Originally Posted by mslim
Hard to say how much oil. It wasn't any oil that you could pour out, just the film left by the viscosity of the oil on the inner surface of the gas can. New plugs wouldn't be a problem, I've done those before. I just didn't want to have drop the gas tank and maybe replace the fuel pump.
I don't think that dropping the tank will be necessary, it should work itself out over time and a few more tanks of gas, the plugs if fairly new should also be fine but I would still pull them and inspect them for any fouling and replace if needed, if they are fairly old then I would just go ahead and replace them but wait it out a while for the system to clear most if not all of the oil out first, oil after all is a petroleum product and it will dilute in the gas and be burned in the engine with little to no ill affects in the long run.
