaced engine at 70,000 miles 2006 - http://www.toyota-4runner.org/showth...ight=nightmare), Mich. Cross Terrains, Nitto T/G, now BFG AT KO's 265/70/17, Leather, Husky mats, Escort, iPhone (phone, GPS, iPod), USA Spec Bluetooth Interface, Fumoto Valve
Current daily driver: 2008 Honda Accord EX-L w/Navi
03-11-2019, 09:15 AM
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
03-11-2019, 12:24 PM
Real Name: Will
Real Name: Will
Yes, they are tough to find. I specifically looked for a v6 because it has the option to go from 2wd to 4wd.
2007 Sport Edition 4WD - Build Thread
03-11-2019, 12:42 PM
Yep, that’s what I have... V6 4x4, SR5 (no rear locker)
Center diff (Torsen type) allows operation in:
2WD
4WD High Unlocked (aka AWD)
4WD High Locked (true 4x4)
4WD Low Unlocked (aka AWD)
4WD Low Locked (true 4x4)
My model year (2004) does not have an option to turn off traction control in 2WD or 4WD unlocked (aka AWD mode), which means you need to lock the center diff to disable VSC. If you want to have some fun in 2WD mode, you need to perform a slight modification (cut wire & add switch) to disable it.
I’ve had the truck in our family since new… but if I was to start this from fresh today, I would be looking for the V8 variant for no other reason than it’s a V8.
That said, 200k+ miles later, this thing is still solid. My favorite thing about the V6 motor is that is uses a timing chain which is good for the life of the engine, and the location of the oil filter. Easy of maintenance including things like spark plug changes are very easy.
03-11-2019, 01:00 PM
Thanks.
Given that you hail from LA, you may not find as many because a lot of the 4th gen 4Runners came in 2wd in the South and SouthWest. But in the rest of the country, the V6 in 4x4 is very common.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
03-11-2019, 01:55 PM
Real Name: Derek
Real Name: Derek
The real odd-ball is the 4th gen with a 4 banger.
I love my V6 4x4.
It is not AWD like the V8, you can run the V6 in 2wd or 4wd.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
03-11-2019, 02:08 PM
I find this question amusing, since in my area, V6 engines easily outnumber the V8's.
A 200 miles search from my zip for 4x4 06-09's shows 36 V6's and 4 V8's.
03-11-2019, 03:12 PM
I was thinking the same thing… I can find a lot more V6 variants… cheap bastards =)
That said, the GX (at least in my area) is very easy to find, and for decent prices when compared to V8 4x4 4Runners. Personally, I would not rule this option out unless there was something specific about the 4Runner you wanted. Sure you would look like a suburban housewife (if you don't mod it), but it’s got grit. It’s still the hearty same body on frame 4x4 goodness. Even shares the same suspension parts making life easier when it comes to upgrades / modifications.
03-11-2019, 03:18 PM
I spent 6 years in Pittsburgh. Love that city, may need to swing by for a "shopping" trip.
03-11-2019, 03:58 PM
I think V6's are more common in my area than V8's. Mine is a Limited with a V6.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
03-11-2019, 04:57 PM
4HI with center diff unlocked is a lot like the AWD on V8s. Almost exactly the same...
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
