Old 03-26-2019, 01:44 PM #16
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Originally Posted by Mike07SE View Post
Fix???
I just gutted the PB assembly to eliminate possibilities. At the time in that video I was running 5th gen rotors and learned that the hub diameter is not quite the same as the 4th (tapered or something like that), so in theory the rotor is not spinning true on the hub. This would also explain why - like you - when I would take the wheel off the issue would go away.
I've since gone back to 4th gen rotors in the rear. In the meantime I haven't since put it back together - more out of frustration of the hassle of it. I'll get to it soon as the weather warms up.
I'm investigating a possible alternative of adapting a combination brake caliper to use in the rear. Wilwood makes one where the brake cable pulls a lever on the back of the piston to engage e-brake.
So answer me this....should I be able to run 4th gen rotors on the rear, and 5th gen calipers?
I'm definitely not going to do any additional brake modification though. I have already spent a fortune on this stuff and I was honestly just looking for a replacement and not necessarily an upgrade. I have seen these style calipers before but I'm honestly not that interested.
I definitely did notice that it seemed like the rotor (and whole brake assembly) was going up and down (VERY SLIGHTLY) and not completely centered on the studs when I took the wheel off. The clicking was going on during this time too.
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 03-26-2019, 05:38 PM #17
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE will become famous soon enough
Mike07SE's Avatar
Originally Posted by inscarguy View Post
My 5th gen upgrade works fine.
Most seem OK. Not everyone is lucky.
Sent from my Pixel 2 using Tapatalk
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
Mike07SE is offline   Reply With QuoteReply With Quote
Old 03-26-2019, 05:44 PM #18
Mike07SE's Avatar
Mike07SE's Avatar
Calipers should be fine. It's the center bore of the rotor that's the issue.
I understand. I'm just investigating other possibilities.
All the same for me. It wasn't until the rotor was off that all noise was gone. It was with the wheel on that this was the result. Long story short this was costly for me as well as I thought I had a busted diff and had it rebuilt.
Old 03-26-2019, 05:59 PM #19
99Runnr 99Runnr is offline
99Runnr has a little shameless behaviour in the past
I am using 4th gen rear rotors with 5th gen rear calipers. 110% bolt up, no trimming, no modification necessary.
99Runnr is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 10:15 AM #20
robaroni's Avatar
robaroni robaroni is offline
Real Name: Rob
robaroni is on a distinguished road
robaroni's Avatar
Real Name: Rob
When I upgraded to 5th Gen set up I stuck with 4th gen rotors in the back. According to the write up I followed the 5th gen rotors would not fit in the back.
2006 4Runner SR5 V6 Galactic Grey
Bilstein 5100's with Moog V8 springs all around * BF Goodrich All-Terrain T/A KO2 285/70-17 * 1.5" Hubcentric Wheel Spacers Front and Back * WeatherTech Mats and Cargo Liner * Pioneer AVH-X3600BHS with JVC CSV Series Speakers All Around * Satoshi Grille * LED Interior Lighting * Lots of PlastiDip * RCI Front Skid Plate * Custom Front Bumper by HotMetalFabs * Silver Suicide UCA's * Next up - Custom Rock Sliders * Roof Rack!
robaroni is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 10:47 AM #21
Real Name: Michael
Real Name: Michael
I remember reading conflicting reports so I wasn't sure and figured oh well I'll give it a shot....didn't work though
I ended up swapping on the old 4th gen rotors and adjusting the e-brake shoes in all the way on both sides and that fixed it. So now I have 2 rotors for a 5th gen that have scratches from install that are worthless to me. You think I can return them or nah?
Old 03-27-2019, 10:48 AM #22
Real Name: Michael
Real Name: Michael
All fixed now for me, I put on the old 4th gen rotors and adjusted the e-brakes all the way in on both sides and there is no noise or movement
Old 03-27-2019, 10:52 AM #23
Real Name: Michael
Real Name: Michael
Moral of the story for anyone doing 5th gen brake swap....DO NOT USE 5TH GEN REAR ROTORS....they don't center up correctly on the axle center bore(there's about 2mm of slop)...also make sure that you pay very close attention to the dust shield on the front calipers and that the e-brake shoes are not hung up on your rotor before you try and remove the rear rotors. You will bend the pins and have a nightmare trying to re-do the assembly.
Thanks to all for the input and ideas
Old 03-28-2019, 06:22 AM #24
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Glad you solved the problem! I had the following typed yesterday morning, but for some reason it didn’t post, and I never came back until today so I didn’t notice.
This may not help with the clicking, but with regard to the rotors... after much research I discovered that the 5th gen calipers and pads work fine with the 4th gen rotors. In fact, there is no advantage to using the 5th gen rotors anyway, since they are the same dimensionally as the 4th, other than the center bore being different. So, when I ordered my new Powerstop brakes, I bought everything separate so I could customize it the way I wanted. I bought the z34 extreme towing pads and rotors for 4th gen, then bought the 5th gen calipers. Everything went together perfectly. Well, except for the parking brakes, but I was missing ALL of the internal components when I bought the truck, so that made sourcing components and getting them to work a bit challenging!
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
brakes , caliper , rear , side , time
Sunroof swap issue. utekineir 3rd gen T4Rs 4 03-22-2017 07:15 PM
Rear brake issue WallyWest 3rd gen T4Rs 2 05-31-2015 04:02 PM
Rear Brake issue? ghs215 4th Gen T4Rs 16 11-24-2014 07:25 AM
Rear Brake Drum Sticking Issue chris360hawks 3rd gen T4Rs 3 11-13-2011 01:42 PM
Rear rotor swap, parking brake stuck ? project-roc 4th Gen T4Rs 2 09-08-2011 07:01 AM
