Originally Posted by Hiker865
Curious why everyone is changing transmission fluid so often?
The manual in my 2006 doesn't recommend it and having spoke with two dealerships while getting oil changes....both said they don't advise doing it unless the transmission starts to have issues. 04-08 comes with lifetime fluid and only needs to be checked for correct fluid level.
It's telling that you don't know much about and do your own mechanical work, first by you saying that you get the dealer to change your oil, one of the most simplest thing to do on these T4Rs, second is if you knew even a little bit about mechanics you would known that there's no such thing as "Lifetime Fluid", especially when it comes to lubricants, lubicants lose their viscosity, cleaning, cooling and lubrication properties after being used for long perioeds of time, e.g. mileage, a good expample is engine oil, transmission fluid is the same but does last much longer, but should be changed somewhere between 70,000 and 100,000 miles, no matter what name Toyota calls it.
Just think about it, how long is the common warranty in 2006 on Toyotas, 36 months/36,000 miles, so this is telling me that Toyota says that's the life of most of the vehicle since thery're no longer willing to fix it after that time/mileage period, so lets just say that's the half-life giving Toyota the benefit of doubt, so that tells me around 72,000 miles is what Toyota at the most considers to be "Lifetime", that being said if you look in not the owner manual but in the "Scheduled Maintenance Guide" you will see that Toyota does recommend if you use yor T4R to tow that the transmission fluid should be changed at 60,000 miles, now this fact tells me that Toyota does know that the fluid will degrade and even faster if under more stress than normal driving conditions but it still degrades under normal driving conditions only a little slower.
Now we all know that Toyota vehciles last much, much longer than the warranty period and even many, many times that period... but I can tell you if you asked a Toyota engineer how long that "Lifetime Fluid" truely lasts and he answered honestly it would be around 100,000 miles or less, at that mileage is the fluid still oily and slippery(?), yes it is and it's still better than water but it has lost much of it's properties compared to new fluid, so now knowing all of this you tell me which would you rather have in your $3000 (not including labor) transmission??
I'm not trying to talk down to you for not knowing about mechanics and or doing your own maintenance because I know most people don't have the mechanical abilites and or the tools, but instead just trying to educate you a little bit on the true lifetime of mechanical devices and fluid properties
