Old 04-19-2019, 05:10 PM #1
4OYOTER 4OYOTER is offline
4OYOTER is on a distinguished road
$75 EBay LC80 Snorkel on 4th gen
For Toyota Land Cruiser 80 Series 90-97 Lexus LX450 Black Air Snorkel System Kit | eBay
I wanted to start a new thread for those who are interested in using a 80 series snorkel on their 4th gen, specifically the 4.7. I had never heard of doing this until last week when I read another thread on the forum here. If I would have known a snorkel would be this cheap, I probably would have done this along time ago. The plan is to update this thread ASAP as soon as I have the installation complete. (Hopefully tomorrow)
I began prepping for the job today. The only special tools I picked up were a hole saw set and riviter from harbor freight. The snorkel didnít come with instructions, but did come with a template (which I realize may not be accurate). The first thing Iím seeing here that may need some fabrication is the elbow that connects the air box to the snorkel. It is a flexible angled rubber piece. Iím not quite visualizing how it is going to work. It seems a 4Ē straight PVC pipe would work better?
I was hoping to not need any additional pieces, but hopefully someone who has done this before can chime in ?
 EBay LC80 Snorkel on 4th gen-2c459fcc-8fbf-4ef1-8c4b-4df245672efa-jpg
1990 3.0 4x4 - Sold
1997 3.4 4x4 - Sold
2008 4.7 4x4 - Only selling when I decide on a GX
2013 SR5 4x4 - Sold
4OYOTER is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 06:30 PM #2
WhiteBoomer04's Avatar
WhiteBoomer04 WhiteBoomer04 is offline
WhiteBoomer04 will become famous soon enough
Looking forward to seeing the results of your install process.
Mark
04 V8 SE, RST Twin stick conversion. 4x4 Labs rear bumper, SW Sliders & Bullbar, ARB Locked F&R, 5.39ís, Smittybilt 10,000lb winch, 1.5 4Crawler BL, Flowmaster, CB and 2m/70cm Ham, Sat. Radio, CO2 system, Lightforce, African Outback Rack, Budbuilt, Front Runner RTT. Rock Solid Toys Solid axles, Atlas Crawl Case, 40" Cooper STT Pro's on Fuel Anza D116 beadlocks, 5:38 gear set, ADS Coilovers.
WhiteBoomer04 is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 08:58 PM #3
Fern Fern is offline
Fern will become famous soon enough
Sub'd
2005 4R V8 4x
Fern is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 10:52 AM #4
dropspace dropspace is offline
dropspace is on a distinguished road
So in case you didn't know, there is some evidence that the 80 Series snorkel does not have proper airflow for the 4.7 V8. I went with the Tacoma Safari snorkel for this reason because it has a larger diameter that is in line with the diameter of the stock airbox. There is a reason why those snorkels are so cheap. I can tell by looking at it that the intake diameter is tiny compared to the Tacoma Safari one.
The only issue with the Tacoma one is that you have to do some internal routing behind the fender to get it to work. I was able to do this with some plumbing parts from Home Depot.
Also, you get what you pay for. The plastic on the cheap ones is generally low quality and will start to fade/crack after a while.
Not trying to talk you out of it, but you should definitely look into the airflow needs that the 4.7 has. Restrict that flow and you are going to get low performance and probably take a mpg hit.
dropspace is offline   Reply With QuoteReply With Quote
Old 04-21-2019, 08:01 PM #5
Thanks for the replies. I decided not to install this snorkel. I measured the snorkel tubing at 2.56Ē diameter. I believe the 4.7 throttle body diameter is 2.9Ē diameter. Thankfully the eBay seller has free returns! Iím trying to figure out what the LC100 snorkel diameter is. If I have to fork out the money for a Taco Safari I will probably hold off for now.
1990 3.0 4x4 - Sold
1997 3.4 4x4 - Sold
2013 SR5 4x4 - Sold
Old 04-22-2019, 12:47 PM #6
Rodtheviking's Avatar
Rodtheviking Rodtheviking is offline
Real Name: Chris
Rodtheviking will become famous soon enough
Real Name: Chris
This kit seems to be the one to use until Safari gets one done for the 4th gen. I have read a few posts where these have worked just fine.
Cruiser Outfitters
Dobinsons makes a larger diameter one, might work better.
Dobinsons 4x4 Snorkel Kit for Toyota Tacoma 2005 to 2015 for V6 and 4Cyl Engines - Dobinsons Direct
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
Rodtheviking is offline   Reply With QuoteReply With Quote
gen , iím , snorkel , thread , work
New cheap snorkel on the market: the eBay ďARB SafariĒ snorkel Atomic6 3rd gen T4Rs 86 09-16-2019 01:42 PM
Installing LC80 snorkel. Need help with fender removal Theo85 4th Gen T4Rs 28 05-08-2016 12:41 PM
LC80 Snorkel fit on 4run? chassis23 3rd gen T4Rs 68 11-17-2014 06:17 PM
Upper Marlboro, Maryland LC80 wheels - eBay JWaldz For Sale: Suspension/Wheels/Tires 0 11-01-2011 10:18 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
