Old 06-06-2019, 07:42 PM #1
Marfy's Avatar
Marfy Marfy is offline
Marfy will become famous soon enough Marfy will become famous soon enough
Marfy's Avatar
Tensioner pulley
Hi there -
No real point to this post except to say that I changed my tensioner pulley yesterday. It was absolutely horrible. This is on the v8 by the way. Dear god.
Tight quarters...crazy angles...busted knuckles.
That being said, I’m really happy I did it. No more squeal. And, it is doable with patience!
For me, I unbolted the Alternator, steering pump, timing belt cover, and the tensioner pulley. Also, I removed my skid plate, my right front wheel and the fender liner. I also had to disconnect my air box, the main coolant line (bucket below), and the coolant reservoir.
Best of luck to those doing this!
[Sold] 2007 Limited - V8 4WD
Stock Rear RAS / Bilstein 5100s / OME 885 / RB 1.25 BL / BFG KO2s - 275/70R17 / SCS Ray 10 - Brushed Gold /
XenonDepot Hid Kit (lows) / Aftermarket Yellow Fogs w/ XenonDepot HIDs / DT Premium Long Tubes / Custom Y w/ 2 cats deleted / full custom exhaust pipe with magnaflow / aFe CAI / MAF Calbrator
Marfy is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 08:56 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Originally Posted by Marfy View Post
Hi there -
Wow, I replaced my tensioner pulley on my V8 about 2 months ago...but I never removed anything but the pulley, not understanding why you had to remove all of what you did to do your's, sure it's tight in there and yes busted knuckles galore, well at least one or two, but I had mine done within 30 minutes, the hardest part for me was keeping the new serpentine belt on all the rest of the pulleys until I could slip it over the tensioner pulley and release the pressure on the tensioner.
Did you replace the entire tensioner or just the pulley?
2004 Limited V8
Old 06-06-2019, 09:51 PM #3
Marfy's Avatar
Marfy's Avatar
I did the whole tensioner... maybe I should not have... sounds like the pulley itself would have been about 5hrs less...
Old 06-06-2019, 09:58 PM #4
Real Name: Skip
Real Name: Skip
Yes I can see where it would take longer to do the entire tensioner, the tension on mine was great so I saw no need to replace it, only the bad pulley/bearing.
2004 Limited V8
Old 06-07-2019, 06:41 AM #5
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Sounds like the best time to do that replacement would be when doing the timing belt since all that stuff has to come off anyway. I was planning to do just the pulley when I do the others and the belt, but maybe I’ll do the whole assembly at one time when I do the TB this season. The pulleys are occasionally noisy when it gets really cold during warmup, but then it goes away so I was planning to at least get new bearings for them at minimum. I have a press, so if the pulleys themselves aren’t grooved or worn, I’ll just do the bearings.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 07:43 AM #6
ZiaMan ZiaMan is offline
ZiaMan is on a distinguished road
If you are thinking about it, def do it during the TB replacement. I didnt realize it while I did my TB until i got to the point of putting my old tensioner and pulley back on.
2008 Nautical Blue GX470
Bilstein 6112/5160
ZiaMan is offline   Reply With QuoteReply With Quote
coolant , pulley , skid , tensioner , timing
Tensioner pulley! 03LTDTR4 4th Gen T4Rs 19 10-31-2021 10:59 PM
Tensioner pulley or tensioner assembly? T4R03 4th Gen T4Rs 3 03-07-2019 09:17 AM
Tensioner Pulley Assembly - Can the pulley itself be just replaced? Lyric_Kayden 4th Gen T4Rs 4 10-24-2014 11:26 AM
Tensioner Pulley Replacement peroxide 4th Gen T4Rs 1 03-12-2014 12:52 PM
Ps Belt Tensioner Pulley GEOFF Classic T4Rs 4 12-08-2008 05:52 PM
