Old 09-04-2019, 07:47 AM #16
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Originally Posted by blackmax View Post
Stranded. So my 2003 4Runner V6 wont turn over. Put the key in the ignition on the lights come on everything is perfectly normal turn the key absolutely nothing happens nothing. The battery is perfectly fine. There's no clicking no nothing just silence. This happened a few days ago and I had the car towed. As soon as they took it off the toe Truck 3 miles away and started right up again. It happened again two days ago and I let it cool off for 15 minutes and it started up so I assume this is a heat thing. Today however it happened and I'm let it sit for several hours now and it still will not turn.
Again it is NOT the battery. It is NOT the battery cables for connection to the terminals. There are no sounds or clicking noises whatsoever. This has only happened when the engine is warm so far. Actually hot. But the strange thing is that this time he engine is cooled off to the touch and still the problem persists. Has anyone ever heard of anything like this? I really haven't. I guess you could go down the heat soak to the starter road but I'm sure that's not yet. He's so at the solenoid but again it's cold now so that doesn't seem like it would be the cause. Ignition switch? I guess perhaps but what would the temperature of the engine have to do with that? Neutral safety switch? I guess it could be but I've tried jiggling the shifter trying to start it in neutral everything under the sun that doesn't seem to be. I'm stumped
Stranded over an hour from my house waiting for AAA now. Second tow in one week. I'm going to have to figure this out thanks for any help you can provide.
I replaced 4 starters in my 2005 V6 runner. OEM lasted 5 years. Rebuilt at top shop lasted one year. Bought a new starter - lased 4 years then failed.
Put a Quality in there now (with lifetime warrantee), and have a $67 battery in garage as a back up. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Captsolo is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 08:41 AM #17
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
I use this on my fuse and relay legs: https://www.amazon.com/Hosa-D5S-6-De...gateway&sr=8-6
Bought it after reading a long thread here about the transmission electrical connector pins corroding and breaking in place causing shifting harshness. I pulled every fuse and relay, sprayed them down and let it dry, then reinstalled.
waypoint is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 05:32 PM #18
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
Update - Fixed
Well this no start and even stalling on the freeway problem persisted for months. Stalled out on the freeway several times. Stalled while sitting at a stoplight several times. Really was a nightmare. Turns out it had nothing to do with the relay at all or the harness or wiring or anything like that.
So I took it over to a local mechanic to have new rotors and pads put on. I parked the truck gave him a key but told him that if it would not start he would have to pop the hood and tap on the EFI relay. He looked at me like I was crazy. I told him what had been going on and he said he would like that too. I came back after a couple hours and the job was done. He also handed me a little white I think 10-amp amp standard plug-in fuse that hat corrosion on both legs. It hadnot popped it just looked like it had seen better days. He said he replaced it no charge and thinks that might be my problem. Well, that was a month ago and since that time I have not had one issue. That was 100% for sure the problem. Simple $0.05 fuse. I really don't even know which one it was to be honest. It was one of the fuses inside the same fuse box where the EFI relay is housed.
white fuse in fusebox is the jumper fuse, that gives power to all the fuses.
10 amp fuses are red in color.
25amp fuse is close to clear, 20amp is yellow.
i would take all the fuses out and inspect it really good.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 09-26-2022, 09:10 PM #19
Pale Rider Pale Rider is offline
Pale Rider is on a distinguished road
Hi riceandpho,
I'm having similar issues to the OP and was wondering if you would mind clarifying your comment: "white fuse in fusebox is the jumper fuse, that gives power to all the fuses."
Where exactly is that jumper fuse?
Can you point it out from this site:
https://fuse-box.info/toyota/toyota-...uses-and-relay
2006 V6 SR5
Pale Rider is offline   Reply With QuoteReply With Quote
Old 09-26-2022, 10:21 PM #20
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
He means "short pin", #25
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 09-27-2022, 06:28 AM #21
Thanks!
But is that even a fuse? It doesn't show any amp value.
2006 V6 SR5
Old 09-27-2022, 08:23 AM #22
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
Update - Fixed
i was about to comment to change the fuses, i had replaced my whole engine and got the same thing no start, noise, click, nada. took me two days and i even called someone out to diagnose. said it was the ECU. my friend happen to come over that night started messing with the fuses, noticed the ECU one was a little corrodded, swapped it out and boom turned on like a charm. so even those little tiny fuses can cause issues if their dirty.
daprotege5 is offline   Reply With QuoteReply With Quote
Old 09-27-2022, 08:33 AM #23
jbtvt's Avatar
jbtvt's Avatar
Originally Posted by Pale Rider View Post
Thanks!
It's a jumper, makes a connection, not designed to blow. The Deoxit linked above is supposed to be good stuff, vintage electronics guys love it, or just clean anything suspect with steel wool and coat with dielectric grease on a qtip
Old 09-27-2022, 12:00 PM #24
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
My 2 cents FWIW since these same exact symptoms happened to me recently. Turned the key and everything looked normal but crickets. OP said his battery was fine, maybe so. My truck would start with a jump but die immediately until I finally thought to give it some gas right at startup. That kept it running long enough to drive home. Long story short, alternator was bad and the battery tested so low that the dealer checked to be sure their tester was working right. New alt and battery fixed the problem.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 09-27-2022, 12:22 PM #25
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Obviously, electrical problems can be abundant, but good info here. Thanks to all who contributed.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 09-29-2022, 08:44 AM #26
riceandpho's Avatar
riceandpho's Avatar
the short pin for the fuse box is a good place to remove for any work done to the truck that needs the battery disconnected, if you know what your doing, you don't need to disconnect the battery, but also verify that the short pin fuse really disconnect the power. I think you still get power to alternator and starter.
when replacing the starter and alternator, its good practice to remove the battery from the truck, you'll get more room and know that you don't have power to the truck.
anyone want to remove the short pin to verify? i got too much electronics to program again. at least my radio save my eq settings.
battery , engine , guess , happened , turn
Waiting for a tow truck. What's wrong with my 4runner? DanielW 4th Gen T4Rs 9 12-08-2015 10:30 PM
Absolutely no power! Rob503 Classic T4Rs 11 06-30-2013 12:59 AM
Waiting. Painful waiting. Durango24runner 5th gen T4Rs 1 06-23-2013 04:34 PM
Absolutely Puzzled mr280zxt 3rd gen T4Rs 12 03-27-2011 11:23 PM
Turn Key, Start Truck, processes? jabbajim Classic T4Rs 3 09-20-2010 08:32 PM
