Old 04-09-2019, 04:43 PM #16
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Originally Posted by azgold View Post
You wouldnt have these issues, had you just gone with a Toyota battery
ahhhh...you're one of THOSE guys...
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 04-09-2019, 06:33 PM #17
Rodtheviking's Avatar
Rodtheviking Rodtheviking is offline
Real Name: Chris
Rodtheviking will become famous soon enough
Real Name: Chris
I didn't want one.
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
Rodtheviking is offline   Reply With QuoteReply With Quote
Old 04-11-2019, 01:31 AM #18
shmabs shmabs is offline
shmabs is on a distinguished road
To those using the GM diode and an AGM.
What are you seeing for running voltage, and how are you measuring it?
shmabs is offline   Reply With QuoteReply With Quote
Old 04-11-2019, 08:47 AM #19
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
If I'm remembering correctly - High 14.x's cold start, low 14.x's on both batteries when connected warm and cruising highway speed. I have a dual voltmeter installed in my center console to monitor but you could also use things like scanguage or a cheap cig lighter plug in, or OBD scan tool - bluetooth/wifi dongle with torque lite app.
blackoutt is offline   Reply With QuoteReply With Quote
Old 04-12-2019, 12:05 PM #20
Thanks for the reply!
I installed an AGM battery and the GM diode and was seeing 15 volts occasionally (via scan gauge), which seemed awful high. I went back to the regular 7.5 amp fuse, and I'm seeing 13.8-14.0. Does anyone have any documentation on the charge profile that AGM's require? I've heard they require more, especially optimas. My 4runner isn't a daily driver, so I'll have to double check my numbers again. Most of the online charts I'm seeing show that more than 14 is required at 77 degrees, maybe I will have to swap that diode back in. Is anyone seeing and negatives to a standing voltage of that high?
Old 04-13-2019, 11:31 AM #21
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
im a short trip only driver, my 6-7 year old battery wasnt being maintained past 12.1(thats only around 25% ) should be at least 12.6 . i just purchased a new AGM battery just in case, so cant really help ya but in my search ive read that different vec. make & years need different diodes, so i skipped on the GM diode & went with the DIRTY PARTS piece since it states for 4r & fj & should keep the charge at the magic # of about 14.7 for an AGM battery, right now without it i only get 14.0 which ive read isnt enough to keep it fully charged. recieving it on friday so will see if it works
chaz is offline   Reply With QuoteReply With Quote
Old 04-14-2019, 12:34 PM #22
Dirtrider216 Dirtrider216 is offline
Dirtrider216 will become famous soon enough
Just got my GM diode in the mail yesterday, hopefully I’ll put it in today
As it stands
Overnight my battery voltage in the am is 13.8 and it drops to 13.1 within 10 minutes unless I jump on the interstate
2006 limited v8 4wd
Toytec/ebiach 3” coilover lift with 1/2” top plate spacers, Jba high caster UCA’s, blistein 5100 rear shocks with toytec superflex hd springs, Cooper st max 255/80/17 with mb 352 in 17x9 -12 mm offset, auxbeam light bar in front bumper, custom retrofit headlights, SS brake lines, 5th gen brakes, custom rear storage box
Dirtrider216 is offline   Reply With QuoteReply With Quote
Old 04-14-2019, 01:26 PM #23
chaz's Avatar
chaz's Avatar
anybody read the thread in the 5th gen section about these things as possible fire hazards? one maker says his are the only safe ones made.
Old 04-14-2019, 01:42 PM #24
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Maybe you could post a link to where you read this so others won't have to go looking for it?
2004 Limited V8
Old 04-14-2019, 03:34 PM #25
chaz's Avatar
chaz's Avatar
"Voltage Booster" for 31M AGM Battery
Old 10-16-2019, 02:47 PM #26
BendRunner BendRunner is offline
BendRunner will become famous soon enough BendRunner will become famous soon enough
do you know if the Arclight works with the 4th gen?
BendRunner is offline   Reply With QuoteReply With Quote
alternator , battery , charging , driving , voltage
Optima yellow top or.... 4flyer 3rd gen T4Rs 6 10-03-2016 10:07 PM
Brand New Optima Yellow Top D35 nutter For Sale: Non-T4R Items 3 03-22-2016 04:53 PM
Optima yellow top D35 alc9020 5th gen T4Rs 1 05-13-2015 10:06 PM
Yellow top Optima battery D35 or 34? EEtM33t 4th Gen T4Rs 35 12-08-2012 01:00 PM
Just installed Optima Yellow Top mtnracer Engines / Suspension / Wheels / Tires / Audio / Accessories 5 10-07-2006 01:11 AM
