Old 06-23-2019, 12:32 PM #16
hankd's Avatar
hankd hankd is offline
Real Name: Harry
hankd is on a distinguished road
hankd's Avatar
Real Name: Harry
yep it was programmed at the dealer. the truck will turnover, start and run. keys and fobs work normally.
had a mechanic friend over a few times. first problem was all the fuses in the box under the hood were 'hot' even when they shouldn't be (ie a multimeter will read current on fuses it shouldn't when there is no key in the car). that problem went away on its own, which is troubling. but any time the etcs fuse is plugged in it blows immediately. we have not taken the dash apart yet, though i have no reason to expect anything was damaged behind the dash. if we disconnect the ecu, the a newly installed etcs fuse will be fine, but as soon as we plugged the last cable in the ecu the fuse fries immediately.
the alternator is shot and we cut the wires (clip was siezed) to it to make sure there wasn't some open relay in the alternator. i ordered a new alternator and clip for it.
we wondered if the ecu is partially working where it does what it's supposed to do but something in it is shot and causing the fuse to blow. took the ecu apart and did not see anything obviously toasted at first glance.
when my mechanic had the ecu hooked up to his scanner, he had a read/write option which he wasn't familiar with. i am wondering if i need yet another ecu if i might be able to use his scanner to read the key/vin off the current one and write it to a new one, saving me a trip to toyota.
major nightmare here haha. i've read all the threads on here about ecu water damage and done a hefty bit of googling over the last few months. but i'm grateful for any replies or further insights anybody else might have.
hankd is offline   Reply With QuoteReply With Quote
Old 07-05-2019, 04:50 PM #17
hankd's Avatar
Real Name: Harry
hankd's Avatar
Real Name: Harry
turns out the alternator fried in the water and that was causing the fuse to blow. replaced the alternator and the truck is working again!
Old 07-06-2019, 05:49 PM #18
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Congrats! And thanks for posting the final fix, this will no doubt help somebody down the road as it was a complex troubleshoot.
waypoint is offline   Reply With QuoteReply With Quote
Old 07-06-2019, 06:23 PM #19
Real Name: Skip
Real Name: Skip
This just goes to show what sometimes seems to be a complicated issue turns out to be relatively a simple fix that was just over looked/not checked out!
Glad you got it fixed!!
2004 Limited V8
Old 05-30-2022, 03:33 PM #20
kadijasquare kadijasquare is offline
kadijasquare is on a distinguished road
Water damage is one of the worst things that can happen. There was a huge flood in my house because the pipe burst. The garage and the ground floor were almost ruined, and my car had many problems because of that.
Still, the biggest problem for me was the damage to my house. I had to call the flood damage repair professionals to help me undo the damage water did. These guys did an amazing job, and most of the damage was repaired.
My car is still at the mechanic's place, but it will be fixed soon, I hope. It's crazy how one burst pipe can do so much damage.
kadijasquare is offline   Reply With QuoteReply With Quote
car , ecu , floor , water , wet
Possible Water Damage to Engine? jdm843 4th Gen T4Rs 4 10-07-2015 12:24 PM
Key Fob Water Damage Question GreyhoundGuy 4th Gen T4Rs 7 01-24-2014 09:06 AM
water damage headliner?? cobey 4th Gen T4Rs 4 06-08-2013 08:26 PM
Interior Water Damage jaa 3rd gen T4Rs 10 10-06-2012 03:50 AM
Water Damage? bill99 Problems & Warranty Issues 5 10-28-2009 03:50 AM
