Originally Posted by Dubbs_Malone
How can I tell if it's the slip yoke?
Is it a 4WD or 2WD?
If it's a 2WD it's not the slip yoke as only the 4WD seems to be the ones with this issue and also the 2WD don't have zerk fittings to grease on the driveshaft.
If it's a 4WD just grease the slip joint on the driveshaft until it moves a bit from the grease going in, usually 15 to 20 pumps on a grease gun, if that was the issue it shouldn't be doing the thump any longer until it needs greasing again.
