Old 05-30-2022, 10:26 AM #1
sajer's Avatar
sajer sajer is offline
sajer is on a distinguished road
sajer's Avatar
2006 start no crank again.....sigh
Ok, so a month or so ago I jump back into 4runner and get power but no crank , barely a slight click and nothing. Check battery and dork around with stuff and then boom it starts.
Take it to mechanic because all the lights are now on and he checks the cables , hooks up scanner showing ctalytic convert and clears codes. Drives it around all day and no issues. I get it and two days later all the light back on , but seems to start ok.
Then im leaving work and it wont go into gear , just sits for maybe 10 seconds and then pops into gear. I drive it around with the lights all on and decide to try and reset it myself. Unplug it for a bit then start it back up and no light no issues. This morning I go to start , get power but no crank.
I pull the relay and seems to test ok. Bypass the relay through the box and the engine cranks.
Now what do I try. Starting to get the feel for a new runner at this point.
thanks
sajer is offline   Reply With QuoteReply With Quote
Old 05-30-2022, 11:06 AM #2
rdruss's Avatar
rdruss rdruss is online now
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Sounds like the relay may be suspect. You say you bypassed it and ok.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
rdruss is online now   Reply With QuoteReply With Quote
Old 05-30-2022, 11:15 AM #3
sajer's Avatar
sajer's Avatar
Yep , tried my multi meter on it and it appears good. Then with it pulled I jumped the starter and it fired.
Now I just went back out and messed with things again. I tried starting in park , with no go. Moved the transmission to reverse - no go. Moved the transmission to "N" and it fired up. I had tried previously to start in "N" with no start , but this time it did? Maybe the transmission range selector is going out?
Old 05-30-2022, 01:10 PM #4
sajer's Avatar
sajer's Avatar
Welp further dinking around. I tried starting in P no go. Tried in R no go. Tried N and it fired.
So, transmission range sensor and a buddy of mine though maybe the brake light switch?
back , crank , light , lights , start
No start no crank sugjavier 3rd gen T4Rs 24 12-28-2022 06:00 PM
Crank, no start OLD BOB 4th Gen T4Rs 1 04-11-2022 09:39 AM
Crank no start thecole1098 3rd gen T4Rs 10 07-21-2018 07:44 AM
Crank no start 4runneracerunner Classic T4Rs 35 08-19-2017 04:46 PM
Crank, NO start... Please help! VALERIEP81 3rd gen T4Rs 7 12-15-2009 08:05 PM
