Old 03-16-2019, 04:59 PM #1
4by4runr's Avatar
4by4runr 4by4runr is offline
4by4runr is on a distinguished road
4by4runr's Avatar
bfg ko2 load c vs load e (discount put on wrong tire)
So as some of you may know I went to discount tire to get some BFGs. I specifically asked for load c knowing that load e are heavier and I don't do much trailing. I've already got an alignment. I've driven on them a bit and don't notice any harshness but I didn't really want to take the hit on MPG if it's not needed, especially considering I'm moving 2000 miles in about a month.
Opinions on C VS E?
or anything I may not be taking into consideration.
Thanks!
And my receipt says load c 112
2004 V8 4x4 sport in Galactic Grey • Xreas delete • 248k • BFG KO2 265/70/17 • Custom Arizona sun two tone paint • 2" leveling kit
4by4runr is offline   Reply With QuoteReply With Quote
Old 03-16-2019, 06:43 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Well first you got a much better tire with the E rated version, but you will take a hit on MPG, if you can live with that I would say keep them.
How long have you had them installed and driving on them?
If not all that long take them back and demand that they swap them out, if you have had them on for more than a few weeks you maybe out of luck since you shold have inspected them after the install and now have to sell them and then get the correct tires, you could play inexperienced/dumb and tell them you had no way of knowing it was the incorrect tires until an experienced friend pointed it out to you and may get them to do the right thing.
2004 Limited V8
Old 03-16-2019, 07:07 PM #3
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
There is no point in getting the E unless you really can use the 3-ply sidewall, which you can in Arizona. If moving 2000 miles away, however, you won't actually need those.
They are not "better" tires, they are simply "different" tires with higher load capacity and, in the specific case of the KO2, better strength for offroading, too. They are stiffer so that's better for handling and cornering but thereby also harsher.
If you want to have the middle ground, DT claim they offer D load in 265 70 17, which should be acceptable. It has a 3ply sidewall as E but won't be as harsh on road.
To me, as far as KO2 go, the LT-D is a winner.
Btw, I offroad in AZ on P-metric tires. The LT-D KO2 will probably be my choice if I feel the need to go back to a 3ply sidewall.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 03-16-2019, 09:13 PM #4
4by4runr's Avatar
4by4runr's Avatar
Update
Called discount tire to get this resolved. I am quite happy with the tires, they don’t actually seem as rigid as everyone let’s on, the ride is on par with what I’m used to. So I proposed that instead if them having me come back up there, waste my time, them pay for another alignment, and waste more of my time, that they give me the certs for their tires. And we’ll call it good.
They did and we are (good)!
Another happy accident!
Old 03-16-2019, 10:56 PM #5
zeekevin zeekevin is offline
zeekevin is on a distinguished road
I had the e load ko2 and like the ride, but recently switched to the c load ko2 which shaved roughly 10 lbs a tire, it is softer so all I did was just run a higher psi in the tire
zeekevin is offline   Reply With QuoteReply With Quote
Old 03-16-2019, 11:15 PM #6
0verland's Avatar
0verland 0verland is offline
0verland will become famous soon enough 0verland will become famous soon enough
0verland's Avatar
Personally, I chose E rated too and don't regret it. Here in Arizona I would def rather take the slight hit in MPG to have a thicker ply tire.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
0verland is offline   Reply With QuoteReply With Quote
Old 03-17-2019, 12:10 AM #7
phqduphead's Avatar
phqduphead phqduphead is offline
Real Name: Kyle
phqduphead is on a distinguished road
phqduphead's Avatar
Real Name: Kyle
Glad they made it good. I’ve had great service with discount for 20 years. I can’t imagine that the E would make a huge impact on mpg, maybe 1, also changing tires would not require a new alignment.
06’ Sport 4WD, locked on 33’s
phqduphead is offline   Reply With QuoteReply With Quote
Old 03-17-2019, 01:12 PM #8
4by4runr's Avatar
4by4runr's Avatar
Well you guys have all given me some great insights. I took the tires on a midnight run down a stretch of rough paved road (at45psi) to simulate the roads back in Michigan. I had only driven these so far on fairly nice freeway and the like. I have to say I’d agree that there is simply no cushion. And unfortunately as awesome of a deal as these are (4 with certs for $880) they are overkill for my needs and unnecessarily rough. Most wheeling in MI is just roots/muddy so I’ll be taking them back to get the c load that I wanted in the first place.
I read a couple other threads on here about c vs e and in order to not destroy the tire you basically have to live with the stiffness 45-50 psi unless wheeling. I’m mostly commuting but I’ll have some tougher terrain when I head out fishing or hunting in mi.
Thank you to everyone here for your insights!
Old 03-17-2019, 01:14 PM #9
4by4runr's Avatar
4by4runr's Avatar
Discount tire has a pretty clean 30 day return policy - one of the reasons I go there. I’ve never had a customer service problem there.
Old 03-17-2019, 11:19 PM #10
Rodtheviking's Avatar
Rodtheviking Rodtheviking is offline
Real Name: Chris
Rodtheviking will become famous soon enough
Real Name: Chris
What tire pressure did they set them to? I have E loads and run 26 front and 24 rear, ride is just fine but have to deal with the tire light on. I did the "chalk" method to find my pressure with my given set up.
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
Rodtheviking is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 11:39 AM #11
4by4runr's Avatar
4by4runr's Avatar
They’re set at 45psi all around. Running them on the freeway at 26-30 could be catastrophic due to the heat build up in the sidewalk.
Old 03-18-2019, 01:35 PM #12
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
my LT 6-ply kumho (dont think they are listed as E though) have a cold pressure max of 50psi...im running them at 34lbs right now and they feel good. i dont think you wanted to run those load E with so much PSI, must have been super harsh lol
hinmo24t is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 03:49 PM #13
Inv4drZm's Avatar
Inv4drZm Inv4drZm is online now
Inv4drZm's Avatar
I would try 30-35 psi before getting rid of them. As far as driving with real low pressures, my rig and a couple others drove an entire week all around moab with less than 20psi at highway speeds with no bad effects, your mileage may vary though. I think we've done that for two vacations there come to think of it.
Inv4drZm is online now   Reply With QuoteReply With Quote
Old 03-18-2019, 11:22 PM #14
Real Name: Chris
Real Name: Chris
This is the method I used with a good explanation.
Tire Pressure Checker: Righting the Pressure in Your New Tires | 4wheelparts.com
I guarantee you are running on the center of your tires, and they feel like bricks.
Old 03-19-2019, 03:17 PM #15
YetiX's Avatar
YetiX YetiX is offline
Real Name: Scott
YetiX has a spectacular aura about YetiX has a spectacular aura about YetiX has a spectacular aura about
YetiX's Avatar
Real Name: Scott
I'm really surprised how low you're running your tires. Every tire place/guy that I have consulted has said that E load tires should be run at higher psi. I run my 265/70 Ridge Grapplers at 45 psi and they're comfortable on the street and wear evenly.
-Semper Fi-
2006 4Runner Sport Edition 4WD V6/Suspension/Armor/Lights/Wheels and tires/Drawers/Camping things/Surfboards/Rhodesian Ridgebacks . . .
BUILD AND ADVENTURE THREAD
YetiX is offline   Reply With QuoteReply With Quote
bfs , discount , load , moving , tire
Discount Tire BFG KO2 285/70/17 C load Instant Savings TexasBock Engines / Suspension / Wheels / Tires / Audio / Accessories 5 02-20-2019 03:12 PM
Daily driving: 285/70/17 C-load vs 255/80/17 E-load? str8flexed General Discussions 5 01-04-2019 12:09 AM
Tire help - which load rating & tire--- Any input on the Kumho KL61 P vs KL78 E ?? FLynFish Engines / Suspension / Wheels / Tires / Audio / Accessories 4 06-13-2013 10:40 AM
