Old 06-27-2019, 11:14 AM #61
K-D-Runner's Avatar
K-D-Runner K-D-Runner is offline
K-D-Runner will become famous soon enough
K-D-Runner's Avatar
Hey Victory4x4, is it possible for you to do an overhead molle panel in the rear cargo area similar to what OG Fabrication sells? But possibly make it larger so it fills up more of the roof? I don't know how much weight the mounting points are capable of withstanding but it could be a unique storage option replacing the need for overpriced nets. Possibly even make it a bolt-in addition to your rear window molle panels for extra stability/strength?
Just some ideas for you!
Sent from my Pixel 3 XL using Tapatalk
K-D-Runner is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 02:43 PM #62
volkinator volkinator is offline
Real Name: Eric
volkinator will become famous soon enough
Real Name: Eric
This would be great! I just did the net one with some inexpensive materials (still owe you some pictures on the other thread!)
But this would be pretty cool. Even sink it down a bit to get some more height above (keep it above the rear view mirror lines)
2000 Limited | e-locker | 33's | Skids/Sliders | TRD SC | Sold
2007 Limited | V8 | RCI | OME 884/895e | 255/75r17 | JBA's
volkinator is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 04:07 PM #63
K-D-Runner's Avatar
K-D-Runner's Avatar
Exactly! Nobody's done it in a way that actually makes use of all the space from what I can find. I was thinking about making my own net but started seeing overhead molle panels for Tacomas and Tundras and thought it was a cool alternative because you could quickly hook a net of any size to it if needed for stuffables, and have different pouches and tools mounted up and out of the way.
Old 06-27-2019, 05:42 PM #64
dahveeed dahveeed is offline
dahveeed will become famous soon enough
Please build a hybrid tube front bumper. The only reason I haven't bought your integrated front bumper is because I'm hoping someone will build the hybrid type.
I believe there is a lot of interest for this style, similar the one built by "Inv4drZm"
dahveeed is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 07:27 PM #65
BLUE 01 BLUE 01 is offline
BLUE 01 is on a distinguished road
X2 I’m beginning to dislike my ARB bumper was going to order the Coastal Off-road bumper but have to way to weld it together
BLUE 01 is offline   Reply With QuoteReply With Quote
Old 06-28-2019, 08:42 AM #66
Victory 4x4's Avatar
Victory 4x4 Victory 4x4 is offline
Official Vendor
Real Name: Cam
Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of
Official Vendor
Real Name: Cam
Do these skid plates work with the V8 4th gens?
Originally Posted by davjr96 View Post
I also just ordered one intending to put it on my V8 so will also report if it arrives before they report.
We have test fit them on a V8 and they fit exactly the same! The only difference between the two is where the oil filter is located. Unfortunately, neither one is easily accessible through the skid. The V6 I believe is up top (accessed through the hood) and the V8 is up under the sway bar / behind the front cross member.
17 SR5 - BDS | Falken | Mamba | Free Spirit | Warn | Factor 55
Offering quality steel and aluminum goods for Toyotas | Victory 4x4
@victoryrunner
Victory 4x4 is offline   Reply With QuoteReply With Quote
Old 06-28-2019, 11:50 AM #67
K-D-Runner's Avatar
K-D-Runner's Avatar
Thanks for confirming that! Also, is there any plausibility regarding the overhead molle panel? Victory 4x4 New Products/Prototyping
Old 06-28-2019, 12:23 PM #68
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
It is possible! Maybe in the future, we have a lot on the list at the moment!
@victoryrunner
Old 07-08-2019, 11:41 AM #69
Real Name: Eric
Real Name: Eric
I went the net route before our last trip and it works well. Needs to be pulled tighter and add a couple more static lines to prevent things from sagging. The Molle panel would be awesome though.
Old 07-08-2019, 11:54 AM #70
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
skids
are you still offering the 15% off? thanks.
hinmo24t is offline   Reply With QuoteReply With Quote
Old 07-08-2019, 03:31 PM #71
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
The intro pricing has ended, but give the sales team a call and let them know you are from the forum! 269-459-8447
@victoryrunner
Old 07-09-2019, 11:47 AM #72
4rs 4rs is offline
4rs is on a distinguished road
4rs 4rs is offline
I like the roof rack for the gen 4. I have the sport. I assume it uses the same mounting points as the original rack? What’s the install like?
4rs is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 10:54 AM #73
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
Correct, it bolts into the factory locations. The install will be the same as the 5th gen but without the front bumper mounts.
https://www.youtube.com/watch?v=ntTACTNuT_Y
@victoryrunner
Old 07-11-2019, 10:56 PM #74
Tahoe_Natl_Forest Tahoe_Natl_Forest is offline
Tahoe_Natl_Forest is on a distinguished road
Newer to the forum so not sure if you've done this before, but this is the greatest marketing move ever! It's also informative and got me excited about my truck. Will go look at your damn full (but very flush) roof racks since nobody makes a half one ;)
EDIT: Wait a minute, does this replace my stock rack or live on top of it?
Tahoe_Natl_Forest is offline   Reply With QuoteReply With Quote
Old 07-11-2019, 11:44 PM #75
Zach L Zach L is offline
Zach L is on a distinguished road
Wow! Just picked up my 4th gen and I'm loving all the products you guys have released. Leaning toward the Blitz integrated front bumper and rock sliders.
Also do you guys have details on the lift and tire size on your development vehicle. Thanks!
2006 T4R Limited V8 4WD Nautical Blue
Zach L is offline   Reply With QuoteReply With Quote
check , current , start , thread , victory
Victory 4x4 New Product Prototyping (Armor & Accessories) victoryrunner 5th gen T4Rs 360 06-29-2023 01:56 PM
3D Printing Collaborative Prototyping michaeljtomey 3rd gen T4Rs 30 12-09-2020 11:42 AM
DFW Prototyping Rig Needed - Winch Mount USOffRoad 5th gen T4Rs 27 06-01-2017 05:56 PM
Looks like RCI is prototyping 4th Gen Bumpers! Krayziekid 4th Gen T4Rs 23 05-01-2016 03:54 PM
5th Gen with KDSS in Colorado needed for prototyping! RCI Offroad 5th gen T4Rs 3 03-16-2015 04:52 PM
