Old 04-19-2019, 12:41 AM #1
montijo505's Avatar
montijo505's Avatar
Calling all 17x9 -38
Title says it all. I’ve seen 5th gens running these dimensions all day. Anyone in a 4th gen rocking 17x9 -38 SCS’s? I’ve been slowly saving and am finally about ready to pull the trigger on some new wheels. Would love to run this size but I’ve been told it won’t work. I’m running a toytec 3” coilover lift, SPC UCA’s, already have a BMC done. Currently running 17x9 -6 with 285/70R17 Trail Grapplers. What’s the difference in MM from -6 to -38? Only rubs backing out of the driveway on the fender liner. I’m willing to go further down the rabbit hole in regards to trimming/cutting to make these work. Someone egg me on!
Also pics and what mods did you do to run them? Thanks guys.
Old 04-19-2019, 01:35 AM #2
Formidable's Avatar
Formidable Formidable is offline
Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light
Formidable's Avatar
That wheel width and offset are very aggressive. They will poke out of the fender flares exactly 1” more than your wheels right now. See the following chart. An easy way to test the fitment without investing 1k is to buy 1” wheel spacers. I think there is a used set for sale right now in the 4th gen specific thread. Push your wheels out 1” and see for yourself exactly what you need to do to make it work. Or... abort ship and sell the spacers for a minimum to no loss.
Calling all 17x9 -38-4ad7a070-5e39-40df-afd4-3e596a825fd6-jpg
2002 Thundercloud | TRD Supercharger | TRD Headers | URD 2.2 Pulley | Toytec | Addicted Offroad | 4xinnovations | Icon | SCS | BRIDE
BUILD THREAD
Formidable is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 01:42 AM #3
Formidable's Avatar
Formidable's Avatar
Ask the guy selling the spacers what the width is. He didn’t post this info. From the pic they look to be 1” wheel spacers. This is the route I would take before throwing any significant cash at this. Link below.
4th Gen specific for sale thread
BUILD THREAD
Old 07-02-2019, 12:12 PM #4
scottblink23's Avatar
scottblink23 scottblink23 is offline
Real Name: Scott
scottblink23 is on a distinguished road
Real Name: Scott
Hey I noticed you pulled the trigger on these. I am seriously considering these rims. What are your thoughts on them? Did they end up working out? Do they stick out "too far"? Can you post pics from the side? lol - sorry for the 20 questions.
Thanks!
2006 SR5 4WD | OME Lift (885 + top spacer) w/Superflex Rear Coils | ICON Uniball UCAs | CBI Full Front Bumper | Warn Winch | PIAA 510s | Cooper AT3XLT 295 75 16 | Level 8 Trackers | GOBI Stealth Rack | MJT Satoshi Grille - http://www.toyota-4runner.org/4th-ge...ld-thread.html
scottblink23 is offline   Reply With QuoteReply With Quote
Old 07-02-2019, 12:49 PM #5
jgmx893's Avatar
jgmx893 jgmx893 is offline
jgmx893 is on a distinguished road
jgmx893's Avatar
I never understood this chart exactly, can anyone explain it?
By my logic, with an offset of 0mm, the hub mating face should be exactly in the center of the wheel, no? Which should then mean a backspacing of exactly half the wheel width. This chart(among others I've seen), contradicts that. Anyone able to explain?
jgmx893 is offline   Reply With QuoteReply With Quote
Old 07-02-2019, 01:17 PM #6
montijo505's Avatar
montijo505's Avatar
Thanks!
They are awesome. The finish and quality are great. I didn’t have a hard time getting them to fit, but I had a 3” toytec coilover lift, body mount chop and SPC UCA’s already. That being said, I did install a 1” body lift to help and also set my UCA’s to the farthest position forward to help clearing the body mount. I did have to trim the lower front bumper quite a bit as well. Well worth it.
Calling all 17x9 -38-img_1489-jpgCalling all 17x9 -38-img_1490-jpgCalling all 17x9 -38-img_1488-jpg
Old 07-02-2019, 02:17 PM #7
Real Name: Scott
Real Name: Scott
Thanks man - I have a 3 inch OME lift + top spacer, ICON UCAs, No BMC ... where do you think I'd rub?
Old 07-02-2019, 02:17 PM #8
Formidable's Avatar
Formidable's Avatar
The more negative the offset the more the mating surface is pushed towards the back of the wheel. Another way to think about it is the wheel will stick out further from the fender as compared with zero offset. More negative offset wheels also correspond to bigger lips in the front of the wheel depending on wheel design.
If you check 9” wheel on the chart I previously posted and look at -6 offset you will see that when you compare the backspacing with -38 offset you get approximately 1.25”
Just an FYI, there are a TON of videos and explanations online regarding offset and backspacing.
Calling all 17x9 -38-b5b4cb04-d3ae-47ab-9508-b35a54e209e9-jpg
BUILD THREAD
Old 07-02-2019, 02:17 PM #9
Real Name: Scott
Real Name: Scott
by the way they look awesome!
Old 07-02-2019, 03:40 PM #10
montijo505's Avatar
montijo505's Avatar
Definitely on the body mount. You’ll have to chop it for sure. It sounds more complicated than it is. Any local welder will do it for around $20-$30 including blocking the hole off with plate metal. Just spray paint it so it doesn’t rust. Also the front bumper on the lower inside edge will need trimming. A dremel is best but I literally used a sharp utility knife.
Old 07-02-2019, 04:44 PM #11
Real Name: Scott
Real Name: Scott
Thanks man - I've got a CBI front bumper so fortunately I won't have to worry about the front. The BMC doesn't intimidate me.. bring it on!
Old 07-02-2019, 06:26 PM #12
montijo505's Avatar
montijo505's Avatar
Seriously can’t recommend the wheels enough. They look super aggressive. I get compliments every time I drive it.
Old 08-22-2020, 05:28 PM #13
barryjacob8 barryjacob8 is offline
barryjacob8 is on a distinguished road
Just found this thread, live in Rio Rancho area as well and can't wait to save up and get these wheels! Didnt know how they would look from the side but you posted some pretty awesome shots and I know that I forsure want these!
Sent from my SM-G973U1 using Tapatalk
barryjacob8 is offline   Reply With QuoteReply With Quote
Old 08-22-2020, 06:56 PM #14
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
Willtheyfit.com is a good site to answer offset questions.
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 08-22-2020, 09:17 PM #15
montijo505's Avatar
montijo505's Avatar
You're welcome to look at it anytime!
Sent from my SM-G986U using Tapatalk
17x9 , i’m , i’ve , run , running
SCS F5 17x9 T4RWARRIOR Stealth Custom Series 12 08-17-2018 12:03 AM
SCS F5 17x9 ? Kimokona Stealth Custom Series 0 01-28-2017 01:41 PM
FS: MB 352 17x9 $400 Osmith For Sale: Suspension/Wheels/Tires 1 10-16-2015 03:10 PM
FS: MB 352 17x9 with lug kit-Nashville, TN $550 AZrunner11 For Sale: Suspension/Wheels/Tires 4 01-07-2014 01:53 AM
