04-05-2019, 07:06 PM
Cost of professional paint job?
What's the approximate cost to repaint a 4th Gen, assuming no body work is necessary other than the usual surface prep? Same paint and color as OEM, and how much extra to change color?
Good quality, solid work for a daily driver, not a show car.
04-05-2019, 09:10 PM
It's probably best to actually call up some local and regional places for quotes - something local and something in the nearest major city if you aren't in one already.. Labor rates are massively different across the country. No point in getting your hopes up for something you can't actually find in your area.
That being said- To my knowledge there's a lot of different options for how thorough of a job you get, which can make prices be from $500 to over $3000. I have a coworker who repainted his 2005 GTO the same factory red it already was, but made a couple of pieces black, like the roof and some trim pieces. They did a full teardown, painted the parts off the car, and reassembled with mostly new weatherstripping for like $3500. His isn't show quality, but he did thoroughly vet the shop he chose, and paid more for them based on the cars he personally saw.
04-06-2019, 08:39 AM
Real Name: Armando
Real Name: Armando
I got a quote from Maaco for $2500 to paint the entire vehicle. This is in the Austin area. My 4runner has really bad clear coat damage on the fenders, side mirrors, roof and grill. I thought that was a decent price. I'll also get another quote from an independent shop which i talked to over the phone and he give me a price estimate of $2500-3000.
I will pull the trigger on a new paint job(keeping it the same silver metallic color) maybe this fall or early Jan/Feb 2020. I've already spent $700 on tires/$1500 new suspension/$400 HID retrofit. I've trying to get all dressed up and pretty for our 15th year anniversary coming up in Feb 2020.
Original Owner- 2005 Silver Metallic Sport Edition 4WD V6
04-06-2019, 09:24 AM
consider a full body wrap, its around 4k to 5k, its the same for paint job, atleast over here in cali.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
04-06-2019, 10:20 AM
Wraps are cool, but I’d never spend that much when you have the option of a traditional paint job for around the same money. Wraps just don’t have the longevity of a good paint job. Most people I know that have gone with wraps, did so to change the appearance with a different color or graphics, while preserving the original paint for resale. That’s the only reason I’d personally consider wrap.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
04-06-2019, 10:30 AM
I personally love the time-tested, worn paint look that you see on many survivior vehicles. That worn paint is just your 4runner aging gracefully!
*2017 4R TRD Pro, 01H5 Cement w/ Shrockworks dimpled tread plate sliders, Moroso oil catch-can, black powder-coated roof rails. (summer runner).
*2005 4R Sport Edition w/ Bilstein 5100's, Gen-5 brake upgrade, K&N cold air intake, cabin air intake mod, Falken Wildpeak AT3. (winter runner).
*1965 Pontiac GTO convertible, 4-speed w/tri-power, PHS documented. (born in Freemont CA).
*1962 Chevrolet C-10 (short-step) pickup, 4-speed, survivor. (born in Oakland CA).
01-19-2022, 12:12 PM
I only paid $4500 for my 4runner and really want to repaint it.
But say at $2500, its more than half what I paid for her. So can't justify it.
If wraps were cheaper I'd consider it. But I've seen matte wraps go for $6k. Ouch.
03-25-2022, 04:11 PM
I also live in the Austin area. What did you end up doing? I am looking to get my V8 lifted and some body armor replaced.
04-01-2022, 06:45 AM
Real Name: Armando
Real Name: Armando
@ Tigersquid
It got a complete new paint job. I got rear ended, so took it to Maaco and they did the repair and paint job. Very happy with the results. This happened in Nov 2019.
04-01-2022, 08:20 AM
It really depends on how picky you are. I spray my own things, in my driveway, with no booth, and can tell you that I would never be able to live with the quality of work Maco does over here in the NC area.
Just as an example.. half way decent material alone (some primer, base coat, clear coat) to paint the 4runner will run in upwards of $1500-2000. Higher quality paints/clears will run even more than that. That goes to show the quality of material you are getting at Maco for the money they charge.
For reference.. a good body shop will charge you no less than $5000 on the low, LOW end to do a full body spray in the same color. Realistically, for "good" work, you're probably looking at $7-9k. Can it be done cheaper and still have decent results for a 20 year old daily driven SUV? Absolutely it can, we just have to be realistic about the quality and expectation.
Also, when people say "no body work" ... any car that has seen a few years of life on the street will have dings and dents and scratches. Just because you aren't replacing body panels doesn't mean there isn't any bodyfiller/sanding/prepping involved, which takes a lot of time to do right. Places like Maco will literally paint over whatever is in place for the most part, and some people are perfectly fine with that. I have certainly done it on my vehicles.
For color change, the only time this will play a major difference in cost is if you want to do it the correct way and also paint the jambs and all other none-readily visible areas like under the hood and trunk. If you're ok with the rig being blue on the outside, but having white door jambs and fender aprons when you open it up it shouldn't cost you any more to do, but ultimately will look super tacky.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
01-11-2024, 05:17 PM
Real Name: Jeffrey Quickle
You would only have about $300 - $400 in a wrap if you did it yourself. Anyone can wrap a car. I wrapped my Lexus IS 250 by myself and it turned out great. Watched a lot of videos, took my time only doing one or two panels each day and I used Avery Supreme gloss black. Avery is so easy to work with. All you got to buy is the vinyl and to make it easier you can get someone to help you with it. The hardest part for me or the part I made some mistakes with was the Trimming. If I did not point out my mistakes to people they would never notice it.
01-14-2024, 11:03 PM
i looked into this over the summer and go quoted 2700 -3500
03-14-2024, 09:17 AM
It's amazing how prices can vary depending on where you are located. I've heard similar stories from friends who got quotes ranging from surprisingly low to shockingly high. Your coworker's experience sounds pretty thorough and well worth the investment. It's always reassuring to hear about someone who did their homework and got a decent job done. It's definitely a reminder that quality often comes with a price tag. I recently joined this forum and saw a thread about make 1000 a mont. It's intriguing, isn't it? The idea of making an extra grand a month sounds appealing, but I'm still trying to figure out what's feasible for me.
03-14-2024, 01:16 PM
Real Name: William Teichroeb
Just thought I'd throw in my recent experience here. I had a new paint job through insurance (was vandalism while my vehicle was parking in a lot). The approved shop repainted everything on my vehicle except the roof which they left alone. I saw the bill they sent to the insurance company and it was around $11,000 Canadian, which is around $7500-$8000. We do have higher tax and fees so maybe $7000 US.
Not cheap. I asked if I could pay extra to get a custom colour, but the insurance company wouldn't allow it. But not cheap!
