04-19-2019, 10:40 AM
Real Name: brian
Real Name: brian
Have Bluetooth without Bluetooth radio?????
In not sure how this works but I have the the JBL synthesis in my 4runner. When i have my phone plugged into the jack in the console i have bluetooth in my car. Where is the speaker in the vehicle that allows me to talk? Its not the nav radio.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
04-19-2019, 10:58 AM
Real Name: Eric
Real Name: Eric
Not sure quite what you're asking, but...
If you have bluetooth it should work without your phone plugged in to anything (if you phone is connected) The microphone should be located in the sunglass holder at the headliner (should have a grid in it). If you're the original owner and haven't changed anything this should be the case.
If the previous owner added an interface for bluetooth the microphone could be anywhere (wherever they put it). This could be a Grom unit, or a couple other manufacturers. Again this is assuming bluetooth is in fact connected.
If you're referring to the AUX in the center console, your phone will be coming through all the speakers and won't be connected to bluetooth but it will be using your phone's microphone and using the car speakers for audio.
Not sure if that helps, but I'm trying to use what you gave us.
2000 Limited | e-locker | 33's | Skids/Sliders | TRD SC | Sold
2007 Limited | V8 | RCI | OME 884/895e | 255/75r17 | JBA's
04-19-2019, 04:15 PM
Real Name: brian
Real Name: brian
Thats it. I do not have bluetooth in the car but I can speak to someone like Bluetooth when the phone is plugged in to the console.
04-19-2019, 07:38 PM
My 06 V8 Limited has factory bluetooth for the phone only, with steering wheel controls. I have never used it but my kid had set it up.
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
04-20-2019, 07:01 AM
Real Name: brian
Real Name: brian
You probably have the navigation option, mine does not.
04-20-2019, 08:02 AM
Aux mode on the radio when answering a call will play the persons voice through the speakers for me if I am plugged in.
Does it still work if you are on FM or another source?
04-20-2019, 01:08 PM
This... You are on AUX, my friend. Not Bluetooth.
Air 4rceRunner One, 04 Sr5
