Old 05-05-2019, 02:12 PM #1
magert54's Avatar
magert54 magert54 is offline
magert54 is on a distinguished road
magert54's Avatar
I need your help owners
I'm replacing my CV's and steering rack and when I was putting it back it was stuck with an extra hose dangling.
It was connected to a capped end. This was next to the battery its left side.
Can someone trace the line from the capped point next to the battery and explain it or take picture of its end point.
Thanks in advance
2006 4.7L V8 SE
Build Thread Colorado
magert54 is offline   Reply With QuoteReply With Quote
Old 05-05-2019, 08:16 PM #2
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
It’s most likely the breather tube for the front diff. It has a small metal “cap”, that is actually a breather. It is attached with a metal bracket that is very close to the battery area.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 05-05-2019, 08:28 PM #3
magert54's Avatar
magert54's Avatar
Thank, based on my pictures, the line has the cap at the bottom of the pic and on the other photos that connects to the lip in the center of the photo. Where did the other end go to?
Sent from my SM-G930P using Tapatalk
2006 4.7L V8 SE
Old 05-05-2019, 11:05 PM #4
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
i think thats the front diff breather for the 4wd models.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 05-05-2019, 11:15 PM #5
magert54's Avatar
magert54's Avatar
Thanks, I'll attempt to locate it in the morning. I've so spent a solid hour staring at the drivers side near the CV boot wondering where the hook up point was. I've resorted to the forum as it's been a 2 weeks since I started the project and forgot where it was.
2006 4.7L V8 SE
Old 05-06-2019, 10:55 AM #6
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Agreed, looks like front diff breather. The first post in the link below shows it in position...
4th Gen Front Diff Breather - YotaTech Forums
eleven14 is offline   Reply With QuoteReply With Quote
Old 05-07-2019, 08:08 AM #7
magert54's Avatar
magert54's Avatar
To clarify, I know where the hose starts (top next to battery) I don't know where the end of the hose is connected to. Can someone provide pictures or information on what I'm looking for.
2006 4.7L V8 SE
Old 05-07-2019, 08:30 AM #8
Direwolf82 Direwolf82 is offline
Direwolf82 will become famous soon enough
Sorry boss, I just looked and without jacking it up and maybe pulling a wheel or skid plate I can't see where it goes into the diff.
In other vehicles I have it's always on the top of one of the tubes, of course they are solid axle.
I'll try looking again after work when I have more time.
Direwolf82 is offline   Reply With QuoteReply With Quote
Old 05-07-2019, 09:22 AM #9
Took a break and had another look from another angle.
Mine goes down from the battery and turns above the CV and goes to the top of the pumpkin. I don't know how to put up pics yet. Hopefully that helps get you in the right area.
Old 05-07-2019, 10:07 AM #10
magert54's Avatar
magert54's Avatar
Thanks, this is the guidance I needed. I've Googled, binged, YouTube and still my searches are without progress. You have narrowed my search in the area drastically.
2006 4.7L V8 SE
Old 05-07-2019, 08:24 PM #11
magert54's Avatar
magert54's Avatar
Found it!!!
2006 4.7L V8 SE
Old 05-08-2019, 07:29 PM #12
Sweet!!
I hope that means you got to go on a test drive?
Old 05-09-2019, 10:52 AM #13
magert54's Avatar
magert54's Avatar
Yep, while limping to the alignment shop I heard my tyres chirping and felt the front end bouncing. Once I arrived the shop was quick to work. It took two alignments, first was 6 degrees off and their machine only registers up to 3 degrees. They had to eyeball it and try again. 30 min later, it was done and WOW! My truck turns like my Avalon and its great. Next I will have to reinstall the shrockworks and I'm ready for the season.
2006 4.7L V8 SE
Old 05-09-2019, 09:32 PM #14
Excellent, good luck this season and enjoy it!
battery , capped , end , left , point
Help. 3rd Gen Non-ABS owners quatin 3rd gen T4Rs 3 04-14-2019 12:54 PM
4th Gen owners who were 3rd Gen owners, suspension question RickC 4th Gen T4Rs 18 11-27-2015 07:06 PM
TRD Transcooler owners or similar cooler owners check in please SIKHILUXSURF 3rd gen T4Rs 6 06-21-2012 09:12 AM
99 SR5 owners or past owners Woodsie8 3rd gen T4Rs 4 12-17-2011 11:44 PM
3rd gen 4R owners! airbag Engines / Suspension / Wheels / Tires / Audio / Accessories 3 03-04-2007 12:02 AM
