Old 09-26-2022, 04:31 AM #1
vonRunner's Avatar
vonRunner vonRunner is offline
Real Name: Andrew
vonRunner will become famous soon enough
vonRunner's Avatar
Real Name: Andrew
vonrunner's 2006 V8 Build & Adventure Thread
vonrunner's 2006 V8 Sport Edition
Tires & Wheels
285/75R17 Toyo Open Country A/T III
Method NV 305 - 17x8.5 - 0mm Offset
Spidertrax 1.25" Spacers
Suspension
Camburg UCA's
Fox 2.5 Ext. Travel Coilovers w/ DSC
Eibach 14" x 650lb Springs
Front Sway Bar Removed
Eimkeith Panhard Correction Kit
Fox 2.5 "Tundra Spec" Rear Shocks w/ DSC
Dobinsons C59-677V Rear Coils
Overland Custom Design Ext. Rear Sway Bar Links
Durobumps Front & Rear
Armor
Nguyen Works Dual Swing Rear Bumper
Demello Offroad Stealth Series Front Bumper
Demello Offroad Hybrid Sliders
Eimkeith Lower Link Reinforcements
SDHQ ABS Guards
Stock Skids
Lighting & Electrical
Baja Designs S2 Pro Ditch Lights
Baja Designs Squadron Sport Fog Lights
Baja Designs S8 30" Light Bar
Switch-Pros 9100
PowerTrays Switch-Pros Mount
Performance & Recovery
MagnaFlow Overland Series Exhaust
Metal Tech Extended Brake Lines
ARB Dual Compressor
Warn VR EVO 10-S Winch
Factor 55 Fairlead & Flatlink E
Misc
OFFROAM 4th Gen Phone Mount
Prinsu Roof Rack
WeatherTech FloorLiners
ARK Splash Guards
Four Cam Engineering Cab Vents
Build Thread
vonRunner is offline   Reply With QuoteReply With Quote
Old 09-26-2022, 08:14 AM #2
Napalm's Avatar
Napalm Napalm is offline
Real Name: Nathan
Napalm will become famous soon enough Napalm will become famous soon enough
Napalm's Avatar
Real Name: Nathan
Woo looking forward to seeing this one!! Subscribed!
Looks like a NICE build!
2007 SR5 V8
2017 Limited
Napalm is offline   Reply With QuoteReply With Quote
Old 09-26-2022, 11:32 PM #3
vonRunner's Avatar
Real Name: Andrew
vonRunner's Avatar
Real Name: Andrew
December 2021
After what felt like it would be a never ending search, I finally found a 4th Gen that met the requirements I was looking for. I put up a WTB ad here as a last ditch effort and to my surprise it worked. Seller was in Arizona, so I jumped on a plane and drove it back to California. This is the first Toyota I've owned after many years of looking, and I'm definitely drinking the kool-aid now.
First photo after taking ownership. 2006 V8 Sport Edition 4WD with 99K on the clock.
The drive back was about 400 miles, but it could have been 4,000 and I would've been smiling the whole way. Pulled off a random side road in the middle of nowhere to grab some sunset photos.
Build Thread
Old 09-27-2022, 01:55 AM #4
vonRunner's Avatar
Real Name: Andrew
vonRunner's Avatar
Real Name: Andrew
January 2022
The next few weekends after I picked it up were spent doing some smaller things in between all the busy holiday/family stuff.
First I removed the steps, swapped the V8 tow hitch for the V6 version, and installed the MagnaFlow exhaust.
Next was a fresh set of WeatherTechs to clean up the interior. It came with a pretty beat up set of tan WeatherTechs, so this made a massive difference in the interior appearance.
Finally I gave one of those headlights restoration kits a go because the headlights definitely had some haze going on.
Build Thread
Old 09-27-2022, 03:12 AM #5
vonRunner's Avatar
Real Name: Andrew
vonRunner's Avatar
Real Name: Andrew
February 2022
This is when the fun stuff started to arrive. I was able to get two desert trips in before the suspension and wheels showed up which was cool because I got to experience how capable it already was in it's (basically) stock form. Also, it gave me a good feeling of my starting point and what things I felt it needed the most... Which was of course suspension and tires haha.
Had a couple good mail days to start the month off.
Everyone likes some good before and afters right?
Suspension, wheels, and tires on. After running into the typical unplanned stuff along the way, I decided to call it there for the weekend. This is before the Dobinsons rear coils went in and with almost no preload added to the coilovers.
Build Thread
Old 09-27-2022, 04:32 AM #6
vonRunner's Avatar
Real Name: Andrew
vonRunner's Avatar
Real Name: Andrew
February 2022
Then it was time to finish up the remaining stuff I didn't get to the prior weekend.
Put in the Dobinsons C59-677V rear coils, the RIG'd ultraswing, and the spare.
Threw on the Spidertrax 1.25" spacers and painted the rear hubs.
Since so much time was spent working underneath it, my OCD kicked into overdrive and I applied a little elbow grease to the rest of the undercarriage
Build Thread
Old 09-27-2022, 07:32 AM #7
Napalm's Avatar
Real Name: Nathan
Napalm's Avatar
Real Name: Nathan
This is some inspiration right here for mine. Great looking build!! Looking forward to seeing more of it.
2007 SR5 V8
2017 Limited
Old 09-27-2022, 08:30 AM #8
thegame7 thegame7 is offline
thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice
Shout out to titanium metallic 06+ Sport V8s! That thing is minty. Mine has 215k on the clock
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
thegame7 is offline   Reply With QuoteReply With Quote
Old 09-28-2022, 01:12 AM #9
vonRunner's Avatar
Real Name: Andrew
vonRunner's Avatar
Real Name: Andrew
Thanks, appreciate that! Working on getting the rest of the stuff up, but it's taking longer than I thought it would haha.
One of the best combos for sure! I've seen yours on here and it looks awesome!
Build Thread
Old 09-28-2022, 01:44 AM #10
vonRunner's Avatar
Real Name: Andrew
vonRunner's Avatar
Real Name: Andrew
March 2022
First shake down trip after the suspension install was Mojave Road. Got in some solid dirt miles over the course of a day and a half, and there were a lot of cool things to stop and check out along the way. I'd really like to run this route again to explore the area more... Next time I won't be detailing the undercarriage right before the trip though. Couple murky water crossings and some muddy streams quickly undid my work lol.
It was insanely windy the weekend we ran it, so between that and all the driving not many photos were taken unfortunately.
Build Thread
Old 09-29-2022, 12:50 AM #11
vonRunner's Avatar
Real Name: Andrew
vonRunner's Avatar
Real Name: Andrew
April 2022
Picked the Demello bumper up from powder coat. I never got to see it before this as I drove it straight from Demello to the powder coater and never took off the wrapping. Upon seeing it finished I was impressed with the build quality and design.
Here's a photo of the side you don't usually get to see. Thought it was cool the way they used skeletonized internal supports for extra strength where needed while also keeping weight reasonable.
Before and after. Bumper, Baja Designs, and SDHQ billet ABS guards were added.
Build Thread
Old 09-29-2022, 01:21 AM #12
vonRunner's Avatar
Real Name: Andrew
vonRunner's Avatar
Real Name: Andrew
April 2022
And here's a couple side shots from after the winch install, new tint, and additional rake from the newly added weight haha.
Build Thread
Old 09-29-2022, 08:08 AM #13
Napalm's Avatar
Real Name: Nathan
Napalm's Avatar
Real Name: Nathan
Good looking bumper. Love the simplicity and the hidden winch!
How bad is the rake? It’s hard to tell from the photo. I’ve been wanting a new bumper but was concerned about this.
2007 SR5 V8
2017 Limited
Old 09-29-2022, 07:47 PM #14
vonRunner's Avatar
Real Name: Andrew
vonRunner's Avatar
Real Name: Andrew
It actually wasn't horrible, but If you're going to add a bumper and/or winch you'll most likely have to make suspension adjustments.
Build Thread
Old 09-29-2022, 08:17 PM #15
Sweet! I've always been curious how one of those bumpers would look if it were color matched
adventure , build , suspension , thread , vonrunners
PC_Overland Adventures and Build Thread delgadtn 5th gen T4Rs 14 05-17-2020 12:45 AM
Seattle_SR5's 99 Limited 4WD: Repairs, Upgrades, Adventures and Build Thread Seattle_SR5 3rd gen T4Rs 15 02-11-2020 04:54 PM
10' LE Build Thread and Adventures (Lots of Pics) Grey-Thunder 5th gen T4Rs 29 11-08-2019 09:34 PM
Another Slow Build & Random Adventures Thread by Folsom4Rnr Folsom4Rnr 4th Gen T4Rs 14 08-02-2018 05:04 PM
eddie333 build thread & misc adventures eddie333 5th gen T4Rs 46 03-08-2017 02:53 PM
