Old 03-19-2019, 08:43 PM #1
Dirtrider216 Dirtrider216 is offline
Dirtrider216 will become famous soon enough
Trying to track down a rotational grinding noise
Like the title say, there’s a rotational grinding- like metal on metal grinding. I can only hear it at low speeds with the windows down but that doesn’t mean it’s gone at higher speeds, I’ve greased everything with a zerk and just all 4 brake pads replaced with rotors resurfaced by the dealership
It also goes away after driving in the rain while the car is still wet but once the car dries out and warms back up it’s back again.
Any ideas?
2006 limited v8 4wd
Toytec/ebiach 3” coilover lift with 1/2” top plate spacers, Jba high caster UCA’s, blistein 5100 rear shocks with toytec superflex hd springs, Cooper st max 255/80/17 with mb 352 in 17x9 -12 mm offset, auxbeam light bar in front bumper, custom retrofit headlights, SS brake lines, 5th gen brakes, custom rear storage box
Dirtrider216 is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 10:04 PM #2
lightfreak lightfreak is offline
lightfreak will become famous soon enough lightfreak will become famous soon enough
Check all brake dust shields and see if they’re touching the rotor ever so slightly? In rain the water will act like lubricant and the noise goes away.
2004 4Runner Limited V6 4WD ***SOLD***
385,000 Km
Titanium Metallic
Vehicles: '21 Highlander XSE V6 AWD | '21 Acura RDX SH-AWD Tech | '03 Honda CBR600F4i
lightfreak is offline   Reply With QuoteReply With Quote
Old 03-20-2019, 11:04 AM #3
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
I had a grinding noise on mine that turned out to be in the passenger rear e-brake assembly. One of the pins that has a spring around it had rusted enough to where the pressure of the spring had bent out the pin nearly straight causing it to contact the back on the flange on the axle. You way want to put your truck in gear up on jack stands and give it a listen. That is what I ended up doing.
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 03-20-2019, 12:10 PM #4
mliebal mliebal is offline
mliebal is an unknown quantity at this point
I had a emergency brake shoe retaining pin get bent and hit the hub that made noise.
mliebal is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 12:33 AM #5
HCWatson997's Avatar
HCWatson997 HCWatson997 is offline
Real Name: Cole
HCWatson997 will become famous soon enough
Real Name: Cole
Wheel bearing(s) maybe?
03 V8 2WD converted to 4x4 | 3/2” sus lift | 1” BL | 34” Falkens | first Coastal Offroad hybrid bumper | FiberwerX fenders | JBA UCAs | VVTI intake/fuel rail/TB swap | white/green cluster swap
HCWatson997 is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 10:12 AM #6
GA-v8 GA-v8 is offline
GA-v8 is on a distinguished road
Brakes (like mentioned above previously) or wheel bearings. My wheel bearing creaked at lower speeds, and especially when turning and placing a load on that side / bearing. Luckily, I had just bought my truck from CarMax, so they were able to replace it immediately.
But IMO, if its brakes, then it would sound worse when you are actually using the brakes. But if its while you're not using the breaks & happens under load (i.e. turning) then it's probably wheel bearings.
'07 v8 Limited
-2.5 inch OME coil lift - 1 inch stacker - Icon UCA's & ball joints - new LCA's - H9 light mod
GA-v8 is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 10:59 AM #7
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
Brake pad retainer clips have caused this for me.. check them all, dust shield, lazy caliper, wheel bearings.. thats about it..
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 05:34 PM #8
taxzz's Avatar
taxzz taxzz is offline
taxzz will become famous soon enough taxzz will become famous soon enough
taxzz's Avatar
My rotational grinding was the wheel hub bearing. I bought a new assembly for <$100 (http://tinyurl.com/yygycuba) with this one.
The way I confirmed which wheel it was by jacking up the front, then trying to 'shake the wheel' by pushing on the top, pulling on the bottom, and vice-versa.
The 'play' in this was incredibly small, and not much different between my fronts (I didn't have to check the back). I picked the one with 1-2mm of more play and replaced it with a few hours work in the driveway.
You can see how to check for play at 50 seconds in this video, YouTube.
I used the video above, and the one below to help me complete the job.
YouTube
2007 Limited V8 | Apache AX2 and Dobinson 3" lift
2004 Limited V8 | Dobinson IMS Long Travel 3″ lift w/ SPC UCAs | Yoko 35x12.5/17 | Rear Locker | Front LSD !!!!FOR SALE!!!!
2004 SR5 V6 | Sold
taxzz is offline   Reply With QuoteReply With Quote
Old 04-06-2019, 05:58 AM #9
Runn4est Runn4est is offline
Real Name: Steve
Runn4est is on a distinguished road
Real Name: Steve
What about the needle bearing? Check for play on your driver's side inner CV.
'15 Mag Gray LE -- TOTALED | '14 TE wheels - dipped black, Falken AT3W 285/70/17 | SPC Adjustable UCAs | Daystar 2.5/1.5 top spacer lift | RCI Fuel Tank Skid (Steel) | Shrockworks Step Sliders (trimmed LE Rocker Trim) | SR5 front end conversion
'08 BP Urban Runner -- 5100 fronts at .85 with Toytec 620# springs | SPC Adjustable UCAs | Plastics Guy Front Bump Stops | ICON VS 2.0 Rear with Toytec Superflex 2 inch springs | RCI Transition, Front and Transmission Steel Skid | LT275/65/18 Falken Wildpeak A/T3W | 1.25 inch wheels spacers
www.4runnerfamily.com | IG: Runn4est
Runn4est is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 12:49 AM #10
*Update*
Took the car to 4wheel parts about a month ago for them to install SS braided brake lines and new (from Napa) CV axles since my passenger boot was torn and one of those seems to have fixed the issue of the grinding noise
2006 limited v8 4wd
Old 09-10-2019, 08:06 PM #11
November Sun November Sun is offline
November Sun is on a distinguished road
I had the same problem, it was my hub bearing
November Sun is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 08:59 AM #12
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
i had that from a section of my exhaust hitting my rear axle when it rotted off
check cat shields too
hinmo24t is offline   Reply With QuoteReply With Quote
back , car , it’s , metal , speeds
Intermittent Rotational Noise....any ideas? Video with sound Boconnor303 4th Gen T4Rs 4 12-08-2017 09:34 AM
Rotational Mystery Noise RicMan 3rd gen T4Rs 4 09-21-2017 09:19 PM
HELP, rotational/humming noise at all speeds. itschrisb 3rd gen T4Rs 13 10-11-2016 05:41 PM
3VZE Mystery Rotational Noise brettniles Classic T4Rs 10 02-05-2016 06:14 PM
