Old 02-06-2020, 02:03 PM #121
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
throw the turbo away and sell the rest. its junk.
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
Old 10-13-2020, 12:08 PM #122
Inv4drZm's Avatar
Inv4drZm Inv4drZm is online now
Inv4drZm's Avatar
@Johns06yota
Looking into building a rear-mount turbo for my single cab Tundra 4.7L. Tons of room underneath since it doesn't have a t-case. Do you know the pros/cons to having the turbo mounted far back near the axle like yours, or would it be better since I think I have the room to mount it near the transmission? Shorter charge piping and exhaust should reduce lag in the system right? Would give me decent room for mufflers behind it. Little more protected up there. Thoughts? Looking at 3-5 lbs of boost max, but just want to do it right.
Inv4drZm is online now   Reply With QuoteReply With Quote
Old 10-14-2020, 05:09 PM #123
toyoman25's Avatar
toyoman25 toyoman25 is offline
toyoman25 is on a distinguished road
toyoman25's Avatar
Originally Posted by Inv4drZm View Post
@Johns06yota
Do a Super Charger not turbo
Toyo is my Name and My Ride
toyoman25 is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 06:31 PM #124
Inv4drZm's Avatar
Inv4drZm's Avatar
Superchargers are around $4k used if you can even find one, let alone belts for them. I'm not sure they'll fit the VVTI motors either.
Plus no turbo noises.
Old 10-15-2020, 01:49 PM #125
Piggity Piggity is offline
Piggity will become famous soon enough
I'd but the turbo in the engine bay, there's room. You might need to move the A/C lines out of the way but it should be doable. I'm sure you've seen this kit on ebay....
John's Turbo v6 Build-s-l1600-jpg
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
Piggity is offline   Reply With QuoteReply With Quote
Old 10-15-2020, 02:25 PM #126
Inv4drZm's Avatar
Inv4drZm's Avatar
I've seen the kit, and for an offroader that would be the way to go. But if I do forced induction I will keep it a street truck only anyway.
With a rear mount you don't have to mess with installing headers or moving anything around in the engine bay, or even using an intercooler. I can fabricate everything myself with my tig welder. It would be an insanely simple system and good enough performance for my uses. I mainly just want to hear a turbo whistle.
Old 10-16-2020, 01:49 PM #127
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
So if this is yours tell us a little bit about it: performance, fuel economy, etc.
When did you do it, mileage, a few install details.
Thanks!
Old 10-18-2020, 02:18 PM #128
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I wonder what vehicle this is, must be a Tundra. ABS block is on PS and brake booster is vacuum.
Old 10-19-2020, 02:32 PM #129
No idea, it could be the 4Runner, Tundra, or Sequoia.
Thanks!
Not mine, read my post about it being the eBay kit.
Old 11-18-2020, 10:56 PM #130
Johns06yota's Avatar
Johns06yota Johns06yota is offline
Real Name: John Iannacone
Johns06yota has a spectacular aura about Johns06yota has a spectacular aura about
@Johns06yota
sorry for the late reply. your best option is going to be placing it in the engine bay. the v6 just does not flow enough to spool for boost in a timely manor that far back. The amount of money I spent to get it to spool with a little lag would have paid for someone to make custom manifolds. My other concern with rear mount was an oil line blowing or the scavenge pump failing. basically what im getting at is rear mount seems easier on paper but adds a lot of difficulty that you dont initially see. by doing engine bay mount you will get boost quick enough for slow speeds and also keep the reliability factor higher
__________________________________________________ ___
If you are looking for custom 4runner parts, then look no further!
iannaconeautoaccessories.com
Johns06yota is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 10:07 AM #131
Inv4drZm's Avatar
Inv4drZm's Avatar
That is my conclusion as well, though for what I want it for a rear mount could still work. I don't need a ton of power. I'll just need to research some more. I found this thread for a V6 Tacoma where they did a single turbo in the engine bay. If its possible to build a kit this way without pulling the engine that might be my best bet. Also as mentioned there is already a kit out there that should work for my application.
TORSPD: NEVR | Page 417 | Tacoma World
John's Turbo v6 Build-boost-jpg
Old 12-12-2020, 04:26 PM #132
Steve Theodore Steve Theodore is offline
Steve Theodore is on a distinguished road
I'm sad to see that the OP went to so much trouble to fabricate and build this kit only to have to throw in the towel. The community would so benefit from more research done into turbocharging the 4.0L V6, and it was fun to see the work being done to accomplish that.
Did anyone buy the used kit? Are developments ongoing?
Again, sorry to see it come to an end...very cool stuff. I wish there were some published dyno or Dragy numbers made just to quantify the differences too.
Steve Theodore
2008 Toyota 4Runner Sport Edition V6 4x4
ex-2000 Toyota 4Runner SR-5 V6 4x4 5 speed (R.I.P. old girl)
2012 Lexus IS-F
2001 Lexus IS300 slicktop
Steve Theodore is offline   Reply With QuoteReply With Quote
boost , gauge , turbo , wideband , wires
John's 99 4runner rebuild/build mmml4 3rd gen T4Rs 153 07-29-2020 09:07 PM
98 Turbo (re)build jerrydub10 3rd gen T4Rs 116 08-04-2019 11:50 PM
BAMFT4R Turbo Build lhoy12 3rd gen T4Rs 8 06-21-2018 02:36 PM
Rock Toy Industries 3rd gen 3.4 Turbo Build RTI 3rd gen T4Rs 97 12-13-2015 09:43 PM
Flatboys rear turbo build flatboy 3rd gen T4Rs 135 04-03-2015 04:52 PM
