Originally Posted by Johns06yota
If I notice based on readings that the system is running hot due to no intercooler or lean I can easily disconnect things until I add larger injectors/fuel pump/engine management. Since theres no info on turbo 4th gen v6 4runners I'm basically in the dark other than a buddy of mine and some of the boosted third gen guys lmao.
Im a big fan of water-methanol injection for intercooling. Truly amazing stuff can be done with it. I used it on my turbo Eclipse 22psi on a larger turbo with pump gas. Works great
If/when you get to needing larger injectors, see if the Apexi SAFC or Neo is compatible with 4Runner... or other compatible piggyback fuel controllers to dial in the fuel curves. Combine that with your wideband and you can get pretty far with it
