05-05-2019, 11:43 AM
Need help with last step before removing subwoofer, anyone?
Ok i have a 2005 Toyota 4Runner Limited and am replacing the jbl sub. I followed a write up on here and removed all screws but cant get the side door panel up and away what am i needing to do that wasnt in write up based on the pictures i am enclosing. anyone that could shed some light so i can finally install my new sub would be greatly appreciated.
In the pics i have the double decker cargo shelf on and tried sliding it down. Was i. Supposed to remove it all together. I feel like the seat is also stopping that end of panel from coming out
05-05-2019, 11:44 AM
The pics arent rotated so it may seem confusing. Sorry
05-05-2019, 12:16 PM
When I did my sub, my seats and shelf were already out, so the job seemed easier than the write-ups had made it out to be. So yes, maybe remove them? Neither are difficult to remove, but they do add to the project.
04 V8 Limited
Lifted, lit, locked, protected
Coffee machine and crock pot equipped
05-05-2019, 02:26 PM
This video.
YouTube
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
05-05-2019, 11:08 PM
go to remove the 2 bolts that hold the double deck tray.
follow the guide for the rear cargo removal for stereo installs.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
05-06-2019, 11:10 AM
I literally did this yesterday. Fold the cargo deck all the way flat, remove the long piece closest to the back seat first, it's 2 10mm bolts held inside the plastic pieces with the rings.
Then with the cargo tray flat, there are 2 more 10mm bolts holding this part to the frame.
Hope this helps!
05-06-2019, 09:30 PM
Thanks so much that was what i needed. Now another question i bought a sub that is a quick connect for wires and the wires from old sub are attached to clips, do i cut amd strip them from the clips?
05-06-2019, 10:49 PM
yeap, just make sure you got the positive and negative correctly.
if its too short, just make some extensions.
05-06-2019, 11:40 PM
Thank you so much, so i should refer to the wiring manual to find out what wires are the positive anc negative? Im sorry im a girl.
05-07-2019, 10:16 AM
One set of wires is yellow/red, and the other is green/black.
If you read at the bottom of the OEM connection, it shows +/-.
Hope this helps. It took me all of 5 minutes to cut the factory clips and rewire the new sub.
05-07-2019, 01:03 PM
If you haven't finished this yet, the plug is shaped like a T and you can see the + and - when you pull the plug. The bottom of the T should be + and the top should be -.
And for what it's worth, being a girl shouldn't matter. You're probably ahead of a lot of boys on here for even trying it. You go, non-gender-specific-vehicle-modifier.
05-07-2019, 05:13 PM
This is a pic of the wires that went to old subwoofer which i have now cut the black clips off and ready to be installed on this new sub with this kind of connect on each side. Please advise as to which wires go in which connect slots please and thank u all so much
05-08-2019, 04:05 PM
your speaker
Red wire to red connector........Yellow wire to black connector
Black wire to Red connector.......Green wire to Black connector
05-08-2019, 04:09 PM
On the speaker, the spring loaded button with a red top denotes positive, the black button denotes negative. Do NOT think match colors. The sub woofer actually has 2 speakers, red and yellow go on one side......black and green go on the other side.
Just remember you will have a reduced output as the speaker you chose was 4 ohm.
05-08-2019, 09:19 PM
thank u so much thats what i needed, sub is installed and everything is put back together and it sounds great since the other one was blown and rattled i couldn't listen to certain songs now i can. Thank you all so much i. Have been lurking this website for years since i had an 03 sport and now an 05 limited and i couldn't have figured out half the things i needed to know without this site. Im so glad theres a site dedicated to 4runners ill be asking a few other things in the weeks to come. But in. The meantime thanks again everyone
Reason: Forgot words
