It’s most likely the breather tube for the front diff. It has a small metal “cap”, that is actually a breather. It is attached with a metal bracket that is very close to the battery area.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Thank, based on my pictures, the line has the cap at the bottom of the pic and on the other photos that connects to the lip in the center of the photo. Where did the other end go to?
Sent from my SM-G930P using Tapatalk
i think thats the front diff breather for the 4wd models.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
Thanks, I'll attempt to locate it in the morning. I've so spent a solid hour staring at the drivers side near the CV boot wondering where the hook up point was. I've resorted to the forum as it's been a 2 weeks since I started the project and forgot where it was.
To clarify, I know where the hose starts (top next to battery) I don't know where the end of the hose is connected to. Can someone provide pictures or information on what I'm looking for.
Sorry boss, I just looked and without jacking it up and maybe pulling a wheel or skid plate I can't see where it goes into the diff.
In other vehicles I have it's always on the top of one of the tubes, of course they are solid axle.
I'll try looking again after work when I have more time.
Took a break and had another look from another angle.
Mine goes down from the battery and turns above the CV and goes to the top of the pumpkin. I don't know how to put up pics yet. Hopefully that helps get you in the right area.
Thanks, this is the guidance I needed. I've Googled, binged, YouTube and still my searches are without progress. You have narrowed my search in the area drastically.
Yep, while limping to the alignment shop I heard my tyres chirping and felt the front end bouncing. Once I arrived the shop was quick to work. It took two alignments, first was 6 degrees off and their machine only registers up to 3 degrees. They had to eyeball it and try again. 30 min later, it was done and WOW! My truck turns like my Avalon and its great. Next I will have to reinstall the shrockworks and I'm ready for the season.
