Old 04-30-2019, 10:23 PM #1
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
9 Easy Steps to Lighting Your 4th Gen's Door-Mounted Switches
We all know our friends at Toyota "missed an opportunity" by not lighting the window and lock controls in the door panels. I followed a 2009 thread by @loner and appreciate that info, but the pic links are dead so I decided to do a step-by-step write up. This mod is pretty easy and really makes a difference in the dark, be it nighttime, parking deck, tunnels, etc. As with all write-ups, this is for info only and you are responsible for safely accomplishing any work on your vehicle.
You will need the following for each door you wish to light:
- An LED bulb designed for a 12V system - I used this orange one from Radio Shack to match the OEM dash illumination.
- Drill & appropriately sized bit (9/32 for the Radio Shack LED linked above)
- Quick disconnects (technically not required but a must for facilitating future door panel removal). As seen in the pics, I used a different type but if doing it over, I would use these as they’re less expensive and more similar to the OEM plugs.
- Method to tap power (I used a red Scotchlok, the kind that folds over the wire and forms a female connection to plug into.)
- Method to ground the black wire (I crimped a ring onto it but whatever works)
Steps:
1. Remove the door panel. (Thanks, @SamNavy )
2. Drill an appropriately sized hole. This is obviously after the mod was done but shows where the mounting hole goes.
3. (Optional) Test the LED to be sure it works. If it doesn't, you'll be glad you discovered it now. (A quick & simple test is to touch the red and black wires to the + & - terminals of a 9V battery. It won't light all the way but you'll know it works.)
4. Install & secure the LED. This is probably the toughest part of the job b/c of the tight quarters. The Radio Shack bulbs have a threaded base and a nut, but it’s really hard to turn the nut to get it tightened down. It’s been a while so I can’t recall whether I gave up and just glued it in, but in any case, it doesn’t have to look perfect since no one will see it. As long as the LED is secure, you’re good.
5. Splice in one half of the quick disconnect to the wires from the LED bulb, red to red and black to black. I soldered the connections and used heat-shrink tubing over each one.
6. Tap the power.
a) Crimp a male blade-type connector onto the red wire from the other half of the quick disconnect.
b) Verify ignition is off. (You may also wish to disconnect your battery, though I didn't.) For the driver's side door, the correct wire is in the large bundle that goes to the door controls. It's the black one 4th from the left on the top row in this pic. Trace it carefully back from the plug b/c there's more than one black one IIRC. The one you want is a little thicker.
Be sure to use the black one since it has switched power. This means the LED will be on whenever the ignition is turned on, but it’s not bright enough to be seen during the day and will do no harm being on. (Do not use the red wire next to the black one; it has constant power so it will likely drain your battery.)
Attach the Scotchlok to the black wire as shown here then plug the male connector in. You may have to cut away part of the insulation on the male connector.
7. Crimp a ring onto the ground wire of the quick disconnect and attach to a known ground. I used this 10mm bolt next to the plastic-covered hole. YMMV, but this bolt was very tough to get started on my truck. A breaker bar may be useful.
8. Connect the two halves of the quick disconnect plug, turn on the ignition, and verify the LED lights up.
9. Reassemble the door and enjoy the knowledge that you will never again have to fumble in the dark for those window and lock buttons.
(This is more yellowish than it really looks but you get the idea.)
To find the right power wire in other doors, use a circuit tester like this one from Harbor Freight.
1. Unplug the wire bundle to the door controls.
2. Attach the tester's black wire to a ground (metal body or chassis bolts are usually good).
3. With the ignition off, touch the tester's metal tip to the metal contacts in the face of the plug. If there's a red wire, try it first. When the bulb in the tester lights, you've found a constant power wire (and know the tester is working). You can eliminate this wire from consideration (unless you want constant power for whatever reason, in that case you're done).
4. Repeat step 3 with the ignition on, ignoring any constant power sources. When the tester lights, you have found a switched power source. That's the one you want for this mod.
That's it. Feel free to ask any questions or make suggestions to improve the process based on your own experience.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 05-01-2019, 06:49 AM #2
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Nice job!
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 01-21-2022, 12:39 PM #3
Mike_NL Mike_NL is offline
Mike_NL is on a distinguished road
Very nice helpfull job!
Mike_NL is offline   Reply With QuoteReply With Quote
Old 01-21-2022, 03:16 PM #4
Urbanite Urbanite is offline
Urbanite is on a distinguished road
Great tinkering, is the blub still going strong some 3 years later?
Urbanite is offline   Reply With QuoteReply With Quote
Old 01-21-2022, 04:08 PM #5
Bluesky 07's Avatar
Bluesky 07's Avatar
Yes, and funny you should ask, just yesterday I dropped something on the floor and noticed the bulb, bright as ever, when I reached down to grab whatever it was.
Old 01-23-2022, 02:49 AM #6
Bulb Sourcing
Now that Radio Shack is old history, I can't find anything that might work. I looked at this website, but not sure what to get: Automotive Led Lights Catalog - LEDLight.com
Any idea where a similar bulb could be had? Thanks.
Old 01-26-2022, 09:45 AM #7
Bluesky 07's Avatar
Bluesky 07's Avatar
Yes, my garage. ;-) Check your PMs.
Old 07-01-2022, 09:19 AM #8
BradB's Avatar
BradB BradB is offline
BradB is on a distinguished road
BradB's Avatar
I'd also like to find the bulbs you used. This looks like a great mod!
BradB
‘23 Toyota 4Runner TRD ORP / ‘96 Porsche Carrera 4S / ‘14 Porsche Carrera S / ‘17 Audi TTS / ‘17 Porsche Macan GTS / ‘21 Honda CRF300L / ‘23 BMW R1250GS / ‘23 Husqvarna Norden / ‘22 Honda CB500X / 1959 Radio Flyer
BradB is offline   Reply With QuoteReply With Quote
Old 07-03-2022, 05:08 PM #9
kentaaronj kentaaronj is offline
kentaaronj is on a distinguished road
Great guide, thanks!
kentaaronj is offline   Reply With QuoteReply With Quote
Old 07-03-2022, 08:08 PM #10
Bluesky 07's Avatar
Bluesky 07's Avatar
BradB
Seems the Radio Shack bulb I used is no longer available. The 6mm amber version of the one below is the closest thing I’ve seen to it so far. Couldn’t share the link for whatever reason but just search for this on Amazon.
Old 07-03-2022, 08:31 PM #11
BradB's Avatar
BradB's Avatar
Thanks! I was digging around a while and came across that bulb, too. I was hoping it might do the trick.
Old 10-08-2022, 06:08 PM #12
I was finally able to do this little project today. Thanks to Bluesky 07 who started this thread and who generously donated his extra RadioShack blub to me a few months back.
Making the hole to mount the bulb was a bit of a challenge due to limited space, unless one had a small size drill. I used a right angle drill with a 9/32 bit. I also got the positive wire connection from the tweeter top wire harness as shown in picture. The negative could be connected to any of 4 screws attached to door frame, also shown here. Thanks a lot Bluesky 07!
9 Easy Steps to Lighting Your 4th Gen's Door-Mounted Switches-wires-connection-jpg
Old 10-12-2022, 09:56 AM #13
smc08i smc08i is offline
smc08i is on a distinguished road
Great guide, thanks for this!
smc08i is offline   Reply With QuoteReply With Quote
Old 10-12-2022, 12:45 PM #14
2003V8LTD 2003V8LTD is offline
2003V8LTD will become famous soon enough
Not clear on what the need for this is. The driver's window switch is already illuminated at night. Isn't that all you really need?
Steps:
6. Tap the power.
2003V8LTD is offline   Reply With QuoteReply With Quote
Old 10-12-2022, 05:48 PM #15
Bluesky 07's Avatar
Bluesky 07's Avatar
@2003V8LTD - Well, YMMV and it's probably not a priority for a lot of people. I use the other switches regularly and also found the backlit driver's switch to be pretty dim.
black , door , led , quick , wire
Need ideas: Ambient lighting for door switches loner 4th Gen T4Rs 17 01-21-2022 12:33 PM
How To Move In 17 Not So Easy Steps peter78 Off Topic 7 11-04-2014 12:34 AM
Frame Mounted Side Steps Jamobi 5th gen T4Rs 5 11-03-2014 01:51 PM
Back lighting after market switches GrantK 5th gen T4Rs 3 08-10-2014 02:38 AM
How To Get Things Done, by being a Redneck (10 Easy Steps) 4Running Daily 3rd gen T4Rs 18 12-31-2011 03:12 PM
