I want to use a preload spacer to lift my front end a tad more. I'm looking at the following two options:
Toytec's Preload spacer replaces the bottom perch (picture below). I have the TRD Pro suspension so do not have the ability to adjust the height of the perch. This seems like a stock-ish solution.
Wheeler's Preload spacer sits between the coil spring and top plate spacer (picture below).
The toytec kit is about 3-4x the cost of the wheeler poly kit. Is the toytec kit
actually a better option? Or are they functionally the same? Lots of road driving. No serious offroading.
