Old 10-23-2019, 10:02 AM #1
HIMILESV8SPORT's Avatar
HIMILESV8SPORT HIMILESV8SPORT is offline
HIMILESV8SPORT is on a distinguished road
Lower control arms
As I'm nearing 300,000 miles, LCA's probably could be replaced soon. Wondering if anyone has had any luck with aftermarket arms or are OEM Toyota arms recommended only? Also need new hardware as well. Will any 5th gens swap? Thanks in advance!
Eibach pro truck with WOR springs on 1st notch in front. 5100's in rear w/ FJ OEM takeoff coils. 255/70R18 on 18" Limited wheels. 1.5" spacers on rear(one trimmed a bit to correct lean). Gibson catback, 06+Headlamps, auxito 16K bulbs in high, low, and fogs!
HIMILESV8SPORT is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 10:09 AM #2
Captsolo Captsolo is offline
Captsolo will become famous soon enough
I put the LCAs on my 2005 SR5 (150,000) a few years ago. They came with two bushings, and the mechanic at the Alignment shop said I should get them. Ours were AM, and worked great. Check out sway bars too... they are cheap and easy to find.
https://www.amazon.com/Detroit-Axle-...s%2C269&sr=8-3
Captsolo is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 10:28 AM #3
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
I just got done doing OEM arm and all new OEM hardware. Make sure you buy Diablo Demon Carbide sawzall blades for cutting the old bolts. Thank me later.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 11:26 AM #4
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
Go OEM for LCAs. Lots of threads on problems with aftermarket.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 12:30 PM #5
TLChip TLChip is offline
TLChip is on a distinguished road
Do you happen to have a list of all the oem part numbers for the arm, bushings, and hardware? Planning on taking care of this in the near future.
TLChip is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 01:18 PM #6
Real Name: Michael
Real Name: Michael
LCA Driver Side - 48069-60010
LCA Passenger - 48068-60010
Front Cam Adjuster Sleeve - 48409-60020
Front Cam Adjuster Nut - 48452-35020
Front Cam Adjuster Bolt - 90119-14120
Rear Cam Bolt - 48190-60020
Rear Cam Nut - 90179-14069
Rear Cam Plate - 48198-6011
Minus the LCAs themselves, you will need 2 of everything listed above to do both sides. Make sure you get those aforementioned blades, and also don't forget to put anti seize on the new parts going in so that they can be adjusted in the future without freezing up.
Old 10-23-2019, 01:19 PM #7
Real Name: Michael
Real Name: Michael
Also you don't need to purchase bushings separately, if buying OEM LCAs they come assembled
Old 10-23-2019, 01:47 PM #8
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I installed a 1Aauto arm on one side and a used OEM arm on the other in 2017 and no problems so far. The 1Aauto comes with bushings installed and ball joint installed. I added some additional grease to the BJ before install.
I used all OEM alignment adjust hardware.
I don't off-road so that may have an effect on long term reliability and durability, but for $130 its worth a try.
Old 10-23-2019, 01:58 PM #9
blackjackck's Avatar
blackjackck blackjackck is offline
Real Name: John
blackjackck will become famous soon enough
Real Name: John
5th Gen?
I'm casually looking as well but have been looking at the 5th Gen take-offs. I thought they should work with the 4th Gen. Price looks good when I've seen them on FB. Anyone can confirm 5th Gen LCA?
2008 V6 4x4 Sports Edition / Build Thread/ FJ Off Road Package, 265/70/17, 2012 FJ Wheels, Husky Liner, LED bulbs, Spare Bumper -current////// SOLD Past vehicles:1996 V8 Landcruiser Rebuilt; 1988 Jeep Wrangler- 2 inch lift with 33' tires; 1976 Jeep CJ 7 (inline 6) - Frame off restoration
blackjackck is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 02:57 PM #10
Real Name: Michael
Real Name: Michael
Read these when you get a chance. good info
UCA & LCA compatability between 4th and 5th gens
Difference in suspension 4th and 5th gen
Old 10-23-2019, 03:29 PM #11
Awesome, thanks for all the info. Yeah the diablo blades are great I use them for a few different tools.
Old 10-23-2019, 07:53 PM #12
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
I bought an aftermarket. It comes with the bushing and balljoint. I don't off-road much so it's good. No issues so far. Saved a lot on cost.
radlynx is offline   Reply With QuoteReply With Quote
Old 10-25-2019, 08:56 AM #13
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
OEM only with OEM hardware ONLY..
If you live in the salt belt, do not even consider uniball aftermarket lcas..
if you want to spend money and get an upgrade consider these..
Performance Lower Control Arms | DK-812704 – Dirt King Fabrication
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 02:09 PM #14
not much less than I spent on the 4runner to start
those look awesome and sure they perform great, but I'll have to pass.
Old 10-30-2019, 01:18 AM #15
pahaf91 pahaf91 is offline
pahaf91 is on a distinguished road
Ebay LCA Lower control arms
I got the ebay LCA and i use my 4Runner for more off roading then the average person on here i bet. I take it to trails at least 2x a week. And these are serious trails. I had no complaints at all.
Only issue installing these on my 4Runner was that one of the cam bolts was seized so i had to cut it off.
pahaf91 is offline   Reply With QuoteReply With Quote
arms , lower , oem , recommended , toyota
WTB: 4th gen OEM lower control arms Brian3676 Want to Buy/Trade 2 07-12-2019 11:22 PM
WTB: 4th Gen lower control arms whosandrew For Sale: Suspension/Wheels/Tires 1 08-15-2018 03:31 PM
WTB - 5th gen Lower Control Arms Jetboy Want to Buy/Trade 0 01-13-2018 12:37 PM
WTB: 3rd gen upper/lower control arms/rear trailing arms BADCLOWN Want to Buy/Trade 2 05-24-2017 03:11 PM
