Originally Posted by blackoutt
Yes I know I could go to a plate bumper or build a full custom setup but for some reason I like the stock plastic bumper covers and don't feel that they limit me for what I use my rig for. That being said, when wheeling, the most common thing I hit on is my V8 rear hitch hanging low. If I move it up out of the way I guess I could damage other things but I'd like to consider my options for slightly more clearance in the back. I've seen GX470 guys install the standard and high tuck hitches to their stock crossmembers so I'm assuming this would be the same thing on our 4runners? Anyone have any experience with this before I buy and start cutting up my bumper cover?
Metal Tech High Tuck Rear Receiver - Metal Tech 4x4
Looks nice actually! If you don’t tow anything I’m sure it would be fine for the occasional tug to remove a stuck Jeep. Nothing will be as strong as the load distribution hitch or a full plate bumper with a hitch built in though.
If you’re handy with fabrication tools I’m sure you could make it stronger by welding more bracing on the backside of the stock crossmember which would distribute loads a lot better, should you decide you still want to tow with it.
