Old 04-19-2019, 01:38 PM #1
dahveeed dahveeed is offline
dahveeed will become famous soon enough
Need help! White knuckle slider install
I need advice from those that have installed these white knuckle sliders! I install the passenger side no problem. But this driver side I think I did something wrong ? The rear upper brake line clip I was able to do, but I can’t seem to figure out the center U bolt . Following the instructions my center u bolt doesn’t line up at all. I don’t see how I can push the slider forward anymore for it to line up ? See below ;
Center u bolt pictured location per instructions
The location of my slide in relation to the u bolt
Are you guys unclipping the side brake lines (circled in green) and leaving them unclipped ?
I don’t see how I can slide them anymore forward as they would touch in the front
and rear
Any advice would be appreciated !
dahveeed is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 03:18 PM #2
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
i did this not too long ago (in MA cold garage sub freezing no less)
i believe i popped/broke the green circle clip and slid mine further back, you will want to get it under those lines and further back.
if youre still not able to reach it, which i think happened to me, unfortunately i undid the rear most bolts (might have left u bolts in slider) and the front i loosened or removed bolts, and then i got the middle ones and the others after.
hinmo24t is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 03:20 PM #3
did you have fun popping the clip on the rear top of frame drivers side?
that gave me the most trouble so its cool you got that out of the way. i hated popping the clip with a flathead blind with the hardlines in it.
Old 11-09-2020, 02:39 PM #4
4RunnerGrom's Avatar
4RunnerGrom 4RunnerGrom is offline
4RunnerGrom is on a distinguished road
I was thinking of going with these sliders myself! Do you have HREW or DOM?
Was doing some light research and saw that people were suggesting other brands at a lower cost, but the reviews for people with WK seem to love them, how are you feeling about them almost a couple years later? Cheers!
2001 4Runner Limited - Build Thread to come!
4RunnerGrom is offline   Reply With QuoteReply With Quote
Old 11-09-2020, 03:01 PM #5
montijo505's Avatar
montijo505's Avatar
I've had mine for a little over a year. Love them. I had zero issues installing other than they are heavy. I got the DOM and they look perfect. I used Raptor liner to paint and that's holding up well also.
Sent from my SM-G986U using Tapatalk
Old 11-10-2020, 07:33 PM #6
Thanks for posting that shot, they look awesome. Good call on painting it yourself with Raptor liner, that might be the way to go!
Old 11-11-2020, 01:37 PM #7
montijo505's Avatar
montijo505's Avatar
It's held up incredibly well on my sliders and front bumper. Another shot of the sliders.
Old 11-11-2020, 01:44 PM #8
montijo505's Avatar
montijo505's Avatar
And more
bolt , center , instructions , line , side
White Knuckle sliders DannyLlama 4th Gen T4Rs 88 11-22-2020 07:11 PM
Bolt on slider mid-install help white knuckle sliders hinmo24t 4th Gen T4Rs 17 02-10-2019 09:53 PM
White Knuckle Rock Sliders RockstarCondoms 3rd gen T4Rs 9 09-05-2018 01:39 PM
Sliders from White-knuckle Off Road H2O_Doc 5th gen T4Rs 102 06-25-2018 02:57 PM
White Knuckle Sliders - Weld or Bolt On? ritmatt 5th gen T4Rs 4 06-23-2016 08:41 PM
