Old 04-29-2019, 10:43 AM #1
Samm25's Avatar
Samm25 Samm25 is offline
Samm25 is on a distinguished road
Samm25's Avatar
Need help! Transmission Drain & Fill
I know there’s a bunch of threads for the drain and fill on these 4th gens, but I couldn’t find anything that answered my question.
So, I did a drain and fill about two weeks ago on my 2008 4Runner 4.0 V6. Drained the transmission fluid just fine, about 3.5 quarts came out. I filled it back up with about 3.75-4 quarts. Got the tranny temp up to 118F and took the level check plug off, when I did, I was not getting a “small trickle” as Toyota says you should, so I filled a little more fluid in, etc. still wasn’t getting a trickle.
It’s kind of a long story, but to make it short, my father prematurely turned the engine off while the check level plug was off, so about a quart of fluid came rushing out and I lost it. Luckily I had bought 5 quarts. So I filled it back up to where I was getting a little flow of fluid coming out with the tranny temp in the 115-130F range. My question is, since it’s been about two weeks, would it be bad to get the transmission temp back up between the 115F-130F range and pull the check level plug again to see if I’m getting a steady flow, and if so...should I let the extra fluid out till I get that “small trickle”?
It’s my first transmission job ever, so I guess you live and learn
Thanks for the help
Samm25 is offline   Reply With QuoteReply With Quote
Old 04-29-2019, 11:05 AM #2
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Certainly won't hurt to check. Fluid level is pretty important to the transmission, affects how well it performs in general. You should only have a light trickle when you put the plug back in. Make sure you shift through all your gears a few times before returning to park and leave engine running (Dad) when you check the level.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
back , filled , fluid , temp , transmission
Drain and Fill Sealed transmission Morphyne 4th Gen T4Rs 44 03-26-2016 09:25 PM
Drop pan or drain and fill transmission 4Runner4TW 3rd gen T4Rs 4 09-06-2014 10:15 PM
Transmission Drain and Fill 04 V-6 Boaz Maintenance/Detailing 25 08-08-2013 11:11 PM
Transmission Flush vs. Drain and Fill Shorehunter99 3rd gen T4Rs 8 11-06-2012 10:04 PM
03 V8 Transmission Drain and Fill kujayhawk Maintenance/Detailing 4 07-06-2006 06:35 PM
