Old 03-17-2019, 12:47 PM #1
runokc runokc is offline
runokc is on a distinguished road
3rd Gen Tacoma Suspension Swap (2016-2019)
Just installed suspension from a 2017 Tacoma Off Road on my 2006 Sport Edition 4WD V8 (120k)
Shocks Front and Rear, Front Coils all fit perfect
(also swapped UCA's they looked identical to mine)
Rear Bilstein B12 1.8" Coils Bilstein B12 (Special) For 2003-2009 Toyota 4Runner 1.8" Rear Coil Springs
Rear lower shock bushing to swap
Universal Shock Bushings - 9.8108
Couple of things I wanted to say, ride is really good. My suspension was not bad, this is much better. Felt very very similar to a 2015 TRD 4runner I road in at an off road event. XREAS does reduce body roll, noticed it on a clover leaf immediately after swapping it. The old shocks don't have near the dampening over bumps and gravel that this suspension has, maybe it did when new!
Main reason I went this route, and I know I will here push back is...I came from autocross, and trying to perfectly match spring rates with shock rebound is hard. I don't feel comfortable running a spacer lift, I feel buying a proper length spring and shock is a better option for off road, comfort/handling. Not saying that putting an over inch longer shock is how the geometry of the vehicle is designed, but the longer spring compensates well with it.
I didn't take before or after measurements and I have 32" Falcon Wildpeak AT3's but I have some before and after photos that will give you and idea. I believe its about 2" all around. If anyone has any question let me know, the whole set up was under $400.
PS: Everything i read previously states you have to loosen the LCA, to remove the front coils (which changes alignment) you don't....you can just remove the swayer bolts on both Driver, and Passenger side. Then simply rotate the sway bar counter clockwise up over the top of the UCA.
First Three are Before, last three are after!
3rd Gen Tacoma Suspension Swap (2016-2019)-fullsizeoutput_961-jpg  3rd Gen Tacoma Suspension Swap (2016-2019)-fullsizeoutput_952-jpg  3rd Gen Tacoma Suspension Swap (2016-2019)-fullsizeoutput_951-jpg  3rd Gen Tacoma Suspension Swap (2016-2019)-fullsizeoutput_960-jpg  3rd Gen Tacoma Suspension Swap (2016-2019)-fullsizeoutput_962-jpg  3rd Gen Tacoma Suspension Swap (2016-2019)-fullsizeoutput_963-jpg
runokc is offline   Reply With QuoteReply With Quote
Old 07-27-2019, 01:24 AM #2
NWTrailRunner NWTrailRunner is offline
NWTrailRunner is on a distinguished road
Did you find the Rear Bilstein B12 1.8" to match well with the shocks? Did you end up level?
I just picked up a set from someone's 2018 Tacoma Off Road today and now need to get a set of rear coils to make sure I don't come out nose high.
Thanks!
NWTrailRunner is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 05:23 PM #3
Yes it is perfectly level, you will have to compress the rear springs a bit to get the button shock bolts on. These spring would deff accommodate a larger rear shock if you wanted as well.
Old 09-19-2019, 01:12 PM #4
JShipps JShipps is offline
JShipps is on a distinguished road
Thanks for this thread guys! I have an 07 SR5 V6 4WD with original suspension that's sagging. Do you have any thoughts on the difference between swapping 3rd Gen Tacoma vs 2nd Gen Tacoma suspensions on our 4th Gen T4R? Is one higher than the other? I understand I'll need to find different springs in the rear and you guys mention the Bilstein B12s, but would FJ Cruiser rear springs work as well? I want some lift, but just what the new suspension will give me. I'm OK with being level or a little rake, and I'm not adding any weight like bumpers, etc. This is my daily driver and won't have any oversized tires.
Thanks for the advice!
4Runner Noob
2007 SR5 V6
JShipps is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 04:41 PM #5
JVC8790's Avatar
JVC8790 JVC8790 is offline
Real Name: John
JVC8790 has a spectacular aura about JVC8790 has a spectacular aura about JVC8790 has a spectacular aura about
JVC8790's Avatar
Real Name: John
I've got 2nd gen Taco TRD Offroad fronts currently and as I'm told they are a little bit lower. I purchased 3rd Gen ones that are just waiting to be installed at some point in the future. I paired mine with FJ Rears and swapped out the rear shocks with those from the TRD Tacoma with new correctly sized lower bushings. Check the build thread in my signature for more pics, sounds like your needs are pretty similar to mine although I did end up going with a slightly oversized wheel/tire mostly because I needed new tires anyways and found a deal!
2004 4Runner V8 Limited - TRD Exhaust, LED Interior Swap, Pioneer HU, Tacoma TRD Front Suspension, FJ Rear Springs, 10" + 32" Light Bars, Prius Shift Knob, 275/65R18 Falken Wildpeak, 18x9 Level 8 MK6 Et0, GOBI Ladder, 06-09 Headlight Swap, TOTALED NOV 2019, RESURRECTED APR 2020 Build Thread
1998 Volvo S70 T5 - Custom Airlift Suspension, BBS Nebula Wheels, Brada Seats, Engine Bolt Ons - StanceWorks Build Thread
2010 Subaru Forester 2.5X - Wifes Car
JVC8790 is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 08:04 AM #6
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
@JVC8790 Did you ever install the 3rd Gen fronts? If so, what was the outcome in terms of height? TIA.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 08-21-2020, 08:55 AM #7
mykdee mykdee is offline
mykdee is on a distinguished road
I just installed 2020 Tacoma TRD Offroad complete front suspension and they fit perfect. Bolted right up!
mykdee is offline   Reply With QuoteReply With Quote
Old 08-21-2020, 04:05 PM #8
Bluesky 07's Avatar
Bluesky 07's Avatar
Sweet, thanks.
Old 09-04-2020, 01:20 AM #9
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
This looks great! Did you run any spacers? How’s it been long term? Thanks!
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
3rd , coils , rear , shock , suspension
3rd Gen Tacoma suspension swap onto 4th Gen 4Runner bstave 4th Gen T4Rs 61 02-04-2024 11:11 PM
Tacoma Suspension Swap ARK_SWAMP_RIDER 4th Gen T4Rs 430 03-18-2021 05:49 PM
2016 Tacoma Bilstein Suspension Swap? blackfc3s 4th Gen T4Rs 2 05-10-2016 10:23 PM
Any interest in Tacoma suspension swap? gone_primal 4th Gen T4Rs 4 04-17-2015 11:18 PM
