04-05-2019, 09:54 AM
#16
Same here on the Bilstein 5100 setup. I used OEM springs (purchased from a v8 owner on here) and the same rear springs.
Everything bolted right in and rides wonderful.
Metramm
2006 4Runner Limited 4x4 v6
241,000 miles and counting!
04-05-2019, 10:11 AM
#17
bilstein does say rear 5100s are for 1+ lift springs but as long as you dont offroad hard id say you will be fine, if in doubt, either get the 4600 (which are about the same valveing as 5100) or use a rear spacer for stock coils & 5100s or get FJ rear coils for the 5100.
04-09-2019, 01:45 PM
#18
Real Name: James
Real Name: James
interesting
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
04-15-2019, 01:11 AM
#19
Everything is done.
Full maintenance done also
Replace:
rear shocks and front struts.
Struts mounts
Inner and outter tie rods.
Lower control arms
Upper control arms
Sway bar bushings
Sway bar end links
Front and rear rotors and pads (OEM)
Water pump (OEM)
Thermostat
Radiator cap
Belt
Upper and lower coolant hose
Spark plugs
Cabin filter
Engine filter
Transmission fluid and filter
Engine oil
Brake fluid flush
Diff fluid
Power steering fluid
Every weather strip molding outside of the car
Truck feels great. These bilstiens are not harsh at all. Very good ride with excellent rebound control unlike the garbage kyb.
04-15-2019, 11:45 AM
#20
garbage kyb's? never heard that before, most the members on here that use them & commented said they were a good stock type replacement shock & kyb in general get good reviews. you cant compare stock type shocks to upgraded bilsteins that cost twice as much. & if you do a search, theres are quite a few people that say the 5100s are a stiff/harsh ride... it all comes down to personal preference & what the vehicle will be used for.
sounds like you had a defective set if they leaked at 9000 miles, but thats what warranties are for.
i plan to use the kyb struts & shocks for a budget stock replacement to eliminate the x-reas in my on road only 4runner & have no reservations on using the kyb brand.
04-15-2019, 12:34 PM
#21
4runners don’t have struts
pet every dog
04-15-2019, 05:42 PM
#22
Real Name: James
Real Name: James
My X-REAS is blown, was gonna upgrade, but now I might have a deal pending, virtually giving away stock coilovers, can source rear springs cheap just about everywhere. So I will spend the $$ saved on other Runner fixes, instead, and maybe lift, etc. in a few years, we'll see maybe sooner than later.
Regards, sport2004
04-16-2019, 08:39 AM
#23
hmm, you sure about that?
04-16-2019, 08:50 AM
#24
04-16-2019, 10:47 PM
#25
yes. do you know what a strut is?
pet every dog
04-17-2019, 09:35 AM
#26
just bustin your balls. i think your personality is funny on here.
04-17-2019, 03:43 PM
#27
I’m glad somebody does.
pet every dog
