Old 03-26-2019, 09:55 PM #1
mphillips_90's Avatar
mphillips_90 mphillips_90 is offline
mphillips_90 is on a distinguished road
V8 4wd Tcase Actuator Motor Part Number???
So hurricane florence ruined my 4wd. In order to get back into Wilmington to start helping people out, I had to drive thru a lot of flooded streets which allowed water to get into my actuator thru the crack vent hose that I had no idea about.
Due to this the 4wd actuator stopped working. Ive pulled it apart, got everything loose, gears spin freely and the motor itself works when I send it power. As soon as I put the first gear on it, the motor gets locked up.
My only guess is that the motor is weak. Does anyone have the actual part number for the dc motor? Or does someone believe it could be something else?
mphillips_90 is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 01:20 PM #2
L8Shift's Avatar
L8Shift L8Shift is offline
L8Shift will become famous soon enough L8Shift will become famous soon enough
L8Shift's Avatar
I believe this is the whole assembly, Actuator Assembly Trans - Toyota (36410-60093) | Conicelli Toyota of Conshohock
36410-60093
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
L8Shift is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 01:54 PM #3
djpope09 djpope09 is offline
djpope09 will become famous soon enough
Originally Posted by L8Shift View Post
3641060093 Toyota ACTUATOR ASSY, TRANSFER SHIFT Price: 526.68$, Weight: 2.173kg - PartSouq - Auto Parts Around the World
This place has it for about half the price.
Are these the same for both the 5 speed transmission and 4 speed that was mated to the 03 and 04 V6? I was looking at that part number for my 04 V6 and now I'm thinking it might not be the correct part for me.
djpope09 is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 03:33 PM #4
Brian3676 Brian3676 is offline
Brian3676 will become famous soon enough
Just buy the Aisin one off Rockauto.com. Its literally the exact same one that you get from Toyota just not in a Toyota box. Aisin is the the OEM manufacture. I got mine from RockAuto. Install is pretty easy. maybe 4 hours if you know how to turn a wrench. Drop the T case, split it, R&R the actuator and put it back together.
Brian3676 is offline   Reply With QuoteReply With Quote
Old 03-27-2019, 06:47 PM #5
Yeah $480 is even better. I would buy that one too.
Old 03-28-2019, 12:19 AM #6
I just hate going thru the big process of dropping the tcase and splitting it when the 4lo function is still operable.
Any have an old sitting around with a working actuator motor they’d be willing to part with?
Old 03-28-2019, 12:14 PM #7
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
Is the V8 and the V6 the same part? If so, how? Everywhere I look the numbers are the same.
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 03-28-2019, 01:58 PM #8
That's a good point. If only 4lo or 4hi isn't working, could you just replace the motor?
AISIN SAT017 is the part on RockAuto. $164.
Old 03-28-2019, 02:00 PM #9
I'm seeing the same thing. They all have the same Tcase actuator number.
If all the actuator is doing is selecting 4WD then it should work for both the 4 speed and 5 speed transmission.
Old 03-28-2019, 04:31 PM #10
L8Shift's Avatar
L8Shift's Avatar
Cool, I was just getting the part number for OP, as requested...
I hope not to need one.. at any price..
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
Old 03-29-2019, 11:44 AM #11
How does that work if the v8 is full time fwd and the 6 is selectable.
2005 4Runner SE V8
Old 03-29-2019, 03:24 PM #12
That is a great question. Maybe 2Hi is locked out on the V8 since there is no selector for it on the dash? It would be cheaper for Toyota to make the parts the same and have the switch set up so 2Hi can't be selected.
Looking at RockAuto, I see these options for the trucks:
V8: Aisin SAT003
V8: Standard Motor Products J78004
V6: Standard Motor Products J78004
I don't know why the SMP products are the same, but Aisin SAT003 isn't listed for the V6. If I ever replace mine, I'll call my local dealership first and have them verify the correct part number for my VIN.
Old 03-29-2019, 04:00 PM #13
I wish there was a way to confirm this.. Ive looked at the dealer parts websites and cross referenced the part numbers and they all appear to be the same. But I can see your explanation for the switch being possible. It would be like the v6 only ever switching from 4hi to 4lo.
2005 4Runner SE V8
Old 03-29-2019, 06:50 PM #14
So what Im seeing is that theres really no way to just purchase the DC motor.
Anyone got a spare??
Old 03-29-2019, 07:56 PM #15
Went and took a little video of the problem. When the gear is pressed in all the way it locks up. in the video, my finger is just helping it stay in position then allowing it to fall a little so it can spin. Ignore all the goop, its a lot of white lithium grease to try and get it going.
YouTube
4wd , actuator , motor , number , part
Part number for door actuator? Riser 5th gen T4Rs 6 03-22-2018 12:51 PM
Can't find a part number on a bolt, dealer part guy was an idiot yota-runner 3rd gen T4Rs 8 02-02-2016 08:00 AM
2nd gen 4x4 - front actuator wire part number ltsr Classic T4Rs 4 01-15-2015 04:21 AM
Tcase / front diff bangs and clunks? wont engage? Bad actuator? Highlex 4th Gen T4Rs 3 12-10-2014 09:53 AM
3rd gen items: Differential parts, motor mounts, tcase seals, etc clemson4r For Sale: T4R Items 7 05-12-2014 06:33 PM
