Old 04-05-2019, 09:54 AM #16
metramm metramm is offline
metramm will become famous soon enough
Same here on the Bilstein 5100 setup. I used OEM springs (purchased from a v8 owner on here) and the same rear springs.
Everything bolted right in and rides wonderful.
Metramm
2006 4Runner Limited 4x4 v6
241,000 miles and counting!
metramm is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 10:11 AM #17
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
bilstein does say rear 5100s are for 1+ lift springs but as long as you dont offroad hard id say you will be fine, if in doubt, either get the 4600 (which are about the same valveing as 5100) or use a rear spacer for stock coils & 5100s or get FJ rear coils for the 5100.
chaz is offline   Reply With QuoteReply With Quote
Old 04-09-2019, 01:45 PM #18
sport2004's Avatar
sport2004 sport2004 is offline
Real Name: James
sport2004 is on a distinguished road
sport2004's Avatar
Real Name: James
interesting
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
sport2004 is offline   Reply With QuoteReply With Quote
Old 04-15-2019, 01:11 AM #19
niz55 niz55 is offline
niz55 is on a distinguished road
Everything is done.
Full maintenance done also
Replace:
rear shocks and front struts.
Struts mounts
Inner and outter tie rods.
Lower control arms
Upper control arms
Sway bar bushings
Sway bar end links
Front and rear rotors and pads (OEM)
Water pump (OEM)
Thermostat
Radiator cap
Belt
Upper and lower coolant hose
Spark plugs
Cabin filter
Engine filter
Transmission fluid and filter
Engine oil
Brake fluid flush
Diff fluid
Power steering fluid
Every weather strip molding outside of the car
Truck feels great. These bilstiens are not harsh at all. Very good ride with excellent rebound control unlike the garbage kyb.
niz55 is offline   Reply With QuoteReply With Quote
Old 04-15-2019, 11:45 AM #20
garbage kyb's? never heard that before, most the members on here that use them & commented said they were a good stock type replacement shock & kyb in general get good reviews. you cant compare stock type shocks to upgraded bilsteins that cost twice as much. & if you do a search, theres are quite a few people that say the 5100s are a stiff/harsh ride... it all comes down to personal preference & what the vehicle will be used for.
sounds like you had a defective set if they leaked at 9000 miles, but thats what warranties are for.
i plan to use the kyb struts & shocks for a budget stock replacement to eliminate the x-reas in my on road only 4runner & have no reservations on using the kyb brand.
Old 04-15-2019, 12:34 PM #21
grave's Avatar
grave grave is offline
grave has a spectacular aura about grave has a spectacular aura about
grave's Avatar
4runners don’t have struts
pet every dog
grave is offline   Reply With QuoteReply With Quote
Old 04-15-2019, 05:42 PM #22
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
My X-REAS is blown, was gonna upgrade, but now I might have a deal pending, virtually giving away stock coilovers, can source rear springs cheap just about everywhere. So I will spend the $$ saved on other Runner fixes, instead, and maybe lift, etc. in a few years, we'll see maybe sooner than later.
Regards, sport2004
Old 04-16-2019, 08:39 AM #23
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
hmm, you sure about that?
hinmo24t is offline   Reply With QuoteReply With Quote
Old 04-16-2019, 08:50 AM #24
chaz's Avatar
chaz's Avatar
Shocks vs Struts vs Coilovers – Shock Surplus Shocks vs. Struts | 1A Auto
Old 04-16-2019, 10:47 PM #25
grave's Avatar
grave's Avatar
yes. do you know what a strut is?
pet every dog
Old 04-17-2019, 09:35 AM #26
just bustin your balls. i think your personality is funny on here.
Old 04-17-2019, 03:43 PM #27
grave's Avatar
grave's Avatar
I’m glad somebody does.
pet every dog
front , kyb , oem , springs , struts
2015 TRDP Shocks, OME Old Man Emu Shocks, Sway-a-way Rear Springs - Central MO - $350 Ammomac For Sale: Suspension/Wheels/Tires 0 09-07-2018 04:43 PM
FS: 5th Gen (2016 Trail) Front Coilover Shocks & Rear Shocks/Springs $175, West LA rgoodman00 For Sale: Suspension/Wheels/Tires 3 01-28-2016 03:22 PM
FS: FJ Swap Stuff Shocks Springs and More Shocks! Boulder, CO DonP4Runner For Sale: Suspension/Wheels/Tires 13 02-18-2015 09:42 AM
: 3rd G FS99 Tall Springs F+R and Front Shocks, 4R Wheels and tires, 97 springs SoCal mydogsmonkey For Sale: Suspension/Wheels/Tires 1 07-11-2014 10:36 AM
'99 front springs/shocks w/spacer & rear springs Full_Throttle For Sale: Suspension/Wheels/Tires 10 09-18-2012 11:57 PM
