Old 03-19-2019, 03:35 PM #16
4by4runr's Avatar
4by4runr 4by4runr is offline
4by4runr is on a distinguished road
4by4runr's Avatar
Originally Posted by YetiX View Post
I'm really surprised how low you're running your tires. Every tire place/guy that I have consulted has said that E load tires should be run at higher psi. I run my 265/70 Ridge Grapplers at 45 psi and they're comfortable on the street and wear evenly.
I think they are forgetting that the e load tires have a max psi of 80psi or 2900 pounds per tire. They are made for heavy loads. Airing down to 20-30 puts a lot of force into The sidewall that builds up heat and can cause failure. The correct chalk test shows 45-50 as optimal. Again these are not c load. I’m not going to argue because you are free to do what you want, it’s your tire and your moneys
Thank you all for your contributions.
2004 V8 4x4 sport in Galactic Grey • Xreas delete • 248k • BFG KO2 265/70/17 • Custom Arizona sun two tone paint • 2" leveling kit
4by4runr is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 08:30 PM #17
YetiX's Avatar
YetiX YetiX is offline
Real Name: Scott
YetiX has a spectacular aura about YetiX has a spectacular aura about YetiX has a spectacular aura about
YetiX's Avatar
Real Name: Scott
Originally Posted by 4by4runr View Post
I think they are forgetting that the w load tires have a max psi of 80psi or 2900 pounds per tire. They are made for heavy loads. Airing down to 20-30 puts a lot of force into The sidewall that builds up heat and can cause failure. The correct chalk test shows 45-50 as optimal. Again these are not c load. I’m not going to argue because you are free to do what you want, it’s your tire and your moneys
Agreed. So are you switching to the C load or keeping the E's?
-Semper Fi-
2006 4Runner Sport Edition 4WD V6/Suspension/Armor/Lights/Wheels and tires/Drawers/Camping things/Surfboards/Rhodesian Ridgebacks . . .
BUILD AND ADVENTURE THREAD
YetiX is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 08:42 PM #18
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future
Inv4drZm's Avatar
The heavier the sidewall the lower the pressure you can run. And should run. You have the certificates why worry about 'heat' buildup destroying a tire, I've never heard of this happening.
30-35 psi should be tried before getting rid of them and I can guarantee you they will wear evenly, all of mine have. All ten tires I've had on my truck and 5 on my brother's have been fine.
If 30-35 psi is still too rough then at least you will know.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 09:58 PM #19
davidaw's Avatar
davidaw davidaw is offline
davidaw is on a distinguished road
davidaw's Avatar
Cant comment on the tire science questions but I've had the KO2s for 2 years and 40,000 miles. 275 70 17, E Rated
Been running at 35 on Hiway. No wear problems.
Have not seen much of a drop in MPG but I know there must be some.
Did cross country wheeling trip to CO, UT. Spent a few weeks on the beach at 15 psi.
Various mild off-road trips.
These tires look brand new. Best I've ever had.
Like someone said, it feels good knowing you have the extra meat if you need it. Especially if you are 50 mile from no where.
_________________________________________________
2008 SR5 V6 4WD Toytec 3" lift, BFG 275/70-17 KO2, JBA UCA, 4xInnovations WeldOn Sliders
1985 FJ60 OME-4Plus lift Micky Thompson 33's, Aussie Locker, Mucho Rusto
davidaw is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 10:18 PM #20
Benski's Avatar
Benski Benski is offline
Benski is on a distinguished road
Benski's Avatar
I have BFG KO2s E load, my third set, and I run 32psi front 30psi rear. I don't air up or down, I just drive! I got 107k miles on the first set, and 87k on the second set. I rotate them at 7,500 per the owners manual, and they wear evenly and last a long time. The tire is very durable off road, runs quiet, and looks great!
Ben
1996 T4R SR5 4wd 5speed manual 3.4 V6
Evergreen Pearl w/ Taupe cloth
265/75 16 BFG AT T/A KO2, E load
274,000+ miles...
Benski is offline   Reply With QuoteReply With Quote
Old 03-20-2019, 12:10 PM #21
4by4runr's Avatar
4by4runr's Avatar
So you never heard about the Firestone/Explorer mishap that left a couple hundred people dead. Ford made an executive decision that to make the ride more comforting, they spec'd the pressure to be 26 psi on the oem Firestone tires instead of the 30psi that was on the tires. This combo of heat/an existing defect and low pressure caused the separation. And no, they didn't add the 3ply sidewall so that you could reduce the pressure so you could have a nice ride and protection.
To address others' comments, I'm moving back to Michigan where E load is really overkill for wheeling as there are very VERY few rocky areas in Michigan, mostly mud and sand or roots. If I were staying in AZ I might give it more consideration. I think the E is a fine tire, just not for my needs. Pointless loss of MPG and increased harshness.
YetiX;
I went with the C's, running at 40psi and the ride is great.
Aside:
In the week I drove with them, I noticed about a 2 mpg drop from my coopers which weighed in at 44lbs, the C's are 45lbs so I estimate that I'll get close to my mpg starting point.
Old 03-20-2019, 01:48 PM #22
Inv4drZm's Avatar
Inv4drZm's Avatar
Tire manufacturing issue not psi issue. You're comparing a crappy p rated tire made 20 years ago to modern high-end offroad tires. The Michelin tires they used were fine.
Old 03-20-2019, 03:09 PM #23
4by4runr's Avatar
4by4runr's Avatar
I'm not going to get into a pissing match with you so have fun.
My input in this thread is finished, thank you everyone who positively contributed.
Old 03-20-2019, 11:29 PM #24
Rodtheviking's Avatar
Rodtheviking Rodtheviking is offline
Real Name: Chris
Rodtheviking will become famous soon enough
Real Name: Chris
Exactly.
And I give false info in my previous response, I have my E loads at 36 and 34.. not 26 and 24 like I had stated. My apologies, it was late.
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
Rodtheviking is offline   Reply With QuoteReply With Quote
Old 03-21-2019, 08:50 AM #25
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
if they offer 255 75 17 BFG AT in load E i might run them next time around. considering people have accounts of them lasting twice as long as other brands. well see on my kumho at51 though, they are performing awesome so far.
hinmo24t is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 12:44 PM #26
4Runner&Airstream 4Runner&Airstream is offline
4Runner&Airstream is on a distinguished road
I just joined this forum as I need new tires for my 2013 4Runner.
I am getting a new trailer that will weigh about 5,000 lbs and have about a 600 lb tonge weight.
I am wondering if I should be going with a load E tire.
I also wonder what 4Runner owners are liking for tires.
I’ll be on pavement the majority of the time but like to explore and sometimes have to haul the trailer up some non paved surfaces.
Can anyone recommend tires?
4Runner&Airstream is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 03:31 AM #27
Ben84 Ben84 is offline
Ben84 is on a distinguished road
Anyone actually tried the KO2 265 70 17 rate C?
I'm considering getting the 265, but I see that the load index is lower than the stock (112 vs 113) and wondered if this could be a problem.
Ben84 is offline   Reply With QuoteReply With Quote
Old 06-02-2021, 01:13 PM #28
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is on a distinguished road
Romeo1's Avatar
35 psi is fine in an LT tire for road use. Airing down for the off road if though is totally worth it. Makes for such a better experience. And it allows you to carry so much more speed so much more comfortably it’s not even funny. 20 to 25 is a really nice happy middle for rallying.
I went full the full monty and got an arb twin air portable. Yeah it’s silly expensive, but once you get over the sticker shock, I’d say it’s probably my favorite tool purchase in the last 25 years….. not even kidding. The money I have invested in Mac and Snap-On Tools is a bit nauseating.
That first time I used it, I had that feeling of where have you been all my life?
Airing up or airing down for me is less than a five minute job on the 4Runner. Even aired up the truck tires the other day because I just felt like taking it to 75 for the load I was hauling. It almost feels like using shop air.
I guess if you’re going to be hard on the tires, more meat and mass is never a bad thing. The trade-off is it’s pretty obvious that it’s got some heavy shoes on her when you go down the road.
It really just comes down to what are you wanting to have and what are you willing to put up with.
That all said, if I could find a C rated 265/75/16, 3ply side wall, aggressive, and 3 peak snow rated, it would definitely be a shut up and take my money situation. But that tire seems to be a bit of a unicorn in a 16. Closest there is is the Kanati trail hog in an E rating.
I really don’t want 17s for various reasons. But there is a KO2 size in a 17 that would fit that gets really close, but maybe not quite as an as of aggressive a tires I would like though.
But seriously, don’t fight airing down/up. I fought it fought the last 3 decades and I feel a bit retarded about it now.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Kanati Trail hogs, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, kids call it “Vader”
Romeo1 is offline   Reply With QuoteReply With Quote
bfs , discount , load , moving , tire
Discount Tire BFG KO2 285/70/17 C load Instant Savings TexasBock Engines / Suspension / Wheels / Tires / Audio / Accessories 5 02-20-2019 03:12 PM
Daily driving: 285/70/17 C-load vs 255/80/17 E-load? str8flexed General Discussions 5 01-04-2019 12:09 AM
Tire help - which load rating & tire--- Any input on the Kumho KL61 P vs KL78 E ?? FLynFish Engines / Suspension / Wheels / Tires / Audio / Accessories 4 06-13-2013 10:40 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
