Old 04-29-2019, 04:12 PM #1
Reptile Christ Reptile Christ is offline
Reptile Christ is on a distinguished road
What can I expect with these suspension changes?
Hi everyone,
I drive daily a 2006 4Runner Limited V8 with XREAS. We're at 199k miles and the vehicle rides like garbage. There is tons of body roll, it's really bouncy, every single bump rattles my poor little soul, and, frankly, I HATE IT!
XREAS is not leaking and the Toyota dealer only found one loose sway bar bushing, so I'm assuming XREAS is just showing its age and it's time to go. I would like to go the route of upgrading rear shocks/springs and new struts up front. I'm looking hard at this OME kit: OME-FJ4R - Old Man Emu Suspension (07-09 FJ & 03-09 4Runner)
So a couple of questions:
1) What sort of ride will the OME provide versus stock? I know this may be tough to answer since you don't know how my XREAS is currently functioning, so I guess I just wanna know if people are generally comfortable and feel like the OME kit would be a big improvement. The truck is my daily driver, but I'd like to improve its off-road capabilities while not sacrificing too much comfort.
2) Any other options that are comparable but a bit cheaper than the OME kit I linked?
Reptile Christ is offline   Reply With QuoteReply With Quote
Old 04-29-2019, 05:04 PM #2
Chewy204 Chewy204 is offline
Chewy204 is on a distinguished road
I just did the bilstien 5100 swap. Rides amazing now, better then new.
Chewy204 is offline   Reply With QuoteReply With Quote
Old 04-29-2019, 05:07 PM #3
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
The "X-REAS delete..." link in my sig may be of interest. I was in the exact same position and ended up with a massive upgrade for $200 total. There's no doubt the OME setup will be awesome but the problem with suspension is that it's subjective. You can lay out a grand or more on a setup that may not be what you want and there's no way to return it.
I just wasn't willing to do that and decided to minimize my risk by...well, you'll see in the linked post. In any case, while my approach takes some patience and maybe even some luck, it worked out perfectly b/c the ride and handling are terrific but even if I hadn't liked it, I wouldn't have hesitated to write off the $200 and go another direction.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 04-29-2019, 09:08 PM #4
Does that mean you put 5100 Bilstein shocks all around but left the original springs? Is there a guide you used?
Old 04-30-2019, 05:28 PM #5
Yes i left the original springs. Did a 2.5" spacer lift. And it rode like garbage with the xreas so got the 5100's.
I didnt use a guide. But it is pretty straight forward. If you dont know what you are really doing. I would have a shop do it.
Old 04-30-2019, 08:15 PM #6
Powder_Hound's Avatar
Powder_Hound Powder_Hound is offline
Real Name: Neil
Powder_Hound is on a distinguished road
Real Name: Neil
Hi everyone,
I have done this very similar lift/upgrade when my XREAS died. At 199K you will prob benefit from new springs as well.
It will ride more like a truck, feel more like a truck, and carry loads more like a truck. It will also roll a bit more than XREAS when new as the XREAS is designed to lessen body roll with the hydraulics and check valves in XEEAS. XREAS is great if you drive mostly on road. However, an OME or other suns replacement will allow your T4R to drive more like a 4x4, off-road better, and give you a more aggressive appearance.
As others have stated this is subjective, but this is my .02 on what you are looking to do. I’d recommend getting the middle weight springs vs. the heavies unless you plan to tow. 👍🏻
1st was an 87, 2nd was a 95 and 4th gen is a 04 V8 Sport. OME 885/Toytec RCC2.0HD, SPC UCA's, RCI Sliders with top tread, Airlift 1000, and BFG ATKO2's - 265/70/17's. Tekonsha brake controller, EBay interior LED's, and Kenwood DDX 594 radio. Yakima roof rack for all seasons up top.
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
Powder_Hound is offline   Reply With QuoteReply With Quote
Old 04-30-2019, 09:37 PM #7
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I did similar to bluesky, 4600 Bils, '07 FJ springs front and rear and very happy with results. I like that the TRD springs bluesky used leveled the vehicle, mine still has a rake, had I known in advance would have used the TRD springs.
Will keep that in mind when I get bored and want a project!
Old 05-01-2019, 06:06 AM #8
Bluesky 07's Avatar
Bluesky 07's Avatar
FWIW, I've driven since December, about 5K miles, on my new-to-me TRD Offroad/FJ setup, mostly on the pavement but also off (video below), and it's golden. @powder hound also makes a great point about the springs. It's tempting to keep the originals, especially to save $, and it may be fine. But you're on 13-year-old metal that has carried your rig the equivalent of 8 times around the world. For me, the decision was easy b/c one rear spring was sagging about an inch (have you measured yours, left vs. right?). I also knew it would bug me to wonder all the time how much better my truck would ride if I had just gotten new springs.
Deciding what to do is tough b/c there are so many options, and we all want to think ours is best. That's not what I'm saying, I'm only suggesting getting as close as possible to a "test drive" with a new setup without committing a wad of cash. Something else you might consider is connecting with a local 4R group where you could ask people to show you their setups and maybe even get a ride around the block to see how it feels.
Some recent fun:
Old 05-01-2019, 02:15 PM #9
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
I did a 2.5" Daystar lift with quick strut replacements a year ago.
I never had the Xreas system, but just wanted a better look but factory smooth ride.
It has held up but the next time around, I'd likely upgrade to a real lift. We'll see in 50k miles.
gaber6 is offline   Reply With QuoteReply With Quote
daily , kit , ome , rides , xreas
What "noises" to expect from new suspension? Ogbassist182 4th Gen T4Rs 9 03-14-2016 03:02 PM
How bad can expect an OME heavy suspension setup to beat me up when not towing ECT_Gumby 3rd gen T4Rs 6 06-26-2015 12:35 PM
WTB a T4R around 7k what should I expect? fungames43232 Classifieds - buy & sell (no commercial ads please) 1 05-18-2011 09:23 PM
FJ Suspension High much lift to Expect? cknsls@adelphia Problems & Warranty Issues 0 09-15-2010 05:36 PM
so i an expect how much?? 810moto 4th Gen T4Rs 1 04-03-2010 08:50 AM
