Old 05-09-2019, 02:57 PM #1
thirdelement's Avatar
thirdelement thirdelement is offline
Real Name: Richard R.
thirdelement is on a distinguished road
Post Instructions - How to enable DRL for 2003-2005 SR5
In the process of researching other items for my 03 sr5 i kept seeing listings to disable DRL's and it reminded me that I was missing those from this vehicle. My rav4 and my is300 both had that..and i wanted to find a way to get this working.
From the threads i found out that at time of purchase new, it was a $40 fee to enable this. So, right off the bat, this told me it couldnt be something to0 hard or too intensive. I used this page: Toyota 4Runner DRL Mod as a starting point for wiring. and when you stop and think about it, essentially you are just flipping around what a relay would do. however there had to be an oem solve for enabling them.
in a thread asking some questions, ED_C spoke up and offered a DRL relay that we thought would just swap out with the current "non-drl" relay. I also found from my research that folks were having to visit the dealership in order to turn off the drl option. This made me wonder if parts alone wouldnt solve my task.
So he shipped it to me for free, and i started the removal of the knee panel, and also removal of a couple bolts and nuts to gain access to the back of the fuse panel.
behind the fuse panel you will see a tan relay. that is the non-drl relay.
you will need to remove this and the small 3" harness attached to it.
the black plug at the end of the harness will plug into the DRL relay later
i will look like this when removed.
slide on the black drl relay box with the plug facing towards the passenger side.
plug in the black plug.
reassemble and enjoy your drls.
next diy will be adding auto headlights (with sensor, harness, and blinker stalk)
2003 SR5 4Runner, JBL 9 speaker, 73,500 miles (4/17/2019)
TRD Trail Wheels, M800i WARN Winch mounted with Trans4mer
Pioneer AVH-W4400NEX/ND-BC8 rear camera, RF1000a1 amp, Alpine SWR-12D2 12" sub, Auxbeam, 2006 brake lights,
thirdelement is offline   Reply With QuoteReply With Quote
Old 05-09-2019, 03:43 PM #2
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
...my 2005 sr5 has those ambers lit up as DRL, you think the previous owner did this? i thought it was stock
hinmo24t is offline   Reply With QuoteReply With Quote
Old 05-09-2019, 05:32 PM #3
It was an option at the time of purchase. This wasnt touched by the previous owner.
Old 05-09-2019, 11:55 PM #4
alextmullis's Avatar
alextmullis alextmullis is offline
alextmullis will become famous soon enough
If you hook up a diagnostic scan tool you can switch them on and off... my limited has the option to do so
alextmullis is offline   Reply With QuoteReply With Quote
Old 05-09-2019, 11:55 PM #5
4RunnerMexico 4RunnerMexico is offline
4RunnerMexico is on a distinguished road
You can also enable and disable these lights if you have Techstream FYI. Super easy
4RunnerMexico is offline   Reply With QuoteReply With Quote
Old 05-10-2019, 04:25 AM #6
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
One of the components of the optional DRLs is the DRL-specific relay I sent him to try out. That relay has the additional circuitry for the DRLs. Go ahead and try activating the DRLs via scan tool without that DRL relay, they won't turn on without the proper relay.
My main worry was the body ECU (the one accessed via scantool/Techstream to activate/deactivate DRLs) wasn't default with the DRL "on" signal activated. Luckily by default it was.
Old 05-10-2019, 06:28 AM #7
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Awesome thread! Very helpful for those not having the DRL. Fortunately mine has it, but if I didn’t, I’d be doing this mod ASAP.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 05-10-2019, 12:09 PM #8
i am glad to have been able to test this so quickly and really liked that this was a fast install.
black , drl , harness , plug , relay
Lock Actuator Replacement Instructions 2005 4runner HURRICANES 4th Gen T4Rs 1 01-09-2017 07:16 PM
Enable quick reply munkel General Discussions 9 08-22-2016 03:56 PM
Console Vault for 2003,2005,2005 natevans65 4th Gen T4Rs 19 12-05-2012 02:24 PM
Need repair instructions on 2005 SR5 Rack & Pinion Carsonsmom 4th Gen T4Rs 1 10-18-2012 03:23 PM
How do I enable unlocking all 5 doors on 2003 with one push of the unlock on remote tribaldragon 4th Gen T4Rs 2 03-07-2005 09:35 PM
