Old 04-22-2019, 04:01 PM #1
txclimber's Avatar
txclimber txclimber is offline
txclimber is on a distinguished road
txclimber's Avatar
4th gens running board lights wiring harness
Despite lots of searching, both on this forum and under my truck, I can't seem to locate the wiring harness plug that goes into the socket to power the lights on the "Limited" running boards.
I have a 2007 Sport, and I found several threads that state all models have the harness plug, even though only the limiteds use them. This makes sense, but I can't locate mine.
Can someone confirm that all models do indeed have the plug? And can someone with a limited, or any model for that matter, post a pic showing the plug and where it comes from?
If it matters, I picked up a set of lighted limited boards that I'm putting on my Sport Edition that I'd like to power up. Thanks,
2007 4runner SE V8 4WD: OME BP-51, SPC, Scion IM 2016+
2005 4runner SR5 V8 4WD: ICON Stage 1, Total Chaos UCA, Scion T1819 (SOLD )
1986 4Runner 4WD 22-RE: Full Rebuild, LCE Header, Custom Head, Supra AFM
txclimber is offline   Reply With QuoteReply With Quote
Old 04-22-2019, 04:04 PM #2
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Ill post a picture of mine after I get off, but what does yours look like under there currently? Mind taking a few pictures?
Also when I removed my limited steps the plug was roughly in the middle of them.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 04-22-2019, 04:08 PM #3
txclimber's Avatar
txclimber's Avatar
I'm away from truck as well, but it's pretty blank under there. There are a couple of rubber plugs in the bottom of the body where I could imagine the harness may poke through, but I've fished around inside them pretty good with my finger and not felt anything. There are no loose wiring sockets exposed anywhere near where the running boards are.
Old 04-22-2019, 04:14 PM #4
Real Name: Michael
Real Name: Michael
Hmmm very strange, what you're describing sounds right. Maybe you need to lift the carpet and push them through?? Not sure because I don't have a sport model, but I can still provide pics nonetheless.
Old 04-22-2019, 09:29 PM #5
Real Name: Michael
Real Name: Michael
Here is the pic of mine
4th gens running board lights wiring harness-pic-jpg
Old 04-22-2019, 09:48 PM #6
txclimber's Avatar
txclimber's Avatar
Thanks. Mine is just a rubber plug where your wire is coming out. I'll keep fishing around in there and see what I can find.
Can anyone confirm there is a wire in the Sport Edition? I go on enough wild goose chases as it is, I don't need this to be one too.
Old 04-23-2019, 06:19 AM #7
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
if you want to do it fast and easy, just run a relay harness from the battery, make sure to use the parking light as the trigger, if you want it on all the time with lights outside, now if you only want it on when the door open, then use the door trigger.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 12:45 PM #8
acronin2 acronin2 is offline
Real Name: Lance
acronin2 is on a distinguished road
Real Name: Lance
Any luck finding the harness on your Sport? I have an 04 sport and am looking to add lighted running boards but haven't had a chance to hop under an look yet. TIA
2004 Sport Titanium Metallic, Black WeatherTech Mats, J.A.'s Map Light Mod, 2014 Scion Pioneer Bespoke touchscreen w/ Back Up Camera, Arc Audio xdi805 amp, Handsfree phone/bluetooth steering wheel controls, 06-09 OEM LED tail lights, Interior LED Swap, Gentex 177 AutoDimming Mirror w/ Amber Compass, Sunvisor GPS mod, Avitol 4003 Remote Start w/ factory keyfob, J.A.'s DRL Mod, Back Window Up Hack, OEM 115v AC inverter install, Smokers Kit
acronin2 is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 09:23 PM #9
txclimber's Avatar
txclimber's Avatar
No luck. I can't find the wiring harness anywhere. Leads me to believe despite what I've seen posted before, all trim levels do NOT have the needed harness.
Still hoping someone will chime in and prove me wrong.
Old 11-09-2020, 12:38 AM #10
fefe_grn210 fefe_grn210 is offline
fefe_grn210 is on a distinguished road
Hey txclimber, any luck with figuring out the wiring for those lighted running boards? I have an '06 SR5 and picked up a pair of boards from a '06 Limited today. Looked under my truck and where the adapter would be, mine is also a plain rubber plug.
According to the attached PDF, there's a step of running a wiring harness along the front door sills of the truck and into the dashboard tunnel. I'm unable to find a part number for and it doesn't appear anyone on eBay has this listed for sale.
2006 GRN210 4Runner SR5 | 2011 E90 M3
fefe_grn210 is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 04:45 PM #11
cooper30 cooper30 is offline
Real Name: Ted
cooper30 is on a distinguished road
Real Name: Ted
Long time from the original post, but these are the part numbers I wrote down in my maintenance book when I replaced one on my '08 Limited.
Might help if you find a 12v feed you can use.
Socket - 90075-60005
Connector - 90980-11162
2008 4Runner Limited 4wd V8
2005 Tundra SR5/TRD Off Road 4wd V8
cooper30 is offline   Reply With QuoteReply With Quote
boards , harness , limited , plug , power
Wiring LEDs to the running board wires. 4RunnerIdiot 4th Gen T4Rs 6 10-20-2018 08:26 PM
Wiring air on board switch to Amazon wiring harness. Btmannin Engines / Suspension / Wheels / Tires / Audio / Accessories 3 06-18-2018 03:33 PM
Running board wiring connection lsmo_guy General Discussions 6 09-28-2013 01:16 PM
Anybody know if wiring for '06 Limited running board lights disconnects inside? RanchoRunner 4th Gen T4Rs 7 01-22-2012 11:54 PM
Are all 4th gens prewired for running board lights? jimsi 4th Gen T4Rs 3 03-11-2007 10:42 PM
