Old 03-19-2019, 12:13 PM #16
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
The water pumps on these leak too...weep hole.
My 04 has a build date of 9/03 and had the pink SLL from day one.
Am using Zerex Asian formula now.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 05:52 PM #17
thewaydown thewaydown is offline
thewaydown is on a distinguished road
Originally Posted by mgbringo View Post
I just fixed mine. Tank was low and when I checked the radiator I could see red/pink staining in a couple of places on the engine side of the radiator. It was leaking but never saw any on the floor and didn't smell anything.
I ordered a new radiator, hoses, and thermostat from Rock Auto. I then drained radiator and filled with distilled water three times until drained water was almost clear. I drove it in between until it warmed up and thermostat opened.
I then filled with red pre-diluted anti freeze. That was a month ago now and it is fine now.
Red pre-diluted? Do you mean pink?
thewaydown is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 05:56 PM #18
Now I'm torn, again. I was ready to buy a couple gallons of the Pink for my 03, now i've just been told again (3rd time I've heard it) that red should go in mine.
Does anyone know the logic behind this? Is the engine material a different alloy than the later year 4th gens?
I don't want to test my already suspect head gasket.
Manufacturer date is 06/03 if that provides any info.
Old 03-19-2019, 05:58 PM #19
Hmm... Mine is 06/2003.
I wonder if they changed anything in those 3 months?
Old 03-19-2019, 06:11 PM #20
mgbringo mgbringo is offline
mgbringo is on a distinguished road
Diluted means it is already 50/50 with pure anti freeze and distilled water. I prefer using the concentrate and adding my own distilled water but couldn't find it in red. I did not try Toyota. I used Peak Final Charge Global. It is red and is pre-mixed.
mgbringo is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 06:37 PM #21
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
Yup.
Looks like mid year, that thread chaz added with the super old broken links had it.
The SLL seemed to have been added to reduce something or another...to pass some BS EPA crap?
Just use the Valvoline Zerex Asian stuff. Change it at 30k miles.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 03-19-2019, 10:48 PM #22
Oh, I know what diluted means. The way you worded it just sounded like you purchased the red toyota stuff pre-diluted 50/50, which I don't think exists.
Thanks though!
Old 03-19-2019, 10:54 PM #23
Yup.
Yeah, most likely. Didn't notice that thread he posted, still don't see it. Maybe he removed it.
I've seen a few people mention that zerex coolant. How does it compare? Is it more similar to pink or red?
Old 03-20-2019, 07:22 AM #24
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
If you have your owner's manual look in there, it will have the correct info for yours, they would have edited the manaul for the later year model when they changed to pink.
2004 Limited V8
Old 03-20-2019, 10:14 AM #25
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
pdf in this. From factory: Pink coolant in my 2003
chaz is offline   Reply With QuoteReply With Quote
Old 03-20-2019, 07:15 PM #26
Link to my new thread with borescope pics.
Borescope pics. Head gasket failure?
Old 03-22-2019, 02:59 PM #27
Originally Posted by chaz View Post
Just checked the manual and it says LLC. I read in tacomaworld and also toyotanation that LLC can cause the water pump seals to fail prematurely. Also that Pink isn't backwards compatible with "older" toyotas. Not sure what "older" is referring to. I think I might drain and flush both my 5vz-fe and the 4runner and replace both with the zerex stuff. I'll do this AFTER I figure out where this suspected leak is.
Old 03-22-2019, 09:01 PM #28
lightfreak lightfreak is offline
lightfreak will become famous soon enough lightfreak will become famous soon enough
Pink and RED are compatible, can mixed together and substitute one to replace the other as long as your Toyota originally came with one of them, there's a TSB stating such that's been posted here and elsewhere.
The Pink has a different anti-corrosion agent that gives it a longer drain interval.
2004 4Runner Limited V6 4WD ***SOLD***
385,000 Km
Titanium Metallic
Vehicles: '21 Highlander XSE V6 AWD | '21 Acura RDX SH-AWD Tech | '03 Honda CBR600F4i
lightfreak is offline   Reply With QuoteReply With Quote
Old 03-23-2019, 03:23 PM #29
2003-4x4runner's Avatar
2003-4x4runner 2003-4x4runner is offline
2003-4x4runner will become famous soon enough
My radiator was leaking at the bottom Right corner (passenger side).
2003 V6 BLACK SR5 4X4-Runner
OB #1334
https://www.instagram.com/ob_1334/?hl=en
Dad's Travel Service.
We drive around till we find it. No map's needed!
2003-4x4runner is offline   Reply With QuoteReply With Quote
Old 03-26-2019, 12:09 AM #30
Originally Posted by CookieRoe View Post
Go pink.
Have you checked the drivers side lower part of the radiator? Look there, that is where my coolant was leaking. I've been sweating profusely thinking my head gasket was starting to go, but low and behold, I only have to replace the radiator. (not fun, but loads better than having major engine repair). Anyway, 4th gens tend to leak from that location.
Good luck!
What brand radiator did you guys decide to purchase when replacing the old one?
4th , coolant , flush , put , red
New Radiator with Coolant Flush? Power Steering Fluid Flush, and Brake Fluid Flush? jdotlim 4th Gen T4Rs 4 09-17-2017 07:52 PM
red vs. pink coolant Herculean T4R 3rd gen T4Rs 1 12-22-2016 01:39 AM
pink coolant and green coolant Larry Maintenance/Detailing 30 11-17-2014 11:09 PM
Pink Milkshake question?? Trans flush? rmoore 3rd gen T4Rs 38 06-16-2012 09:15 PM
