Old 11-11-2019, 04:06 PM #1
Rancho5 Rancho5 is offline
Rancho5 is on a distinguished road
3rd Gen guy needs 4th Gen help with ABS Brake unit
From my understanding my 2002 3rd Gen shares a similar ABS/Master Cylinder with your 4th Gens.
Symptoms: Prolonged motor cycling-whirring sound upon startup. Squishy brake pedal and rig lurches forward when almost at a stop, while making motor-whirring sounds.
Physically inspected all connection harnesses at the ABS unit as well as speed sensors at each wheel and they seem to be fine. No breaks etc.
Picked up a complete ABS/Master Cylinder unit from a local guy for $150 so I'm going to swap it out to see if it helps.
When I changed my brake fluid last year I just bled the system old school. I had no idea that I needed to trip the ABS actuators so it's probably why my brake pedal is still squishy.
Is there a less expensive option to trip that ABS actuator, to 100% bleed, other than purchasing a scanner with ABS auto-bleed option? (Which is like $200)
Also I read something about zero pint calibration and I'm wondering what that is and if I need to do it.
Any help appreciated
02 Thundercloud Sport, 155k.
Rancho5 is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 08:06 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I have read that if you do several "panic" stops from fairly moderate speed that will trigger the ABS which will trigger the actuator to help get any air out of the ABS system/actuator, so I would do that a few times and then bleed the brakes normally, then rinse and repeat until it seems that you got all the air out/the pedal firms up.
Of course do the panic stops on a seldom used road where there's little to no traffic!!
2004 Limited V8
Old 11-12-2019, 12:22 PM #3
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
It is my understanding that you would only need control of the solenoids if you replace the cylinder and don't bench bleed first prior to install. I bled my brakes a few months back the OG way, and I have had no issues. To me, it sounds like the seal on the piston in your master cylinder may be failing, and you're losing brake pressure as a result. Did you have the same symptoms prior to flushing?
As to your question on zero point calibration: unless you replace an electrical component of the ABS system (including the cylinder, I'm assuming) your ABS computer will see this and throw out a traction control light, which you would then need to calibrate to correct. Even when tripped, the brake system on 4th gens still works as normal minus ABS. So I don't really think this is your problem
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 01:54 PM #4
Yeah, that's what I'm thinking. And yes, it's been doing this for a quite a while and even prior to my flushing and replacing the brake fluid.
I'll have to do some research on how to zero point reset an 02.
abs , brake , gen , squishy , unit
Installing aftermarket head unit- utilize JBL or use head unit amp nytosc 4th Gen T4Rs 3 07-10-2017 08:43 PM
Sporadic master brake abs booster unit failure Starman52 4th Gen T4Rs 2 05-05-2017 06:33 PM
Swap A/C unit for Climate Control Unit? arzipper 3rd gen T4Rs 0 05-28-2015 10:55 AM
Want to purchase a used Nav Unit in my 06 4runner. What Unit do I need Please help demar002 Engines / Suspension / Wheels / Tires / Audio / Accessories 9 09-04-2009 03:48 AM
Convert JBL Head unit to Scion Unit ttman Engines / Suspension / Wheels / Tires / Audio / Accessories 9 08-19-2008 05:48 PM
