Old 04-09-2019, 05:32 PM #1
sport2004's Avatar
sport2004 sport2004 is offline
Real Name: James
sport2004 is on a distinguished road
sport2004's Avatar
Real Name: James
Additional Parts for Shocks/Springs Upgrade
Have spent quite a while now reviewing the install discussion, suggestions and data. Very Helpful. However, I notice there is frequent reference to replacing additional parts as part of the job. Mount kit, sway bar (?) bushings, links. But, there is not much discussion of these items, function or sources.
I have a pretty worn X-REAS system that has just sprung a leak, and am wondering what would be the typical, sensible, recommended components to replace while everything is disassembled. I may proceed with this next week and don't want to leave out anything obvious to all (but me!)...
Any insight appreciated, thanks.
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
sport2004 is offline   Reply With QuoteReply With Quote
Old 04-09-2019, 05:41 PM #2
mwebster22 mwebster22 is offline
mwebster22 is on a distinguished road
I’ve replaced XREAS to Bilstein 5100’s on all three of mine, and didn’t buy/replace anything else, just swapped the shocks on all 4 corners. Maybe check your lower ball joints, upper control arm ball joints, sway bar bushings and end links, and tie rod ends for play and replace if necessary, but after 150,000 on my 2WD and 140,000 on my 4WD it hasn’t yet been necessary.
2012 4Runner Limited 2WD
2006 4Runner Sport 4WD
2006 4Runner Sport 2WD
mwebster22 is offline   Reply With QuoteReply With Quote
Old 04-09-2019, 06:43 PM #3
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
cool
Regards, sport2004
Old 04-09-2019, 06:51 PM #4
Caldizzle's Avatar
Caldizzle Caldizzle is offline
Real Name: Calvin
Caldizzle will become famous soon enough
Caldizzle's Avatar
Real Name: Calvin
Like mwebster22 said, check those parts as necessary. Give them a good visual inspection for tears or leaks. I recommend jacking the car up and inspecting them for play. Other than that use your best judgement; some of the parts are cheap and easy to do with the disassembly you'll be doing.
Depending on how high you plan on going, look into aftermarket UCAs.
2006 Sport Edition 4x4 V8
Bilstein 6112 w/ King 700# springs (5th clip), Toytec 2" springs in the rear w/ ICON 2.0,
CBI single hoop front bumper, Smittybilt 9500 XRC, RCI steel full skid package, 285/70r17 BFG KO2s on TRD Offroad wheels
Caldizzle is offline   Reply With QuoteReply With Quote
Old 04-09-2019, 07:11 PM #5
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
thanks
Regards, sport2004
Old 04-09-2019, 07:49 PM #6
Shiftless Joe's Avatar
Shiftless Joe Shiftless Joe is offline
Shiftless Joe is on a distinguished road
On my 2WD 07, over last weekend I replaced the:
XREAS with 5100's set at the second from bottom (no oil in right front xreas at all, with no visible leaks?)
Front springs with new factory Toyota (originals were drooping severely)
Front and rear calipers -Napa Eclipse Semi-Loaded (front passenger was seizing so I swapped them all)
Front and rear Napa Adaptive brake pads
New Napa Ultra Premium coated rotors all around
and one front hub due to fowled threads on the studs (will fix and keep 4 spare)
After 150,000 it deserved an update.
Later this summer I plan on swapping out the XREAS on my 05 4x4 with 5100's, reusing the stock springs, and changing nothing else unless it's broken.
It's a Toyota so there's really no need to change parts just for the sake of it.
Shiftless Joe is offline   Reply With QuoteReply With Quote
Old 04-09-2019, 07:52 PM #7
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
appreciate the comments +1
Regards, sport2004
Old 04-09-2019, 11:46 PM #8
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
I would get new strut top mounts. The rubber in the OEM mounts is likely worn down by now. Definitely doesn't hurt to change it out. You'll have everything apart already.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
additional , discussion , insight , parts , recommended
Additional Parts to replace while changing LCA Mullett757 4th Gen T4Rs 3 11-17-2018 05:35 PM
FS: $350 F&R 5100 adjustable shocks, FJ rear springs, and stock parts South-O 4RnR For Sale: Suspension/Wheels/Tires 5 10-06-2014 12:26 AM
Suggestion with additional parts on TB maintenance JWaldz 3rd gen T4Rs 14 05-31-2013 09:24 AM
What additional parts, if any, are needed when replacing shocks and springs? jamess 3rd gen T4Rs 2 05-18-2010 12:45 PM
