Originally Posted by Karnivor707
Having rapid wear on outside edge of front passenger side tire, it’s bothering me a lot cus I just got these tires. Anybody have any suggestions? Here’s my alignment readings.
I also do get a squeak noise on that same side not sure if the squeak is related or not but it has appeared since I added my 3” lift recently. Is there any parts that can be worn I should look into, ball joint, wheel bearing assembly? Is anything like that associated with such wear? It’s only on one side specifically that tire only.
I don't see any attachments. Sounds like an alignment issue.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs |
5th Gen Brakes | Everything else is in the
Build Thread
