Old 08-04-2013, 03:15 PM #1
michaelreed's Avatar
michaelreed michaelreed is offline
michaelreed is on a distinguished road
Loose heat shield sound
Alright guys I need some help. I have what sounds like a loose heat shield or bad cat. It sometimes happens if i rev during idle and usually only happens at low rpm or going up hill lightly accelerating. I've been under my runner like 5 times and can't isolate where the sound is coming from. No heat shields appear to be coming off and I banged on the cats and nothing rattles. Anyone else have issues like this that they have resolved? Any other ideas on what it might be?
My Build Thread
OME 3" lift - LED swap - Cobra CB and Firestik Antenna - Plastidipped Grill
michaelreed is offline   Reply With QuoteReply With Quote
Old 08-04-2013, 03:52 PM #2
TOY2G TOY2G is offline
Real Name: Nathan
TOY2G will become famous soon enough
Real Name: Nathan
It is the heat shield that is wrapped around you cat on the exhaust manifold itself. Both if mine do it, and there is no good solution, other than replacing the manifold and cat. You can take a punch and put a few dents in the heat shield near the seam to help tighten it up, but I will end up rattling again.
TOY2G is offline   Reply With QuoteReply With Quote
Old 08-04-2013, 04:13 PM #3
Are you talking about the cats closest to the engine or the after cats? It appears I have a pacesetter on the passenger side because I only have one cat with a heat shield and it doesn't seem loose.
My Build Thread
Old 08-04-2013, 04:20 PM #4
Wuzzy Wuzzy is offline
Wuzzy is on a distinguished road
I get the noise in drive at idle with the AC on. If I pop it into neutral the noise goes away.
Wuzzy is offline   Reply With QuoteReply With Quote
Old 08-04-2013, 04:26 PM #5
batcave4 batcave4 is offline
Real Name: standard
batcave4 is on a distinguished road
Real Name: standard
Mine fell off last week...at least the rattle is gone.
batcave4 is offline   Reply With QuoteReply With Quote
Old 08-04-2013, 04:41 PM #6
WillK's Avatar
WillK WillK is offline
WillK is on a distinguished road
WillK's Avatar
You could try a large hose clamp. I did that on another car I once had and it worked...
2018 4Runner, SR5 Premium, Silver
2015 4Runner, Limited, White
2015 Lexus RC F, White
2010 Lexus IS350C, USB
WillK is offline   Reply With QuoteReply With Quote
Old 08-04-2013, 04:46 PM #7
ebg18t ebg18t is offline
ebg18t is on a distinguished road
My center muffler heat shield was partially loose. Caused the same sound.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
ebg18t is offline   Reply With QuoteReply With Quote
Old 08-04-2013, 05:07 PM #8
What fell off? Cat heat shield?
My Build Thread
Old 08-04-2013, 05:12 PM #9
SSt4r's Avatar
SSt4r SSt4r is offline
SSt4r is on a distinguished road
SSt4r's Avatar
Check the heat shields ABOVE the exhaust. I've have them get loose and rattle. The corroded around the bolts; I had to add larger washers & that solved my problem.
1999 BMW M3 coupe(E36) & 2005 V8 sport 4X4 black: ARB bull bar with 4 hella 500s,backup camera in spoiler,VSC off, springs:Tacoma w/ toytec(1/2"Fr) & FJ w/ daystar(1.5"R) spacers,Bora .75" front & Spidertrax 1.25" rear spacers,swaybar bushings upgrade,Stoptech rotors,SS brake lines,RCI Metalworks skids (front, trans.,transfer), Volant CAI,DT shorties w/ Dirty Deeds exhaust,fully soundproofed,Rostra seat heaters,HID (lows),HIR (highs),running board lights (added),aux reverse lights,2006+ tail lights,rear fog mod (tail, brake, directional OR rear fogs),Scion T1819,LED int. lights, key reminder diabled, Land cruiser steering wheel,rear window dog barrier, vent visors, Ultraguage, Enkei Deep Six 20" wheels for summer, factory sport wheels with A/Ts, FJ cruiser wheels with winter tires
SSt4r is offline   Reply With QuoteReply With Quote
Old 08-04-2013, 05:17 PM #10
Real Name: standard
Real Name: standard
Nah...muffler shield
, sorry for the confusion.
Old 08-04-2013, 05:28 PM #11
Checked all of them. None are loose or rusted off. The sound itself sounds more like the cat heat shield but its not loose. Could an exhaust leak cause this sort of noise? On occasion when I turn the 4runner on after its cooled off I hear a ticking sound. So Im pretty sure I have a leak somewhere but I'm not sure if that and the thin metal rattle at low rpm are related.
My Build Thread
Old 08-04-2013, 08:56 PM #12
Slvr RnR's Avatar
Slvr RnR Slvr RnR is offline
Slvr RnR is on a distinguished road
Slvr RnR's Avatar
I've had the exact same issue the past 3 weeks. I hear it during idle with the windows down and when driving slow over a bump. I've gone under with a rubber mallet with the car in drive and parking brake engaged (I know,`stupid) and nothing seems to be coming from the heat shields. I can hear the rattle when underneath and think I can localize it past the cat, possibly the headpipe or muffler. When I'm driving the exhaust in general doesn't sound quite right either.
Keeping an eye on this thread.
...I should also mention I have a aftermarket Gibson exhaust.
2007 SR5 V8 4X4 Titanium Metallic
...with a few mods.
Slvr RnR is offline   Reply With QuoteReply With Quote
Old 08-04-2013, 09:22 PM #13
WillK's Avatar
WillK's Avatar
Disregard...
Old 08-04-2013, 09:34 PM #14
RAIDN's Avatar
RAIDN RAIDN is offline
RAIDN is on a distinguished road
RAIDN's Avatar
I had a rattle like this at one point, the heat shield above the muffler had come completely off and was resting on top of the muffler and rattling. It was too big to come out on its own, but I finally just pulled it out and it went away
2004 T4R Sport V8 4WD - Titanium Silver - Daystar 2.5/1.5 Lift - 275/70/17 BFG AT KO - Stealth Custom Series Stealth 6 Wheels, Matte Black - Borla Cat Back Dual Exhaust - K&N CAI
RAIDN is offline   Reply With QuoteReply With Quote
Old 08-04-2013, 09:37 PM #15
Rob4r's Avatar
Rob4r Rob4r is offline
Rob4r is on a distinguished road
Rob4r's Avatar
use some wire ties from home depot
and pad it with sticky foam - i had the sound and this stopped it
Rob4r is offline   Reply With QuoteReply With Quote
Heat Shield SportT4R 4th Gen T4Rs 17 12-02-2017 09:16 PM
Heat Shield above muffler Nedlee 4th Gen T4Rs 3 07-25-2013 02:11 PM
Heat Shield for Hood Diverse4runner 3rd gen T4Rs 10 04-02-2013 04:52 PM
Exhaust Heat Shield...Help! DETarch 4th Gen T4Rs 3 03-12-2009 03:45 AM
heat shield worldcoast Classic T4Rs 1 04-09-2007 10:07 PM
